Key fob not working after replacing dead battery
Discussion in '3rd Gen. Tacomas (2016-2023)' started by djembefola, Apr 18, 2021.
  1. Apr 18, 2021 at 4:38 PM
    djembefola
    djembefola [OP] Well-Known Member
    2017 Black TRD OR DCSB
    Backflip MX4 Tonneau Tube Steps Pro Grill Front/Rear camera anytime 110v in Cab 400 W anytime Interior LED Hondo radio knobs Kicker Tweeters JL Audio Stealthbox JL Audio Amp Partially debadged
    My wife keeps my backup fob and tried it yesterday, but the fob battery was dead. I tested the battery with voltmeter to confirm. This fob hasn't been used in years so the battery in it has probably been dead for months.
    I replaced with a fresh CR2032 battery, but the fob still doesn't work. Tried a 2nd fresh battery and still nothing. I tested voltage on both the new batteries they are both good (3+ volts on each).
    The backup fob does, however, still start the truck when it's touching the start button. Also, the main fob still works normally.
    Google nor TW search had nothing on this. Any ideas?
  2. Apr 18, 2021 at 4:42 PM
    mhornco
    mhornco Well-Known Member
    Sometimes those coin batteries don’t make a good contact. Double check how your battery is sitting in there. I had one where it looked great but had to bend the tabs on the fob a little to get good contact. Of course also possible fob is just dead
  3. May 4, 2021 at 5:17 PM
    djembefola
    Update for anyone else this helps. I had checked the contacts and they were good.
    However, after just leaving the new battery in for a few days the fob randomly started working. I did nothing else other than letting it sit with the new battery for 3 days. Now it works like a charm. Maybe having been dead for a long time required it to have a continuous charge over time? Who knows but it works now.
  4. May 4, 2021 at 5:26 PM
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    Weird. Shouldn’t need a “charge”. But glad it works!
  5. May 4, 2021 at 5:39 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Maybe this? From the manual, page 124.
    Battery-saving function
    The battery-saving function will be activated in order to prevent the electronic key battery and the battery from being discharged while the vehicle is not in operation for a long time.
    • In the following situations, the smart key system may take some time to unlock the doors.
      • The electronic key has been left in an area of approximately 6 ft. (2 m) of the outside of the vehicle for 10 minutes or longer.
      • The smart key system has not been used for 5 days or longer.
    • If the smart key system has not been used for 14 days or longer, the doors cannot be unlocked at any door except the driver’s door. In this case, take hold of the driver’s door handle, or use the wireless remote control or the mechanical key, to unlock the doors.
    The system will resume operation when
    • The vehicle is locked using the door handle lock switch when carrying the electronic key on your person.
    • The vehicle is locked/unlocked using the wireless remote control. (→P. 109)
    • The vehicle is locked/unlocked using the mechanical key. (→P. 557)
    djembefola[OP] and barf like this.
