Key stuck in ignition
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 757southpaw, Nov 11, 2010.
  1. Nov 11, 2010 at 12:37 PM
    757southpaw
    757southpaw [OP] Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    So over the past couple days my key has been hanging up in the ACC position of the ignition makeing it a struggle to take out. I squirted some WD40 and it seemed to work but now it is stuck and doesn't want to come out! It sticks with my extra key as well! Any suggestions on how to remedy this issue? Thanks in advance!!
  2. Nov 11, 2010 at 12:44 PM
    jjones
    jjones Well-Known Member
    Nor Cal
    05 Tacoma Lng BD
    I know on my old 4Runner and other cars i have had in the past the key can stick based on the steering column being in a bad angle. If you shake the steering wheel it will let the key free. I haven't had this problem in my tacoma but in the 4runner when it would happen i would crank the wheel all the way to the end with some force or set the column up or down and the key would turn freely.
    Not a fix but should get the key out if your in a bind.
  3. Nov 11, 2010 at 12:53 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    ^ this. Your steering wheel lock is probably catching it. Turn the wheel slightly while trying to turn the key to the off position.
    knottyrope likes this.
  4. Nov 11, 2010 at 1:03 PM
    Pyro
    Pyro Well-Known Member
    Jon
    Tehachapi, CA
    14' Tacoma TRD Offroad
    Bilstein 5100
    Ive had that happen a few times in my 01' Taco. The solution for me was to put the truck from Park to Drive, then Immediately put it from Drive to park, and It popped right out. You dont even have to have the truck turned on, Just make sure you have the truck with the electricity on right before the ignition spot.
  5. Nov 11, 2010 at 1:15 PM
    757southpaw
    Jay
    757
    I don't know guys! Just went out to try all the above and she came rite out like it's supposed to :frusty:
  6. Nov 11, 2010 at 3:08 PM
    757southpaw
    Jay
    757
    That is without all the recomendations! Anymore ideas?
  7. Nov 11, 2010 at 3:28 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    This... Happened to me and left me in a parking lot for 30 min trying to figure it out.
  8. Nov 11, 2010 at 3:37 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Try some KY. :)
  9. Nov 11, 2010 at 3:39 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Once at the dealer the attendant pulled the truck up ... sat there for a bit and then came in to the counter with the paperwork minus keys. He said "they're stuck."
    I went out, turned the wheel to the left a bit and removed the key.
    He looked at me as if I had performed some sort of miracle.
  10. Nov 11, 2010 at 3:40 PM
    KCin HBCA
    KCin HBCA 2020 TRD Sport 4x4
    Keith
    Huntington Beach
    2020 Dbl Cab TRD Sport 4x4
    Sun spots? The electromagnetic energy the put out might cause this phenomenon...
  11. Nov 11, 2010 at 6:42 PM
    757southpaw
    Jay
    757
    Are you still having the problem or has turning the wheel to the left cured the problem?
    After I try lithum grease and only b/c I don't have KY on hand :p JK
    Turning the wheel to the left or right doesn't work for me! Cute story however :)
    :confused:What's putting out the electromagnetic energy:confused:
    Just got back in from wrestling with it again! Of all the things that could FAIL, why this :notsure:
  12. Nov 11, 2010 at 7:02 PM
    720 Member
    Tennessee
    1988 Toyota Truck 4x4 V6 manual (reg cab)
    If this is an automatic transmission, the shift lock may not be letting you put it back in "park" all the way, which would not allow you to pull the key out. You may want to try the shift lock override.
  13. Nov 11, 2010 at 7:05 PM
    757southpaw
    Jay
    757
    It is an automatic and what is this shift lock override you speak of? :confused: I guess it's time to bust out da owner's manual :eek:
    Michal006 likes this.
  14. Nov 11, 2010 at 7:09 PM
    Cmatt1605
    Cmatt1605 Well-Known Member
    Cody
    Mount Pleasant, South Carolina
    Squeaky leaf fix
    this happens a lot with people that buy keys from us at work. if its a copy of a key then it may just be that the grooves are not worn to your lock yet, we have freshly cut keys that do that from time to time, and we kind of shimmy the key up and down with a pair of slip-joint pliers and yank at the same time. usually they will come out after a few attempts, and we just take the key after that and put it in and out of the lock very very very quickly several times to wear it down more.
    BUT if it is not a copy of a key, and you cannot get any of the suggestions that they have given you to work, open up the steering column up, and remove the ignition. try it in a vise, if that doesn't work, swing it by a locksmith. it will be cheaper to take it to them then them come to you. **the only reason i say this is because with my old mud truck i used to have i had the exact same issue and had to wind up taking it to a locksmith to get it out.***
  15. Nov 11, 2010 at 7:10 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    its aliens............:anonymous:
  16. Nov 11, 2010 at 7:14 PM
    757southpaw
    Jay
    757
    Good Advice...Thanks!
    Nice Avatar detective
  17. Nov 11, 2010 at 7:19 PM
    Detective_Dan
    Colorado Springs
    thanks jay
  18. Nov 11, 2010 at 7:39 PM
    720
    720 Member
    Tennessee
    It should be in the emergency section of your owners manual under
    If the shift lever cannot be shifted from P
  19. Nov 12, 2010 at 2:09 AM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    if you do manage to get the key out try using some liquid graphite. i got some under the name lockease i think and it works great when the door locks become difficult. lasts alot longer than wd40.
  20. Nov 12, 2010 at 2:15 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    It might be that the shifter is not all the way in park. Check out the plastic on the shifter (the plastic that moves with the shifter). The plastic could be binding. This happened to me and I would shove it into park and the key would come out just fine.
