Kenda Klever AT2 “out of round”
Discussion in 'Wheels & Tires' started by pajtrick, Jun 12, 2022.
  1. Jun 12, 2022 at 8:39 PM
    pajtrick
    pajtrick [OP] Active Member
    Ohio
    2019 Cement TRD OR DCSB
    Anyone have issues balancing Kendas? I just got a new set of Kenda Klever AT2 265-70-16s and brought them to a normal tire shop to have mounted on a new set of Method 703s. Well the tire shop (after 4 hours) is claiming each of the 4 tires is out of round and won’t balance. They basically popped them on and said good luck. It’s driving like poop now. Bringing it to the dealer on Tuesday since the tire shop also messed up my tpms sensors and one of the valve stems is sticking out really far from the tire with no casing like the other 3. At this point I think the tire shop messed up and it’s not actually the tires.
  2. Jun 20, 2022 at 10:14 AM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    I recently got the Kenda klever RTs and they balanced out just fine for me.
  3. Jun 20, 2022 at 10:18 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I thought Kenda Klever was a peeler
  4. Jun 21, 2022 at 11:32 PM
    pajtrick
    Ohio
    I had to do a road force balance to prove the tires were bad. They all rated poorly and one was a 90lb of road force. It was basically oval. About 14 days away from Simple Tire telling me if I get a refund. Likely going with a C rated tire. Maybe a Toyo, Cooper, or Falken
