Key fob remote start stopped working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dhauck, Jan 11, 2024.
  1. Jan 11, 2024 at 4:47 PM
    dhauck
    dhauck [OP] Member
    dave
    2017 TRD Sport double cab
    Extang Trifecta tonneau cover
    I have a 2021 trd sport with push button start. The Toyota connect expired but the key fob started the truck up until a few days ago. I replaced the battery but no luck. Is there something else I'm missing to fix this issue. Thanks for any suggestions.
  2. Jan 11, 2024 at 4:55 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I would take some steel wool gently to the metal contacts where the coin battery sits to see if it helps.
  3. Jan 11, 2024 at 6:13 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Did you try your spare fob - assuming that you actually received one (COVID limited fobs to only one per vehicle).
  4. Jan 11, 2024 at 7:20 PM
    dhauck
    dhauck [OP] Member
    dave
    Yes I tried both the light flash but it doesn't start.
  5. Jan 11, 2024 at 7:27 PM
    TA2016
    Oregon
    Does you truck start by placing the Fob near the Push To Start button while pressing the Push To Start button?
  6. Jan 12, 2024 at 2:03 AM
    dhauck
    dhauck [OP] Member
    dave
    I can start my truck with the fob in my pants pocket. For over a year I've been able to start the truck from inside the house by pushing the lock button 3 times. It just recently stopped working.
  7. Jan 12, 2024 at 7:19 AM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    The only thing different is said battery you changed. Worked before,changed battery,now not working. Theres your answer. Crap chinese batterys
    TS4x4 and Ngneer like this.
  8. Jan 12, 2024 at 7:23 AM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    Pretty sure he said he changed the battery after it stopped working.
    Ngneer likes this.
  9. Jan 12, 2024 at 8:10 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    My 21 stopped remote starting itself after the first year when Toyota Connect expired. There are a few threads on this happening. Toyota disables it for no reason.
  10. Jan 12, 2024 at 9:22 AM
    dhauck
    dhauck [OP] Member
    dave
    I have tried both key fob and changed battery. It worked one day and not the next.
  11. Jan 12, 2024 at 11:51 AM
    wfo479
    NE Ohio
    2020 TRD Pro
    Then operator error in battery theory or user interface
  12. Jan 12, 2024 at 12:26 PM
    onemorecast
    onemorecast Member
    My wife's 2021 Sienna stopped working with the remote and app after 1 year. My 2023 Tacoma is a year old next month, so I expect it to stop working as well. I worked for Toyota dealer a few years ago when they decided to start making customers pay a subscription for remote connect, and at that time they told us the remote would no longer work if the customer did not buy the subscription. Before 2021 (meaning 2020 and back) I think those vehicles were coming with a 10 year trial period. I could be wrong on the year that the 1 year trial started, but I know it changed somewhere along that time frame.
  13. Jan 12, 2024 at 5:52 PM
    CT Yankee
    CT
    I never installed the Toyota Connect app. Have little use for most all apps. I've had my 21 TRD OR AC Auto since Dec 2020. Remote start using the key fob works just fine.
    Perhaps Toyota gets revenge when you do not renew your Toyota Connect app when it expires by disabling the fob remote start?
    I don't much care - I use it so rarely that I'd never miss it.
    cc: @dhauck
  14. Jan 12, 2024 at 6:08 PM
    Mr.Gea
    Mr.Gea Well-Known Member
    Gea
    Lancaster, PA
    2020 TRD Sport Cement
    My 2020 Sport still works. I tried it last week and still good.
  15. Jan 12, 2024 at 6:17 PM
    CT Yankee
    CT
    Curious question though - Did you ever install the Toyota app AND paired your phone to your truck?
    I never did (install the app).
    I wonder if there's a correlation....
  16. Jan 12, 2024 at 6:19 PM
    Mr.Gea
    Gea
    Lancaster, PA
    Yes installed and used for 1 year, just never renewed.
  17. Jan 13, 2024 at 7:31 AM
    CT Yankee
    CT
    So much for that theory.
    Maybe some have not got the <Click><Click><Click-Hold> down correctly...
  18. Jan 13, 2024 at 9:10 AM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Hmm my connect expired and mine is still working.. lock lock lock and hold
  19. Jan 13, 2024 at 10:13 AM
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2021 Tacoma TRD Off Road, 2019 Sahara
    Same here. Mine expired in November 21 and it still starts with the fob. It sounds like people are confusing remote start with the app vice remote start with the fob. It can be finicky on the timing of the button pushes.
  20. Jan 13, 2024 at 2:51 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Neither have I, but this has happened to many. Can't even fix it with techstream. I never used it because of the shut off issue when opening the door, but it's frustrating that it's a feature that disabled itself.
