Key in ignition chime disable, 2013
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Clearwater Bill, May 1, 2017.
  1. May 1, 2017 at 7:48 AM
    Clearwater Bill
    Clearwater Bill [OP] Never answer an anonymous letter
    Billy
    Largo Florida
    Inspired by this thread from @PB FAB, I decided to see if my '13 had something similar enough to work the same way.
    So I popped open the cover, and low and behold, there was a similar looking attachment to my ignition. I noticed the wires running into it were on their own 'plug'. So I removed that instead of the disassembly method @PB FAB used.
    Success. No more dinging!
    Photos show the fixture that's mounted on the tumbler case, and the wires running into the bottom. Next photo shows that unplugged. All I did was tuck the plug over and button it all back up. Completely reversible if you wanted to.
    Of course I have no idea what 'all' 2nd gens look like, but if the chime annoys you, it's literally a 10 minute (or less) fix.
    KTM753, tomwil, BassAckwards and 3 others like this.
  2. May 1, 2017 at 7:57 AM
    TK7692
    TK7692 Camo on Camo
    TK
    South Bay, CA
    2015 MGM DCLB TRD Sport 4x4
    Not an overbrander.
    I've done this as well. It will prevent the truck from knowing when the driver side door is open, so you will no longer be able to turn the key fob beep on/off. I solve that by just ripping out the buzzer in the engine bay.
  3. May 1, 2017 at 10:37 AM
    2015TRD
    2015TRD Well-Known Member
    Arkansas
    TRD Sport
    [QUOTE="So I popped open the cover \[/QUOTE]
    How did you do this?
  4. May 1, 2017 at 10:41 AM
    TK7692
    TK7692 Camo on Camo
    TK
    South Bay, CA
    Not an overbrander.
    There are two screws that are behind the steering wheel. Rotate your steering wheel to reveal and remove them. Then you'll be able pop the bottom half of the cover off. It's tricky but you basically pull it out and down.
  5. May 1, 2017 at 10:52 AM
    2015TRD
    Arkansas
    TRD Sport
    Thanks!
    TK7692[QUOTED] likes this.
  6. May 1, 2017 at 12:12 PM
    Clearwater Bill
    Billy
    Largo Florida
    Not sure about that. :notsure: The 'door open' on the dash still illuminates. But of course it does do that with or w/o the key in place anyway.
    Haven't tried/not worried about that. On our '12+ models that's a techstream chore anyway, right?
    If I don't want it to beep when I unlock the door, I just use the key. :D
  7. May 1, 2017 at 12:47 PM
    TK7692
    TK7692 Camo on Camo
    TK
    South Bay, CA
    Not an overbrander.
    I stand corrected. I remembered that my dome light does still come on when I open the door. So it's another factor that affects the keyfob beep mod then. I think it disables the ignition's knowledge of the door being open.
  8. May 3, 2017 at 8:11 PM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    Excellent, i fumbled around with that plug and couldn't get it to release, I pulled mine apart on a job site and found the tab and was able to unplug the wire harness on the 17.
    Clearwater Bill[OP] likes this.
  9. May 4, 2017 at 4:21 AM
    Clearwater Bill
    Billy
    Largo Florida
    You might want to edit your thread to show the change in method?
    tomwil likes this.
  10. Jan 9, 2019 at 5:47 AM
    KTM753
    KTM753 Well-Known Member
    Thanks for this post! My 2nd most favorite mod to my Tacoma. Super easy too. The release tab for this plug is on the right side. Just press down with your finger and gently pull down on the plug.
  11. Jan 9, 2019 at 7:43 AM
    Clearwater Bill
    Billy
    Largo Florida
  12. Jan 9, 2019 at 7:50 AM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    just for an "FYI" if you do this mod, you will not be able to program a new key. i found out that when my key was so worn out it would not "beep" when in the ignition. so just make sure to plug it back in before programming a new key.
    KTM753 likes this.
  13. Jun 27, 2020 at 10:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    Not really sure what you are trying to say here. The 'key in' chime has nothing to do with the airbags. At all.
    The method I posted does not impact the door ajar feature, nor does it impact the dome lights.
    As far as the seat belt goes, mine still chimes, but that's not what this thread was about.
    jrlockman and Muddinfun like this.
  14. Jul 21, 2020 at 10:42 AM
    jrlockman
    jrlockman Well-Known Member
    2011 White Double Cab TRD Sport
    None yet
    I recently did this on my 2011 DC, but now I am noticed that there is a flashing light on the dash all the time, even when I shut the doors and lock the truck... Photo below, anyone know that this means? Is this bad, seems like it could wear the battery out by continually blinking...
  15. Jul 21, 2020 at 11:36 AM
    Clearwater Bill
    Billy
    Largo Florida
    But it quits when the key is in the ignition, correct?
    Pg 77 of your owners manual says............
    The indicator light flashes after the key has been removed from the engine switch to indicate that the system is operating.The indicator light stops flashing after the registered key has been inserted into the engine switch to indicate that the system has been canceled
    Based on that, it should have been flashing all along under the conditions you describe.
    Don't have an owner's manual? Here are the PDFs of all of them for 2011.
