Key Fob won't unlock/lock the doors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ttacoma2017, Jul 8, 2020.
  1. Jul 8, 2020 at 4:50 PM
    ttacoma2017
    ttacoma2017 [OP] Member
    2017 XSP tacoma SR5
    Hello i just bought a 2017 tacoma this week and the key fob is not locking or unlocking the doors when you press the button. i brought it to the dealership and they replaced the battery in the key fob (still wouldn't work) and then they tried programming a completely brand new key (still wouldn't work). the key turns in the ignition just fine, the car runs like normal but when you click the lock/unlock button, nothing happens. they spent about an hour trying to program both the used key and the new key at the dealership but ultimately said they couldn't figure out what the issue was and that i would need to bring it back at a later date so they can analyze it more closely. Has anybody had this issue before? i'm guessing it's something with the computer?
    the manual key that sticks out of the key fob works fine when you unlock/lock the car manually so i don't think its an issue with the physical locks
  2. Jul 10, 2020 at 10:03 PM
    EnriqueG_s550
    EnriqueG_s550 Well-Known Member
    Enrique
    2018 Tacoma TRD OffRoad 4x4 in Cement color!
    Thats odd
  3. Jul 10, 2020 at 10:11 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Potential electrical interference (like a dealer installed GPS tracker that can mess up wiring), or possibly a blown fuse.
  4. Jul 10, 2020 at 10:28 PM
    tcjacado
    tcjacado Well-Known Member
    Good luck on padding that post count;)
    grogorat likes this.
  5. Jul 13, 2021 at 8:42 PM
    ere109
    ere109 Active Member
    Denver
    2016 Blue Tacoma TRD Offroad, Manual Trans
    Did you find a solution for this? My 2016 just started exhibiting weird key fob behavior: the fob will lock but not unlock. Sometimes, if I press lock first, I can then get unlock to work, but it's sporadic. I tried my (never used) spare with similar results. I'll replace the batteries, next, but have seen enough key fob posts to be concerned.
  6. Jul 13, 2021 at 8:45 PM
    ere109
    Denver
  7. Jul 13, 2021 at 9:55 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    i don't think he is really trying hard because only 55 post from 2018.
    but this one is (odd)
    Synergy001 likes this.
  8. Jul 13, 2021 at 10:13 PM
    Bertlow
    Bertlow Well-Known Member
    Alberto
    Tocoma
    Try a new battery
  9. Jul 14, 2021 at 7:12 AM
    Absolut_Boost
    Absolut_Boost Well-Known Member
    Cincinnati, OH
    2021 Tacoma TRD OR DCSB Cement
    I had a similar issue with my 2016 4Runner. The little motor inside the passenger front door latch had failed and needed to be replaced. Try manually locking one door at a time and then pressing the button. For example, I would manually lock the passenger front door and then hit the button on my fob and it would work. If I didn't manually lock that door first, the fob wouldn't lock the car. Do one door at a time and if the fob works all of the sudden, that is your failed latch. The latch as a whole is expensive, but the little motor inside is only 7-8 bucks on Amazon/ebay.
  10. Jul 14, 2021 at 10:01 AM
    TRD2021SPORT
    TRD2021SPORT Well-Known Member
    2021 Tacoma TRD Sport AC
    Have you tried pushing the panic button on the remote? If that feature works at least you know the remote and computer module recognize each other. If the panic alarm button doesn't work then its time for old fashion diagnostics starting with fuses, pinched - broken wiring, etc.
    jerkwithkeyboard likes this.
  11. Jul 14, 2021 at 12:46 PM
    Taco16LB
    Taco16LB Well-Known Member
    I have has this happen 2 times on my 16 OR . This last time was after having my tires rotated and the TPMS redone for moving the tires . Afterwards , the fob would only unlock the drivers door and the rest of the door locks made a sound but did not unlock . I did the trick of holding the lock and unlock buttons for 7 secs , several times . Note that the dash will show that it has changed by showing either 1 or all four doors open . This did not fix the problem at the time . The next day all was back to normal . So ? I guess this is something that goes away on it's own lol .
