Key stuck ignition cylinder
Discussion in '1st Gen. Tacomas (1995-2004)' started by Itsawop, Jan 23, 2024.
  1. Jan 23, 2024 at 12:15 PM
    Itsawop
    Itsawop [OP] Member
    2002 Tacoma 2wd
    Good morning, I'M new here so I hope I'm in the right area. I have a 2002 Tacoma 2wd 5sd and the keys stuck in the ignition cylinder. I've seen a lot of suggestions for a automatic but nothing for a manual transmission.
    Any suggestions for that?
  2. Jan 23, 2024 at 12:19 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
  3. Jan 23, 2024 at 12:20 PM
    Xbeaus
    Beau
    or go to a locksmith and see how much they charge for a new lock cylinder. Might be able to match key but might not be able to and you'd have a different key for ignition.
  4. Jan 23, 2024 at 12:35 PM
    Glamisman
    Glamisman Well-Known Member
    To see if it is electrical or mechanical disconnect the negative battery terminal and see if you can get the key out, if you cant then it is time to pull the lock cylinder.
    beaverdamland likes this.
  5. Jan 23, 2024 at 1:53 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    It it totally locked in the cylinder (immovable) or does it turn to On or Start but just not release when off?
  6. Jan 23, 2024 at 2:04 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Squirt a very small amount of penetrating oil in the opening and then gently tap on the back of the key with a small hammer. Sometimes that helps.
    MNMLST likes this.
  7. Jan 23, 2024 at 2:10 PM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    or press something that vibrates slightly against the key… like an electric toothbrush or the back of a cordless sander.
  8. Jan 23, 2024 at 2:35 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Maybe try moving your steering wheel too? I know the steering lock shouldn't keep the key in but maybe something in that mechanism is broken.
    tanstaafl26 likes this.
  9. Jan 23, 2024 at 3:14 PM
    Itsawop
    Itsawop [OP] Member
    2002 Tacoma 2wd
    I've tried a new cylinder and it still does the same thing.
    I am lost at what to next.
  10. Jan 23, 2024 at 3:15 PM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    New key?
  11. Jan 23, 2024 at 3:17 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    Maybe do what others suggested on your original thread? Why are you creating a new thread? You have 7 replies in that thread - why create a new one?
    stonylaroux and ace_10 like this.
  12. Jan 23, 2024 at 3:31 PM
    Itsawop
    Itsawop [OP] Member
    2002 Tacoma 2wd
    Sorry, I'm new to this so bear with me please. I put in new cylinder and it came with a new key.
  13. Jan 23, 2024 at 9:22 PM
    time623
    James
    AZ
    So you put in a new lock cylinder with a new key, and again the new key is getting stuck in the new cylinder?
    By stuck do you mean actively stuck or just keeps getting stuck? Is the old key still stuck in the old cylinder? Is the new key still actively stuck in the new cylinder?
    When it is ‘stuck’ can you turn the key?
  14. Jan 24, 2024 at 5:38 AM
    Itsawop
    Itsawop [OP] Member
    2002 Tacoma 2wd
    I can start the truck and shut it off but the key will not come out of the cylinder, even if I put the new cylinder with key in.
  15. Jan 24, 2024 at 5:46 AM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    Hmmm, it’s very strange that the new cylinder is acting like the old one, did you try the cylinder to check its function before you installed it? How long have you owned this truck, did it used to function properly or did the key just all of a sudden not want to come out?
  16. Jan 24, 2024 at 5:48 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Maybe the electrical portion of the switch is keeping the lock cyl from turning all the way back to the first position? Try removing the electrical part of the switch and see if the key turns easier
  17. Jan 24, 2024 at 8:10 AM
    Itsawop
    Itsawop [OP] Member
    2002 Tacoma 2wd
    The key worked perfectly and then I came home and went to shut off the truck and it shut off but the key wouldn't come out.
    I'll try to remove the electrical part and see if it works then.
    Thanks again for all your help.
  18. Jan 24, 2024 at 9:09 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Hmmmm
    If you have RR’d ign cylinder, with key
    And having same issue,
    Need to look deeper
    Like the next adjacent part that touches the new cylinder…..
    Column
    oldtimertoyota likes this.
  19. Jan 24, 2024 at 10:13 PM
    beaverdamland
    beaverdamland Well-Known Member
    97 Xtracab MT 3.4
    What happened when you tried with battery disconnected?
  20. Jan 24, 2024 at 11:08 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    As already stated above try wiggling the steering wheel left and right while trying to remove the key. Pretty common to have it jam up if your wheels are turned in one direction and key won’t come out to turn it in the other to free it.
