Keys left in overnight / dead battery / what now?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by a.s., Jun 27, 2016.
  1. Jun 27, 2016 at 3:39 AM
    a.s.
    a.s. [OP] Well-Known Member
    Stack
    NY
    Silver '07 DCSB Sport
    KO2s/5100s/Eibachs/TRD
    Quick help...
    After a long and exhausting day at the beach I completely spaced and left my keys in the f%$@# ignition. The truck wasn't running, I simple turned the power on to close the windows. Ran back inside and left the keys in the ignition in the "on" postion. Now the truck won't start.:facepalm:
    So my question: Do I need a new battery or can I get a jump from my wife and be totally fine? There is still some juice - I can open the windows - but that's it.
  2. Jun 27, 2016 at 3:42 AM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Jump it and let is run a bit, to charge itself up.
    a.s.[OP], Markcal and Large like this.
  3. Jun 27, 2016 at 3:43 AM
    Stormtrooper_08
    Stormtrooper_08 If two wrongs dont make a right, try three
    Orlando, FL
    White '08 TRD Sport Prerunner SR5
    4" Maxtrac spindle lift, adjustable bilsteins up front set at 1.75", 2" blocks and pro comp aals in the rear. 33" Cooper STT Pros.
    Just get a jump to start it. Let it run for about 10-15 minutes then turn it off. Try and start it again, if it works your battery should be fine, if not take it to autozone or advance and have them test the battery
    a.s.[OP] likes this.
  4. Jun 27, 2016 at 3:43 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Jump it and go! If it was a good battery before it ran down, it should recover just fine. Get it started and let it run a while.
    TacomaZL and a.s.[OP] like this.
  5. Jun 27, 2016 at 4:16 AM
    a.s.
    Stack
    NY
    Thanks all. It's jumped and working fine.
  6. Jun 27, 2016 at 4:33 AM
    Roneyj
    Roneyj Well-Known Member
    Chandler, AZ
    06 Tacoma/05 4Runner
    I am going to suggest charging the battery with a battery charger. The alternator in modern vehicles was not designed to charge drained batteries. Your alternator needs a 12.5v+ power supply to function properly.
    K.Ray, Toy4me and a.s.[OP] like this.
  7. Jun 27, 2016 at 4:38 AM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '18 TRD Sport MGM with ARE Cap
    In any event, a jump from the wife is always palliative.
  8. Jun 27, 2016 at 2:17 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    ^^^ That is what I was thinking.
    moondeath likes this.
  9. Jun 27, 2016 at 2:30 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    ^^ Exactly. So many people, enthusiasts included, still don't get this. Alternators charge under a load, not at idle. I read a technical article a while back that said a vehicle needs approximately 20 minutes operating under load to reach what was referred to as a "break even charge", which is the point at which the alternator has recharged what was used to start the engine.
  10. Jun 27, 2016 at 2:33 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Jump it and at least go drive it around. Otherwise, charge it and then still go drive it around some. Does no good either way to just get it running as was stated. Start it, idle it, leave it sit overnight and possibly have to do it again in the morning.
  11. Jun 27, 2016 at 4:53 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    I'm not totally sold on this. It takes me 4-5 minutes to drive to work and I only ever drive longer than 20 minutes once in a blue moon and I've never had an issue with a dead battery. Not tryin to start problems just stating my experience :notsure:
  12. Jun 27, 2016 at 5:26 PM
    Toy4me
    Tom
    NNJ
    I've experienced the same. I'll take a guess and say maybe most batteries live in these conditions and are usually operating close to the edge? This could explain why batteries tend to go dead so quickly after about five years? I had the same battery life experience in my Durango which I'd purchased new, about five years, then dead without much warning. My '05 Viper still has the original battery, but it is always on a charger.
  13. Jun 27, 2016 at 5:30 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    in an emergency, like sitting at the beach..jump start it and go. your alternator wont love it, but should survive. i wouldnt to it often.
    if the vehicle is at home, dead. charge it up with a trickle charger. your alternator will appreciate it.
    Toy4me likes this.
  14. Jun 28, 2016 at 5:39 AM
    a.s.
    Stack
    NY
    Well 48 hours later still no issues. I jumped it, let it run about 20 minutes, shut it off, got the kids dressed, started it right up, went to breakfast ... this morning the truck started right up again. :burnrubber: Battery is only 2 years old. On my next oil change I'll have them test the battery to be safe.
    :hattip:
    Stormtrooper_08 likes this.
  15. Jun 28, 2016 at 8:19 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I'll just go with...............I have a garaged car that gets driven only in fair weather and barely enough to keep it alive. There are times I went too long (month or 2?) without driving it and the battery would be just shy of having enough juice to crank and I would put charger on it and start it right up. Now if I just let it idle for 20 minutes or so even revving it like I was driving it, the battery would be back dead within a couple of days if I didn't actually drive it. But if I did drive it around 10-20 miles or so then it'll make it for 2-3 weeks and still start up without issue. My take is that it is better longterm for charging the battery if you actually go drive it around rather than just letting it sit and idle for awhile.
