Kicker HS10 to Sony “easy sub” out
Discussion in 'Audio & Video' started by TheDamaso, Mar 16, 2023.
  1. Mar 16, 2023 at 3:52 PM
    TheDamaso
    TheDamaso [OP] Well-Known Member
    Damaso
    Baytown TX
    98 2.7 4x4 5sp, 2014 TRD OR
    Hello guys, ran into a new one. Installed a 8” kicker self power sub under the seat of my first gen and I absolutely loved it; so u decided to buy a 10” for my 2014 double cab. Ran the wires; used the kicker KISL deal to get to this: am I missing something or does it only have 1 sub out? This is a Sony XAV 3250 or something like that aaaaand I’m not getting it. Did not have this issue on the single din Sony stereo I’m using in my other truck
    thanks in advance
    pinktaco808 likes this.
  2. Mar 16, 2023 at 4:30 PM
    pinktaco808
    pinktaco808 Hot Steppa
    Just run one rca to sub amp and get a y splitter to connect to amp
    TheDamaso[OP] likes this.
  3. Mar 16, 2023 at 5:08 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    It only has one output. But the hideaway only needs one input. Connect either blue or grey and you’ll be all set
  4. Mar 16, 2023 at 5:08 PM
    TheDamaso
    Damaso
    Baytown TX
    hmmm could I get another run down of this? I don’t have an amp; the sub is connecting straight to the head unit.
    4 wires come out of my sub that then turn into these 2 male RCA, are u telling me to get a Y to to turn these 2 males into 1 male?
  5. Mar 16, 2023 at 5:10 PM
    TheDamaso
    Damaso
    Baytown TX
    Ok! So kinda wild since 4 wire come out the kicker to turn into these 2 but now I only need one? Lol
    But ok that’s how it’s set up now; the grey one is plugged In there but still I’m getting no signal to the sub (yes it’s on) is there any setting on the head unit I should be looking into if that’s really all I need to plug in?
  6. Mar 16, 2023 at 5:10 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Subwoofer amps are monoblock, meaning 1 channel.
    the left and right inputs are tied together inside the amp.
    the only reason they give you 2 inputs is because if you’re using high level inputs, the left and the right channels occasional play different audio
    but that Sony ties the channels together to create one sub output, so you’re all good with just one RCA connected. No need for splitters
    soundman98 likes this.
  7. Mar 16, 2023 at 5:15 PM
    TheDamaso
    Damaso
    Baytown TX
    Ok, so sub is good then, it’s a setting issue. Not sure what I’m doing do I’m just gonna click everything lol or I’m about to rip it out and plug into my other truck that’s settup for the 8 inch one and see if it works like that
  8. Mar 16, 2023 at 5:18 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Make sure sub is turned on in the radio. Some units come off by default
    also make sure crossover is set right if it can be changed
    make sure sub is getting power, lights are coming on, etc.
  9. Mar 16, 2023 at 5:23 PM
    TheDamaso
    Damaso
    Baytown TX
    Ok! So sub has power and the light turns on like it’s supposed to. I found the sub on button on the stereo but nothin happens but could u tell me what the crossovers should be set at? It gives me 2 to mess with
  10. Mar 16, 2023 at 5:33 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Normally don’t gives awful crossover settings. Set the low pass at 80 and phase as normal, unless something just sounds off. Then try reverse
  11. Mar 16, 2023 at 5:33 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Also, if there’s is a switch on the sub for hi or low, make sure it’s on low
  12. Mar 16, 2023 at 5:35 PM
    TheDamaso
    Damaso
    Baytown TX
    Low pass at 80, phase normal, set sub to low pass; got it. Let me go see if it does anything, but wait what about the high pass setting?
  13. Mar 16, 2023 at 5:40 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Also 80, but that’s for your door speakers
  14. Mar 16, 2023 at 5:47 PM
    TheDamaso
    Damaso
    Baytown TX
    Ok, needed that too since I was messing with both of them lol might just hit reset on the whole stereo
  15. Mar 16, 2023 at 5:51 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Have a 3.5 to rca adapter? You can try hooking it up to your phone. That will tell you if it’s the radio or the sub
  16. Mar 16, 2023 at 6:34 PM
    TheDamaso
    Damaso
    Baytown TX
    Update: I got it. Sooooo it was absolutely user error. On the Sony i found the Sub on button but I pressed the button till it says “on” but it wasn’t displaying the condition of the output, it was more of a press on to turn on lol press off to turn off. So yeah, user error, it’s going
