KC lights to Tacoma OEM switch wiring
Discussion in 'Lighting' started by BillBrasky123, Jun 30, 2019.
  1. Jun 30, 2019 at 11:33 AM
    BillBrasky123
    BillBrasky123 [OP] Well-Known Member
    Wiring KC lights to the switch posted below:
    Anyone have a wiring diagram? I have searched online and have found conflicting opinions.
    On the KC you have 3 wires (black ground, white, and greenish? )
    And the Tacoma switch 4.
    Anyone done this before? It’s been a long time since I wired up lights.
    Thanks
  2. Jun 30, 2019 at 9:28 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    if i remember right, the white is the supply line and the green is to the relay. so wire it up the same as the pic above and add in a pos for the dash light. or wire it to the supply and it will be on when the car is on (if you wire it that way)
  3. Jun 30, 2019 at 9:32 PM
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    What are you using them for?
