KC | 3rd Gen Tacoma Ditch Light Packages - Mounts and Lights - *NEW*
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taylor@KC HiLiTES, Aug 14, 2018.
  1. Aug 14, 2018 at 11:56 AM
    Taylor@KC HiLiTES
    Taylor@KC HiLiTES [OP] Well-Known Member Vendor
    Taylor
    Arizona
    2010 DCSB TRD OR 4x4
    See build thread
    We are very excited to announce that we are now offering a complete, out-of-the-box solution for ditch/pillar lights for 2016-2018 Toyota Tacomas! These will be full packages and will have everything you need, including the easy to install bolt-on/no-drill mounts, a huge variety of lights to fit your budget and need, and all the hardware and wiring you need. Our goal with this was to create solutions for everyone that takes the guesswork out of piecing together parts from various vendors. You can choose from a variety of lights and beam patterns to give you greater visibility out of your lighting at night.
    Ditch/pillar lights are a great auxiliary light for someone that is on a budget but still needs improved lighting, or for someone who already has lighting but needs more periphery fill in lights. When properly aimed, they will increase your field of view allowing you to see oncoming obstacles with enough time to properly navigate them and be fully aware.
    To see the link to these on our website, see below or click on any of the photos!
    FEATURES
    • 2016-2018 Toyota Tacoma Ditch Mount Light Bracket Set
    • Designed to Securely Mount and Attach KC LED Lights to Toyota Tacoma Cowl/Pillar/Ditch Locations
    • Utilizes OEM Hood Hinge Bolt Locations For An Easy Install
    • No Drilling or Trimming Required, Complete Bolt On Installation
    • Low Profile Construction To Provide Maximum Driver Visibility
    • Precision Bent and CNC Cut With Powder Coated Black Textured Finish
    Available LED Light Kits (see below for more info on these)
    • I know there's a ton of options here! If you get confused or need help, just ask! I'm more than happy to give my personal advice to help out.
    • KC C-Series C3 LED Spot or Flood Beam
    • KC Gravity® LED G34 SAE/ECE Driving or Wide-40 Beam
    • KC 4" LZR Round LED
    • KC FLEX™ LED Single Spot or Spread Beam
    • KC FLEX™ LED Dual Spot or Spread Beam
    • KC FLEX™ LED Quad Combo Beam
    PARTS INCLUDED
    • (2) Black Powder Coated Steel Ditch Mount Brackets for 16-18 Toyota Tacoma
    • (1) Performance Wiring Harness w/ Waterproof Connectors and LED Light Switch
    • (1) Pair of lights of your choosing
    OEM FITMENT ON TOYOTA TACOMA
    These high quality, US made brackets were specifically designed for OE 16-18 Toyota Tacoma Hood/A-Pillar locations for an easy LED light mount solution. No drilling or fabrication required, simply attach the brackets to factory bolts located along the hood and the cowl section of 2016-2018 Toyota Tacoma trucks. These ditch mount brackets allow you to securely mount various KC LED lights to your Tacoma.
    LED LIGHTING KITS THAT MEET YOUR LIGHTING NEEDS
    KC's Toyota Tacoma 16-18 C-Series C3 LED Spot Beam Ditch Mount Kit provide incredible forward distance and improved visibility when off roading. Using highly efficient Osram LEDs, KC C3 LEDs deliver 1,080 lumens of output per light, along with long lasting performance using on board thermal management for maximum cooling.
    KC C-Series C3 LED Toyota Tacoma 2016-2018 Ditch Mount Lights:
    KC's C-Series C3 LED lights use highly efficient Osram LEDs to deliver 1,080 lumens of output per light in a Spot Beam or Flood beam pattern. C3s feature a highly compact die-cast aluminum housing, aluminum core PCBs with thermal management for maximum cooling, and long lasting LED performance. Choose Spot Beam to deliver improved forward distance or Flood Beam to provide evenly distributed peripheral lighting. Either option is an affordable, high performance lighting upgrade for your Tacoma.
    KC Gravity® LED G34 Toyota Tacoma 16-18 Ditch Mount Lights:
    KC Gravity® LED G34 lights feature efficient Cree LED technology in SAE/ECE Driving Beam or Wide-40 beam patterns. Each Gravity® G34 LED uses KC's patented Gravity Reflective Diode system to strategically position LEDs inside precision engineered reflectors so that all light output is being carefully directed and aimed to deliver usable light. What you get is highly targeted light distribution, providing unparalleled clarity, performance and beam shape. Each light provides 2,300 lumens of raw led light output, in either a Driving Beam or Wide-40 Beam pattern. SAE/ECE Driving Beam G34 are ideal to improve distance directly in front your vehicle, while Wide-40 Beam deliver a wider area of coverage to improve side-side visibility for areas closer to your Tacoma.
    KC 4" LZR Round LED Toyota Tacoma 16-18 Ditch Mount Lights:
    KC 4" Round LZR LED lights feature KC's signature finned turbine die-cast aluminum housing design for maximum heat dissipation, LED performance and longevity. Using forward facing reflector optics, 4" LZR LEDs deliver an incredible 1,832 lumens of raw led light output in a highly usable off road spot beam pattern for improved forward distance and balanced off lighting visibility for your Tacoma.
    KC FLEX™ LED Toyota Tacoma 16-18 Ditch Mount Lights:
    KC FLEX™ LED Single:
    KC FLEX™ LED Single lights feature an extremely compact, durable and unique die-cast aluminum housing design. Inside each FLEX LED single lies powerful 10W Cree LEDs and precision injected reflector optics to create 975 lumens(per light) of immense forward facing LED light output. Their compact form factor makes FLEX™ LED singles perfect for A-Pillar/Ditch Mount locations on Toyota Tacoma vehicles. Choose from Spot or Spread beam pattern light kit options to deliver improved forward distance and peripheral visibility for your truck.
    KC FLEX™ LED Dual:
    KC FLEX™ LED Dual lights feature an extremely compact, durable and unique die-cast aluminum housing design. Inside each FLEX LED single lies 2 powerful, 10W Cree LEDs and precision injected reflector optics to create 1,950 lumens(per light) of immense forward facing LED light output. Their compact form factor makes FLEX™ LED singles perfect for A-Pillar/Ditch Mount locations on Toyota Tacomas. Choose from Spot or Spread beam pattern light kit options to deliver improved forward distance and peripheral visibility for your truck.
    KC FLEX™ LED Quad:
    KC FLEX™ LED Quad lights feature an extremely compact, durable and unique die-cast aluminum housing design. Each FLEX™ LED Quad delivers 3900 lumens of of raw LED light output from 4, highly efficient, 10W Cree LEDs in a combo, spot and spread beam pattern. What you get is an incredibly powerful, balanced output for improved forward distance and peripheral illumination. Their compact form factor makes FLEX™ LED Quads perfect for A-Pillar/Ditch Mount locations on Tacomas.
    JoeCOVA, SaphiraTaco and jeff b like this.
  2. Sep 10, 2018 at 10:53 AM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Here's an installed pic of these bad boys on @Leonardskeonard's truck! He opted for the G34 version.
    lpfe42 likes this.
  3. Sep 10, 2018 at 1:28 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Awesome, I noticed most aftermarket brackets did not have a hole large enough for the KC bolt.
    I had to drill mine out to fit, wish you had these earlier!
  4. Jul 6, 2019 at 7:24 PM
    lpfe42
    lpfe42 Well-Known Member
    Kenny
    Santa Barbara County
    20 DCSB CEMENT
    5100/887 Icon uca
    Have any night shots?
  5. Jul 6, 2019 at 8:07 PM
    SpeySquatch
    2016 TRD OR DCSB
    Have you guys considered a dual flood outer with spot inner combo like this? I made mine so I could swivel each independently for ditch lighting and spotting forward.
    Would love to have the KC Flex for something like this with independent swivel capabilities. Do you guys make covers for the Flex series (different color filters?) yellow would be sweeeet!
    With black filters for day driving on trails
    Black filters on aren’t blinding, but noticeable on shady trails
  6. Jul 16, 2019 at 1:26 PM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    You could actually do this yourself - it's just not something we'd stock on the shelves... we're trying to get away from custom builds as the eat up a ton of time and planning. You'd order a single Dual flex in spot, and single dual in spread, and then the bezel kit/tool so you can remove the bezel, then lens, then reflector and swap the reflectors between the two units and put em where you want! You can get a better idea of what I mean by watching this video to see where I tore apart the FLEX lights. Basically at 1 minute and then throughout the rest of the video.
    https://www.youtube.com/watch?v=Xy7eLkSangM
    SpeySquatch[QUOTED] likes this.
  7. Sep 28, 2019 at 7:57 PM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    How did you get 2 per side?
  8. Sep 28, 2019 at 7:58 PM
    grubburg
    2019 TRD OR MT
    Is there a way to put a KC bar between the grill and license plate?
  9. Sep 28, 2019 at 8:36 PM
    SpeySquatch
    2016 TRD OR DCSB
    Fabbed and rubber coated my own mounts to attach to my single CBI mounts.
    JoeCOVA and grubburg[QUOTED] like this.
