Kenwood DDX9904S Review
Discussion in 'Audio & Video' started by surfandturf, Sep 11, 2018.
  1. Sep 11, 2018 at 7:41 PM
    surfandturf
    surfandturf [OP] Well-Known Member
    CT
    2014 TRD DCLB
    Just got this installed today. I'll have 30hrs of non stop driving coming up for a review. Right from the start I customized my home screen and setup guages to monitor the drive. The guage capability is impressive. I'll post more feedback as it develops.
    Purchased from crutchfield and I flashed the iDatalink to a 2014 TRD Sport
  2. Sep 11, 2018 at 11:47 PM
    greasegunner
    greasegunner Active Member
    Florida
    2014 sport TRD
  3. Sep 12, 2018 at 11:34 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Does it read OBD codes & erase them? Tranny temp? Nav?
  4. Sep 12, 2018 at 11:37 AM
    clemsontaco
    clemsontaco Well-Known Member
    Max
    Greenville, SC
    TRD Pro w/Wheelers Progressive AAL, BFG A/T KO2's, TRD SC
    Just installed the same setup a couple months ago. I spend a lot of time on the road and the CarPlay is great for navigation. My biggest gripe is the fit of the faceplate with the head unit itself given all of the wires behind. How is the profile of yours on the faceplate? Does it protrude at all?
    Max
  5. Sep 12, 2018 at 11:40 AM
    Aw9d
    Aw9d That one guy
    Pretty neat HU. I wan't to see if it can use the gauges with an Bluetooth OBDII scanner vs the iDatalink.
  6. Sep 12, 2018 at 11:56 AM
    surfandturf
    CT
    2014 TRD DCLB
    It can read engine code, not sure on erasing codes...yes on tranny temp. Tranny temp is my center guage...no data on them in this shot because I just assigned the guages. Have not driven yet
  7. Sep 12, 2018 at 1:29 PM
    greasegunner
    Florida
    2014 sport TRD
    How much did you drop on it? Im seeing between $400-$500
  8. Sep 12, 2018 at 1:53 PM
    surfandturf
    CT
    2014 TRD DCLB
    That's right + harnesses
  9. Sep 12, 2018 at 2:57 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    Check your firmware version(if you haven't already), there might be an update on Kenwood's website.
  10. Sep 12, 2018 at 3:15 PM
    greasegunner
    Florida
    2014 sport TRD
    Did you also have to purchase the idatalink, in addition? Or did it come with it?
  11. Sep 12, 2018 at 3:43 PM
    surfandturf
    CT
    2014 TRD DCLB
    Idatalink is an add on...visit cruthfield and you can see the additional cabling
  12. Sep 15, 2018 at 5:48 PM
    surfandturf
    CT
    2014 TRD DCLB
    After a good drive today my first thoughts are...I hate android auto! It's in conflict of other apps on yout phone, and it's not easy to turn it off when you are plugged into the head unit usb. The only benefit to android auto that I see is the ability to have a larger map on the head unit vs your phone. I'd rather just keep everything bluetooth and have full functionality.
  13. Sep 15, 2018 at 5:54 PM
    surfandturf
    CT
    2014 TRD DCLB
    What I do like is the guage data. It has intake F, which would be interesting to compare stock vs cold air intake.
    The distance to empty is not stable, it is probably because its calculating instantaneous mpg to the fuel level which can fluctuate ~5% from sloshing.
  14. Sep 15, 2018 at 6:09 PM
    surfandturf
    CT
    2014 TRD DCLB
    Going to swap out instantaneous mpg for average mpg to see it there is a difference.
    greasegunner likes this.
  15. Sep 15, 2018 at 6:53 PM
    greasegunner
    Florida
    2014 sport TRD
  16. Sep 20, 2018 at 12:00 AM
    navynuke
    navynuke Well-Known Member
    Lake Wylie, SC
    2014 TRD Off Road DC
    I just installed a Kenwood DDX9704S with the Maestro RR. For whatever reason the trans temp is not an option for me, any ideas?
  17. Sep 20, 2018 at 3:28 AM
    surfandturf
    CT
    2014 TRD DCLB
    Check each guage, it may not be available for each guage location
  18. Sep 20, 2018 at 3:35 AM
    surfandturf
    CT
    2014 TRD DCLB
    You also need the idatalink cable.
    Is there any else plugged into your ob2 port? If so you need to remove it.
  19. Sep 20, 2018 at 8:00 AM
    navynuke
    Lake Wylie, SC
    Nothing else plugged in. Almost every other gauge works just fine, Load, RPM, intake air temp.... Also the TPMS isn’t working either.
  20. Sep 20, 2018 at 10:36 AM
    surfandturf
    CT
    2014 TRD DCLB
    Tech support...
