Keyless entry antenna location (2nd gen)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whitetaco97, Jun 22, 2017.
  1. Jun 22, 2017 at 7:07 AM
    whitetaco97
    whitetaco97 [OP] Well-Known Member
    Tyger
    2017 White TRD sport
    Okay, so I've read all over and can't seem to find a straight up answer. My keyless entry range is like 5 feet. I've changed the remote battery and nothing. Any idea where the keyless entry antenna is located so I can either relocate it or lengthen it? Thanks in advance!
  2. Jun 22, 2017 at 8:10 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  3. Jun 22, 2017 at 8:15 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    It would seem the antenna is internal within the receiver unit, likely a "coil" on the unit's PCB like bluetooth and other contemporary RF control stuff. The receiver is in the cabin, above the glove box:
  4. Jun 22, 2017 at 8:38 AM
    whitetaco97
    Tyger
    I will check it out. Thanks!
  5. Jun 22, 2017 at 8:41 AM
    whitetaco97
    Tyger
    Any ideas on why may range would be bad?
  6. Jun 22, 2017 at 8:42 AM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    White box above and behind the glove box, it's mounted to a metal bracket.
  7. Jun 22, 2017 at 8:43 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    Something's strange about that. My 2011 has much better range than that. I think I can get about 200 ft.
  8. Jun 22, 2017 at 8:44 AM
    whitetaco97
    Tyger
    Mine use to be good as well. Then it all of a sudden was only a couple feet. Not sure what happened.
  9. Jun 22, 2017 at 8:45 AM
    js312
    Joe
    New England
    Do both remotes do the same thing? That would narrow it down to a remote issue or a truck issue.
  10. Jun 22, 2017 at 9:37 AM
    whitetaco97
    Tyger
    I lost my other remote. Lol it does work better when I put it to my chin
