Key fob battery? What and how to start with dead battery
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lava-road, Jun 11, 2022.
  1. Jun 11, 2022 at 2:54 PM
    Lava-road
    Lava-road [OP] Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    Several videos and web sites and Amazon shows two sizes of batteries for the Tacoma 2016-2022 & 2005-2022.
    Ok the two sizes show is CR2016. & CR2032. What is the correct battery size?
    How to start your Tacoma truck with push button start? Simple place the fob on the button with the Toyota logo on the button, remove and push the start button.
  2. Jun 11, 2022 at 2:58 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    How to find out the correct size: Open the keyfob casing up, remove the battery, look at it and write down the number on it. WaaLaa. It ain't rocket science man.
  3. Jun 11, 2022 at 2:58 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I use a CR2032 in my Fob which has a higher capacity (mAh).
  4. Jun 11, 2022 at 3:01 PM
    Bravo64
    Bravo64 Well-Known Member
    William
    Orlando, FL
    2020 TRD Off-Road
    They are both 3v, the 2032 is about 1mm thicker and it will last longer.
  5. Jun 11, 2022 at 3:30 PM
    Lava-road
    2019 trd-off road
    Before I open my key fob, wouldn’ t it be smarter to know the size before you open the fob? Then purchase the battery. So I went on line to find the size.
    It was confusing , Ok maybe the CR 2016 fit as well as the CR2032 May fit. Make sense to buy the longer lasting battery.
  6. Jun 11, 2022 at 3:35 PM
    Lava-road
    2019 trd-off road
    Both CR2016 & CR2032 are the same size and can be interchangeable. Both are 3volts.
    CR2032 is just thicker .
    CR2016 90 mAh - 6 hrs
    CR2032 240 mAh - 10 hrs.
    AA, AAA,AAAA, are all different sizes, like C & D batteries.
    A lesson I learn today. Thank you.
  7. Jun 11, 2022 at 5:24 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Taint rocket surgery!
  8. Jun 11, 2022 at 5:32 PM
    Lava-road
    2019 trd-off road
    People thought I was going to be a Astronaut, because I took up SPACE in school.
    And I never became a Rocket scientist either.
    I do know what they”S” stands for - Smart “S”. Lol
  9. Jun 11, 2022 at 6:14 PM
    Coyote501
    Coyote501 Well-Known Member
    Ohio
    2019 Barc Red AC
    I literally just changed the battery in both key fobs yesterday. 2032 is what you want. They are not real hard to change, just be careful. Or you can go to AutoZone or any auto parts store and buy the batteries and have one of the guys there change it for you. 2 batteries is about $10.
  10. Jun 11, 2022 at 6:18 PM
    eurowner
    eurowner Duke Sky
    Scoty
  11. Jun 11, 2022 at 6:18 PM
    nhpoke
    nhpoke Well-Known Member
    jason
    nh
    21 DCLB OR AG
    The size of CR batteries is the numerical designation.
    A CR 2016 is 20mm in diameter and 1.6mm in thickness.
    A CR 2032 is 20mm in diameter and 3.2mm in thickness.
    A CR 1025 is 10mm in diameter and 2.5mm in thickness.
    A CR 3032 is 30mm in diameter and 3.2mm in thickness.
    A CR 2025 is 20mm in diameter and 2.5mm in thickness.
    I keep a spare battery for all of my fob operated vehicles in a plastic bag somewhere accessible to the exterior of my vehicle.
