Keyless entry?
Discussion in '1st Gen. Tacomas (1995-2004)' started by NeutrikKnight, Feb 7, 2017.
Thread Status:
Not open for further replies.
  1. Feb 7, 2017 at 11:33 AM
    NeutrikKnight
    NeutrikKnight [OP] High pass everything.
    Logan
    Pensacola
    1998 Green Tacoma TRD
    Lift kit, aftermarket wheels.
    Hey everyone, new member here. I love my '98 tacoma, it was my first car and it's still my daily driver. I bought her used for $2,000 with 160,000 miles and she's treated me like a king ever since.
    That being said, I don't know much about this truck. I've recently done some work on it myself.
    (new alternator, master cylinder, brake lines, drums and rotors, pads and shoes, about to replace cv axles) I can't find any information on if this truck has keyless entry, the keys I got with the truck were duplicates, probably made at home depot. There was no radio fob to speak of.
    Is there a way for me to tell if this truck has keyless entry, and if so, where I can get a new fob?
  2. Feb 7, 2017 at 11:50 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    If you have stickers on the window that say "toyota security", or a black button (where the optional button things are to the left of he turn stalk) that says "security" and has a little speaker looking thing below it, you have keyless entry. If you remove the driver side kick panel and there's a black box behind it (will say rs3000) you have keyless entry.
  3. Feb 7, 2017 at 12:07 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I'm willing to bet if you have power locks, you probably at least can "hack" a keyless entry. I remember reading somewhere that most manufacturers don't actually use different wiring harnesses/equipment for the different option packages (for the most part). It's apparently cheaper for all the vehicles to be basically the same because it's easier to manufacture them on the line that way. You're basically just paying for the factory to "enable" those options.
    Things like the factory "alarm" is just disabled, and you can hack it to get the security system minus the glass break sensor (and that you can probably add, too).
    But yeah, under the kick panel you should have a black box with rs3000 as vasinvictor said.
  4. Mar 5, 2017 at 3:45 AM
    wilrun4fun
    wilrun4fun Well-Known Member
    Andy
    North Central Kansas
    2000 Tundra Limited, 4x4, access cab, 4.7L, auto
    I also just picked up my 97 and it appears to have keyless but no fobs. I also found an aftermarket remote start unit under the dash that has been disconnected.
    How does one program these fobs if I grab one on eBay?
  5. Mar 5, 2017 at 10:10 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Remove your kick panel on the drivers side, if there's a black box that says rs3000 or rs3200 you have keyless entry, if not there's a audiovox aa-925 on eBay right now, that's what I run and it works great.
  6. Mar 5, 2017 at 10:11 AM
    NeutrikKnight
    Logan
    Pensacola
  7. Mar 5, 2017 at 12:58 PM
    95Taco80
    95Taco80 Blue is the fastest
    Wayland, ma
    1995 v6 4wd lx
    You can retrofit keyless pretty easily - if you've ever done car stereo, it's similar wiring.
    Kits on eBay and other internet sources.
    Might be a cheaper route than trying to hit up the dealer for a fob.
Thread Status:
