key fob range?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DeeKay20, Jan 7, 2021.
  1. Jan 7, 2021 at 10:50 AM
    DeeKay20
    DeeKay20 [OP] Well-Known Member
    Danny
    Columbia MO
    2020 Tacoma DCSB TRD OR 6MT
    Dobinsons 2" lift, 33s....other stuff
    Just comparing to some of the other vehicles I've owned I'm trying to figure out if there's something wrong, or if Toyotas just have terrible range on their key fobs. I can only unlock/lock my Tacoma if I'm within like 20', this is an H-key btw.
  2. Jan 7, 2021 at 10:51 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    2500 feet
  3. Jan 7, 2021 at 10:53 AM
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    Depends on how the wind is blowing. You have a longer distance if your truck is downwind of your fob.
    Shorter upwind.
    Gravity can also play a part. You have a shorter range if your truck is up hill from you vs. it being downhill. :rasta:
  4. Jan 7, 2021 at 10:57 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Mine (H-key also) is far. Uncomfortably far at times since I sometimes worry accidentally hitting a button.
    We had a car that would only work when within arm's reach. I suppose as long as it actually works, it was fine for us?
    DeeKay20[QUOTED][OP] likes this.
  5. Jan 7, 2021 at 10:59 AM
    Mister Grey
    Mister Grey The Viking of disapproval looks in your direction
    Hayward Ca
    2017 Tacoma DCLB Sport 4x4
    The Works.
    If you hold the key fob to your body it uses your body as an amplified antenna for a little extra range.
  6. Jan 7, 2021 at 11:00 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Mine barley works from about ~4-500' with a direct line of sight. That's using my crane as a "antenna"
    DeeKay20[OP], Tacospike and tonered like this.
  7. Jan 7, 2021 at 11:05 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    500ft, huh? :D
    I'd say that yours is working normally or better.
  8. Jan 7, 2021 at 11:19 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    Mine works from a few hundred feet away in open parking lots. I have noticed something weird. When I back in to my parking spot at home tail facing the I can house I can lock/unlock from inside the house and around the corner on the side porch separate by brick walls. If i pull in to the spot, head toward the house I need line of sight either direct or from a window for it to work.
    Of course this is another good reason to back in.
    DeeKay20[OP] likes this.
  9. Jan 7, 2021 at 11:26 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Any doodads added like a dash-cam? Some have noticed a drastic reduction after install.
    Mine works fine, far enough I've never had to actually test range. I had a remote install added from dealer (just to cya, I'm sure I over paid), but their shop but handed me a key ring with two aftermarket fobs, saying they work much farther away, and the Toyota ones just don't go as far as other mfgs. My factory fob still works, so I don't even carry the extras.
  10. Jan 7, 2021 at 11:31 AM
    Tnc
    Tnc Well-Known Member
    Tim
    NE Oklahoma
    2017 DCLB TRD OR
    Mine is maybe 30’ max. Sometimes it won’t work until I’m within arms reach.
    Foushee and DeeKay20[OP] like this.
  11. Jan 7, 2021 at 11:35 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Mine has issues with Meso 3rd brake light. When then cargo lamps are on, I basically get no response from the fob. When they go out, it seems to work. Nothing I've really looked Into though
  12. Jan 7, 2021 at 11:35 AM
    Tacospike
    Two Trucks
  13. Jan 7, 2021 at 11:36 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    6,494 miles (distance from Beijing, China to Phoenix, AZ)............
    Alright, not really, though I did start my truck from Beijing (2018, pre-rona) while it was sitting at the airport in Phoenix. Was pretty cool. I have a remote start app linked to my phone.
    I never think about the range as I always keep me key in my pocket and just touch my door handle.
  14. Jan 7, 2021 at 12:10 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Shits sensitive these days. There's times on road trips, I avoid the Taco Bell, I'm afraid the alternative fuel source will throw a CEL if cabin isn't vented properly.
  15. Jan 7, 2021 at 12:14 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    VTA baybay!
    Chew[QUOTED] likes this.
  16. Jan 7, 2021 at 12:22 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    My first dash cam took out not only my key fob but my radio reception as well. I had to tear it out and put in a different camera and wire harness before that went away. :oops:
    I never really tested my range. Few hundred feet. I usually use the handle sensor though. I also dont have an H-Key. :anonymous::anonymous:
  17. Jan 7, 2021 at 12:53 PM
    Taco_mike73
    York, PA
    I have recently installed the dash cam that was in my old Liberty. I never seen any issue with it then. Now it's wired to the power outlet circuit so it's only on in the run or accessories position. It's an Auckey DR02
  18. Jan 7, 2021 at 3:29 PM
    DeeKay20
    Danny
    Columbia MO
    Seems they just kinda suck haha. Mine's Bone stock other than door speakers and a dome light.
  19. Jan 7, 2021 at 7:31 PM
    Tallgrass05
    Tallgrass05 Well-Known Member
    Checked with my 2018 DCLB when exiting work today. The key fob worked from at least 60 paces, well over 100 feet from the truck.
  20. Jan 7, 2021 at 7:41 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I've noticed it isn't that great as well, even when using my body as an antenna of sorts. Then again my last truck could be started with the fob through several concrete walls. I get 2 rows away in the parking lot and my Tacoma key won't reach.
