KBS Coatings Rust Seal Frame Coater Kit - Lessons Learned
Discussion in '1st Gen. Tacomas (1995-2004)' started by Quba, Nov 18, 2015.
  1. Nov 18, 2015 at 8:32 PM
    Quba
    Quba [OP] Member
    1998 Black Tacoma 4x2 Manual
    I wanted to share my experience with this product:
    https://www.kbs-coatings.com/frame-coater-kit.html#ReviewHeader
    Thanks to TJsingle26 for documenting first:
    https://www.tacomaworld.com/threads/kbs-rust-seal-review-picture-heavy.374144/
    There are some better guides out there than this write-up so do your homework.
    Acquired my first '98 Tacoma this summer (yes, it's the 2WD: workin' with what I got) and wanted to address the frame before the winter set in.
    I chose this product because it was the least expensive and seemed to have good reviews.
    Others swear by Eastwood and POR-15 products.
    This truck came to the Midwest via California a few years back so it wasn't too bad but widespread surface rust starting to set in.
    I paid $72 shipped for the 3-part quart-size frame coater kit and the package arrived in a few days.
    I had enough paint for 2.5 coats on the entire frame (I know pics are all of rear but I did the front too.)
    Prep:
    Removed the bed with the help of the neighbors.
    6 bolts fasten the bed. Consider finding replacement bolts in advance as mine were pretty rough. Had a use a 3-ft breaker from start to finish on them all. I couldn't find any suitable fits at my local hardware or chain auto parts store. I assumed they'd be easy to find. Didn't try the local Toyota dealer.
    Remove all brake light electrical cabling fasteners from the bed underside before lifting.
    I decided to go twisted wire wheel and brush as pro sandblasting seemed too expensive and the powerwasher attachment seemed like more trouble than aid.
    It cleaned up pretty nice after grinding.
    Degrease/Acid Etch:
    Found access to a Hotsy and hit it with that first then again at home with the powerwasher.
    Diluted the degreaser 5:1 in a bucket and applied with the powerwasher product intake hose.
    I applied repeatedly and had plenty left over after several applications so you can go more concentrate. I rinsed and rinsed and hit it again with the powerwasher.
    I used the provided spray bottle to apply the acid-etch / iron phosphate. I'd suggest figuring a better application method (pressurized lawn applicator?) as the spray bottle wasn't the best for hard to reach spots. I let it sit about an hour, as long as I could without letting it dry per instructions. I rinsed again pretty good but still had substantial residue from the iron phosphate.
    Paint:
    I didn't have access to a sprayer so decided to brush on.
    They suggest medium quality brushes. I used both low and medium quality and didnt really make a difference as the paint levels out well and both brushes start to gum up pretty quick. I guess others lIke foam brushes but I didn't try that.
    Make sure to wear good full protection as this stuff is hard to get off your skin - even if you catch it wet with solvent - and you're bound to get drips. I'm glad I had arm length nitrile gloves because my sleeve riding up and kept exposing my forearms while reaching tough spots.
    I would strongly suggest trying to spray on if you can because brushing really sucked.
    There were a few tight spots I couldn't really reach and I ended up using a can of Rustoleum Rust Reformer to reach those. That was a last-minute decision so there are probably better products/solutions and you should consider beforehand if you go this route.
    In retrospect, I'd probably think twice about paying to have this done as it was pretty shitty work and took about 25 hours project time. A lift and paint spray gun would be nice to have. I'm glad it's taken care of. I'll try to update in the Spring to show how it holds up through winter, sooner if there's peeling.
  2. Nov 18, 2015 at 9:29 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    Side question: How easy was it to remove the bed?
  3. Nov 18, 2015 at 10:37 PM
    Quba
    Quba [OP] Member
    Not too bad. Remove the tail lights with a screw driver and disconnect. Remove the electrical cabling fasteners. 6 bolts total, 2 in front corners of bed, 4 clustered behind axle. The bolts took some persuading with a breaker bar, couldn't get without. Remove the gas tank collar. Lifted fine with 3 ppl, was real easy to put back on with 4.
  4. Nov 19, 2015 at 4:34 PM
    Aufmitdemspiel
    Aufmitdemspiel Member
    98' 4wd V6 Tacoma
    That is allot of work but it looks well worth it; great looking finished product. I just hope my OEM frame can go through this winter alright. 17 years and no major signs yet *knocks on wood*.
  5. Nov 19, 2015 at 6:23 PM
    Quba
    Quba [OP] Member
    Thank you! Most rust coatings look good right after applying. Time will be the true test! I'll be pissed if I have to do this again in less than 5 years. =)
  6. Nov 19, 2015 at 7:18 PM
    Clucky
    Clucky Well-Known Member
    W
    WC to EC back to WC
    00 SR5 Stock 5 Speed
    & 12 TRD Stock 6 Speed
    Good stuff. What did you do on that rear bumper?
  7. Nov 19, 2015 at 7:27 PM
    Quba
    Quba [OP] Member
    As you can see, the chrome plating rusted out on top. I prepped it like the rest of the frame, put 2 coats of rust seal and then top coated with rustoleum metallic finish. The top is covered by plastic so I didn't care too much about appearance.
  8. Dec 30, 2015 at 7:46 PM
    Tjsingle26
    Tjsingle26 Well-Known Member
    Tom
    PA
    03 Tacoma xtra cab 4x4
    Hey man, just saw your post. Frame looks great!
  9. Dec 30, 2015 at 7:50 PM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    I'm impressed! I POR15ed my rear and front sections of my frame and then said screw it with the middle and I oil sprayed it. You need the patience of a saint to brush the whole thing. Looks like it came out good!
  10. Feb 15, 2022 at 8:06 PM
    Golfer
    Golfer Well-Known Member
    Any updates after a few years?
  11. Feb 15, 2022 at 8:13 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Tap the members name and you'll see the last log in was 2015
  12. Feb 15, 2022 at 8:20 PM
    Golfer
    We will never know
  13. Feb 15, 2022 at 8:25 PM
    Black DOG Lila
    Virginia
