Kazoo noise when I go over 80
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Reptarbush, Jan 30, 2025.
  1. Jan 30, 2025 at 9:08 AM
    Reptarbush
    Reptarbush [OP] New Member
    Jesse
    2015 Tacoma TRD
    Hey guys I'm new here just got a 2015 Tacoma TRD and when I get it over 80 every now and then I have a kazoo sounding noise from the passenger side front windshield. At first I thought it was the antenna in the wind please help!
    hangun61 likes this.
  2. Jan 30, 2025 at 9:16 AM
    burlyb
    burlyb Active Member
    '14 Metallic Gray SR5 DCLB
    Thats a Tacoma feature. Cross winds and highway speeds can create a negative pressure that causes the door top frames to distort enough for the seals to part, turning your truck into a musical instrument. Some have replaced door gaskets, but I cut a slot into mine and fished "backer rod" foam into seal bulb to help stiffen it up. I could be wrong and you could have a windshield air leak, but your description matches my experience.
  3. Jan 30, 2025 at 9:18 AM
    Dogota
    Dogota 2015 DCLB
    Mark
    Seattle, WA
    If not a bad windshield, it's probably the known door seal issue. Search this forum for "kazoo" and there are several posts.
    Discussion and some DIY solutions here:
    https://www.tacomaworld.com/threads/cross-wind-whistle-kazoo-noise-tsb.498774/
    I had it, replaced both seals with the Toyota parts, and it solved the problem. T-SB 0170-16 information attached, the seals still retail for around $75 each for a 2015 double cab.
    Page 1 of the TSB with part numbers:
    hangun61 and HWI like this.
  4. Jan 30, 2025 at 11:20 AM
    Reptarbush
    Jesse
    2015 Tacoma TRD
    Oh hell yeah thank you bro! This is a huge help.
  5. Jan 30, 2025 at 11:50 AM
    Dogota
    Dogota 2015 DCLB
    Mark
    Seattle, WA
    I recall people blue taped (the hell out of) the windshield seams and drove fast to rule that out, then did the fix with the seal modification.
    burlyb and knottyrope like this.
  6. Feb 2, 2025 at 8:28 AM
    greenEFSI
    greenEFSI TacoSupreme____
    Gio
    West Covina, SoCal
    '15 TRD Pro Super White
  7. Feb 2, 2025 at 8:37 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You have race truck now
    hangun61 and Greyhome like this.
  8. Feb 2, 2025 at 1:00 PM
    whtmtngrv
    whtmtngrv Well-Known Member
    SoCal
    2023 CSM TRD OR DCSB
    - Yota Xpedition Pro Style Grill - Yota Xpedition Black Emblem Overlays - Weathertech Bug/Rock Deflector - Cali Raised LED Cat Shields - Cali Raised Bed Stiffeners - Gold Hook Black TRD OR Bed Decals - TRD Pro Style Taillights - FitCamX Dash Cam - AJT Designs Nalgene/Yeti Cupholder - Fumoto F133N Oil Drain Valve
    Might want to double check just to be sure…
