Keep factory plastic bed liner, or remove and coat with Line-X ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lineback, Apr 20, 2020.
  1. Apr 20, 2020 at 8:11 PM
    Lineback
    Lineback [OP] Well-Known Member
    2013 Tacoma DoubleCab TRD
    5 x 285/65/R18 Nitto Trail Grappler mud tires on 18" XD wheels (full sized matching spare) Bilstein 5100s with 3" spacer lift Prinsu roof rack Secondary air filter mod ARB Deluxe Bull bar front bumper + ARB LED fog lights ARB Recovery point Warn 9.5xp winch with steel cable SOS Concepts angled rock sliders with kick-outs 2 x Baja Designs LP9 Pro mounted to ARB bumper AVS window vents Interior knob mods Toyota bed mat Toyota hood deflector Toyota bed cargo divider Steelcraft 33250 Rear tail light cage guards Reverse light LED mod Wet Okole seat covers WeatherTec floor mats Tail gate anti-theft mod COMMS: On-board 2 meter VHF HAM radio (Boafeng F8HP mobile) + Bluetooth integrated mic External antenna: Nagoya UT-72 Super Loading Coil 19-Inch Magnetic Mount spotter radios: 2 x Cobra ACXT1035R FLT Gear: IFAK EMT Trauma wound kit 5lb fire extinguisher
    I don't own a garage, my Taco sits outside 24/7. I do my best to keep it clean, but its a never ending chore. I am considering to remove the plastic factory bed liner, and spray the bed with LineX for long-term rust prevention, keeping the 3 factory drain holes near the cab of course. Thoughts? Good, bad, waste of money? Will the Line-X outlive the truck ?
  2. Apr 20, 2020 at 8:15 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    You’re gonna be disappointed.
    Newfiebruh, Fitz235, AdamM and 4 others like this.
  3. Apr 20, 2020 at 8:16 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    :popcorn:
    Newfiebruh and SR-71A like this.
  4. Apr 20, 2020 at 8:16 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Have you looked under the plastic bedliner yet? Mine had a hole the size of my hand from rust, which the plastic ones tend to hide.
    I would probably go with a spray in.
    EDIT: Nevermind. I forget things.
  5. Apr 20, 2020 at 8:17 PM
    Lineback
    Nope, have not removed and inspected yet. It could be lined with 24k gold.
  6. Apr 20, 2020 at 8:18 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    I’m new to the 2nd gen world, so someone correct me if I’m wrong, but I believe all of the 2nd gen beds are plastic or poly carbonate with metal bed sides bolted on. That’s the way my ‘15 is anyways.
  7. Apr 20, 2020 at 8:19 PM
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
    Yeah........... That's the bed
    SR-71A likes this.
  8. Apr 20, 2020 at 8:20 PM
    Sasquatch3153
    Josh
    Illinois
    2010 ACLB OR
    Bed side is metal the bed itself is plastic
  9. Apr 20, 2020 at 8:21 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    OP seems to have a 2nd gen which have a composite bed. They are not like the 1st gen with a plastic liner over a steel bed.
    ericvega likes this.
  10. Apr 20, 2020 at 8:21 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Your bed should be composite pladtics. I could be wrong but dont think you have a liner. That is the bed. There is no metal underneath.
  11. Apr 20, 2020 at 8:22 PM
    Lineback
  12. Apr 20, 2020 at 8:22 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Gen 2 (and Gen 3) Tacoma beds are made from SMC (sheet molding compound), a composite of glass fiber and unsaturated polyester resin. It ain't gonna corrode, and there's no need, or really logic, around a drop-in or spray-on bedliner. The exterior panels are steel, of course.
    A lot of folks will have the Toyota accessory bed mat, which as a "stickier" rubber keeps stuff from sliding around.
  13. Apr 20, 2020 at 8:22 PM
    0xDEADBEEF
    Oooh. Good point. Thats what i get for wandering around.
    Hobbs and ToyotaDriver like this.
  14. Apr 20, 2020 at 8:26 PM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
    yea composite bed. if you want more "grip" in it, i rolled on some leftover bedliner (rhino liner) onto the ridges. it lasted 5 or so years and did the job well. cheap and effective.
  15. Apr 20, 2020 at 8:36 PM
    Lineback
    Well since I got yer attention... if money was no object, and I wanted to protect my Taco forever. What else would you coat with Line-X ? I thought about an entire body spray job. kinky
  16. Apr 20, 2020 at 8:39 PM
    jpneely
    Charleston, SC
    depends where you live. in the salt belt, its tough on metal no matter what, but a fluid film would be best on frame parts. you dont want to linex over bolts and such on the underside... ill let people that live there help more on that. protect it forever by just doing general maintenance and not neglecting it.
    Lineback[QUOTED][OP] likes this.
  17. Apr 21, 2020 at 4:24 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I’m a bit confused. There is no plastic bed liner to remove. That plastic is your bed, not a liner.
    EdgemanVA likes this.
  18. Apr 21, 2020 at 9:12 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    @kuffer14 is that you? Have you come back to us? (Search Kuffer14 if you don't know what I'm referring to. Legendary.)
