Keep blowing 20 amp efi fuse.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Aw3263, Nov 14, 2019.
  1. Nov 14, 2019 at 8:10 AM
    Aw3263
    Aw3263 [OP] Member
    Aaron
    2002 2.7 Tacoma.
    Led headlight bulbs.
    I’ve checked everything I possibly could. Keep blowing efi fuse and it is as soon as I turn the key. Any ideas?
  2. Nov 14, 2019 at 9:02 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You obviously haven't checked "everything you possibly could" if the problem still persists.
    I would download a wiring diagram for the EFI system (google). Start at one end and go to the other. You've got a short somewhere.
  3. Nov 14, 2019 at 9:08 AM
    Aw3263
    Aw3263 [OP] Member
    Aaron
    2002 2.7 Tacoma.
    Think the relay could be bad that is under the kick panel?
  4. Nov 14, 2019 at 10:39 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Anything is possible .
    Relays seldom short the coil opens or the contacts burn fast or wear out
    I would look for physical damage to the wire harness Rodent damage.
    Aw3263[OP] likes this.
  5. Nov 14, 2019 at 10:43 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Can you give us a rundown of everything you've done recently? This will help us to know where problem areas might be.
    Did you remove the stereo and verify those connections and wires are protected correctly? Stereo install is only thing you've done lately? If you did not use a plug and play harness and you cut and reconnected wires, there is likely an issue with that
  6. Nov 14, 2019 at 10:59 AM
    Aw3263
    Aw3263 [OP] Member
    Aaron
    2002 2.7 Tacoma.
    Well the fuse is not breaking on acc so that tells me it rules out the stereo. It only blows on the on position.
  7. Nov 14, 2019 at 11:15 AM
    cruiserguy
    Elijah
    SEKS
    That may rule out the stereo itself, but not a hack wiring job behind it. I'll peace out, I won't waste your time or mine
    Bivouac and Wyoming09 like this.
  8. Nov 14, 2019 at 11:22 AM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Find out what circuits use same fuse and go from there .Can disconnect thing in circuit to try eliminating circuits. Example my 05 rav for 10amp gauge fuse affected ac power windows cooling fans charging system .
  9. Nov 14, 2019 at 11:23 AM
    Aw3263
    Aw3263 [OP] Member
    Aaron
    2002 2.7 Tacoma.
    okay? Sorry dude. I checked all the wires that were l wired into the radio harness. Iv got my whole dash apart right now lol cannot find any wires just yet. Waiting on a friend to get here to use his probe meter to find the short. Thank you for your help anyways.
    cruiserguy likes this.
  10. Nov 14, 2019 at 11:43 AM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Problem happened right after radio install ? Any ways try checking o2 wires see if shorted .Some had problems with shorts on o2 harness blowing fuses . Easy visual while waiting for your friend .
  11. Nov 14, 2019 at 12:39 PM
    Aw3263
    Aw3263 [OP] Member
    Aaron
    2002 2.7 Tacoma.
    Yeah that was the first thing I did even took them off to try to start.
  12. Nov 14, 2019 at 12:54 PM
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    I had a similar issue, mine was the 15amp EFI? It was a wire being grounded. It took me awhile to find the issue. It was also in an area I looked multiple times. So even looking “everywhere” you can still miss it.
    Already taped up...
    cruiserguy and Aw3263[OP] like this.
  13. Nov 14, 2019 at 1:26 PM
    Aw3263
    Aw3263 [OP] Member
    Aaron
    2002 2.7 Tacoma.
    Is that on the passenger side?
  14. Nov 14, 2019 at 5:11 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Yes, please explain exactly where this is. I have a buddy with a 3rd Gen 4runner with the same exact problem. We were 4wheeling in Death Valley and this problem ended his trip. Would love to find out he's have the same issue and this will fix his problem.
  15. Nov 14, 2019 at 5:31 PM
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    This is on the passenger side lower part of the console. The wires you see there is going to the shifter. Because of the short, none of my power windows would work and I had to use the shifter release tab to take it out of park. However the truck was still drive able and everything else was functional. The fuse would break every time I turn the key to the first click (ACC). It was cause by the wires getting pinched between the plastic cover and that metal bracket, has a burn mark in the photo. Eventually the edge of the metal bracket rubbed off the wire insulation and expose the wired. I would look around places where wires are close to metal brackets and see if one is grounding itself.
  16. Nov 14, 2019 at 5:51 PM
    Timmah!
    TIM
    Hmmm, this is different than my buddy's problem. He doesn't have any other associated issues with his fuse blowing as far as I know. But, he has a wire somewhere that's grounding out and he has yet been able to find it. His problem is also intermittent. He can drive for a long time and have no issues. Then, out of the blue, the fuse will pop again leaving him stranded.
  17. Nov 14, 2019 at 6:04 PM
    cruiserguy
    Elijah
    SEKS
    Any consistencies at all that he's noticed? If it's truly completely random....... Good luck man. There's gotta be something
  18. Nov 14, 2019 at 6:08 PM
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    That sounds like a nightmare. At least my problem was instant (easier to diagnose) and the truck drove without problem. Worst case is take it to the dealer and have them chase all the wiring. I’m sure they have the equipment to find the short, if there is one.
    Is he able to put in another fuse and drive or does it take time for the problem to reset?
    Keep us updated so we know for further reference.
    Electrical problems are a pain to diagnose.
  19. Nov 14, 2019 at 7:15 PM
    Timmah!
    TIM
    Sometimes he can put in another fuse right away and he's good to go for a while. Other times it keeps blowing fuses over and over again like it did in Death Valley.
    Taking it to a dealer to diagnose could be very costly with the labor rates in California. My local dealer charges $200/hour.
    If my buddy finally figures it out, I'll respond back to this thread let you guys know what it was.
  20. Nov 14, 2019 at 7:32 PM
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    Do you have a multimeter, and a wiring diagram for your truck?
    Cause if not, you’re going to be pushing a rope. You need to be able to trace the circuit, in diagram and physically, and see every wire and every component that sits on that fuse. That is the only way.
    I had an issue with an engine cutting out years ago in a Miata. Wasn’t blowing fuses, didn’t affect the chassis electrical, just the engine would momentarily shut down then fire back up intermittently. Long story short, one of the cam position sensor wires was grounding, it would freak out the ECU.
