Kayak transport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by USCG_Chief, Jun 15, 2021.
  1. Jun 17, 2021 at 9:39 AM
    HVLA
    HVLA Well-Known Member
    Idaho
    2020 Voodoo Blue OR DCSB 6MT
    That doesnt look too bad. 10 footer?
  2. Jun 17, 2021 at 9:46 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Jhook is better for plastic rotomoulded kayak, because the tie-down force is supported by the stronger portion of the boat.
    Worst case scenario is anchoring a plastic kayak, with the bottom hull onto the roof rack bars, tensioning the front and back of the kayak against the kayak's rocker shape, and then being in the hot sun. The forces will deform the hull, often lending a crease where the roof bar contacts. Better off to invert the kayak with the water side up, ideally lining up the rack bars with bulkhead locations in the kayak.
    USCG_Chief[OP] likes this.
  3. Jun 17, 2021 at 10:21 AM
    Bedawson
    Bedawson Well-Known Member
    Central Oregon
    2020 DCSB off road - Sold
    | Fox 2.0 | Icon AAL | RRW-7 -12 offset | 285/70/17 |
    I have a bed rack that sits below the roofline of the truck. I still use J hooks, but had to add a spacer below J hooks closest to the cab to prop that end up and clear the roof. works great so far!
  4. Jun 17, 2021 at 10:28 AM
    Taco_Fisher
    Taco_Fisher Well-Known Member
    Carl
    Cape Coral, FL
    '18 TRD Sport
    KDMax v6 Scorpion AT+ 265/70/17 Audio Control and Image Dynamics audio Coming soon: all the mods!
    I have a home built as well but yours is much cleaner looking and more functional. Any chance you have a pic of that trailer without all the yaks loaded up? I'd like to see if I can come up with something similar to allow my big hobie to load in the middle on the bottom and still have the rack setup like yours.
    SeaofBlue[QUOTED] likes this.
  5. Jun 17, 2021 at 11:05 AM
    SeaofBlue
    SeaofBlue Well-Known Member
    Owensboro KY
    2016 MGM DCSB Limited
    I don't have at the moment. I can get one in between the two bottom kayaks buy it's a small one and I have to twist it to get it in then it will lay flat. With my J hooks up I can get two more on top. But I'll try and get some pictures of it empty soon.
  6. Jun 17, 2021 at 11:13 AM
    Taco_Fisher
    Carl
    Cape Coral, FL
    '18 TRD Sport
    Awesome thank you.
    I have mine currently setup like this but I have nowhere to store seats, drives, PFDs, etc... I'm trying to figure out a better way to rearrange but the problem is the Hobie has to stay flat in the middle like that becuase it's too heavy to put in j-hooks or up on the rack.
    What I don't like is the top configuration. Having those j-hooks so far out on the cross bars introduces a ton of flex in the bars when moving but I have to keep them that spread apart to get the other one in the middle. I like yours where the outer kayaks are on an angle lower on the trailer. That would allow me to stand up 1 or 2 more vertically in the middle where that Vibe is now.
  7. Jun 17, 2021 at 11:21 AM
    pushgears
    pushgears Well-Known Member
    2021 OR DCSB MT
    My greatest fear is having my 14-foot ‘yak fly off while motoring along at 70 and killing someone. With that in mind, I suggest a dedicated set of attachments.
    USCG_Chief[OP] and vicali like this.
  8. Jun 17, 2021 at 11:25 AM
    Taco_Fisher
    Carl
    Cape Coral, FL
    '18 TRD Sport
    Well you've done the right thing to prevent that. Bow and stern lines prevent our airfoils from going airborne :)
    CrispyTacoLover and vicali like this.
  9. Jun 17, 2021 at 11:32 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    VE7OSR and pushgears like this.
  10. Jun 17, 2021 at 11:45 AM
    pushgears
    2021 OR DCSB MT
    “It’s a truck ;-) “
    Good suggestion/mod! The Yakima bow and stern tethers have a vinyl sleeve to protect the paint. Can’t see them because of the crappy photo...:anonymous:
  11. Jun 17, 2021 at 12:55 PM
    xf800spro
    xf800spro Member
    Harrison,Me.
    2019 SR5
    USCG_Chief[OP] and outdoorgb like this.
  12. Jun 17, 2021 at 1:11 PM
    Paddtac20
    Paddtac20 Well-Known Member
    Terry
    Iowa
    2020 Limited Quick Sand
    I use Yakima cradles with rollers on the rear pair. Also using a loader that fits in hitch receiver.
  13. Jun 17, 2021 at 1:12 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    USCG_Chief[OP] and VE7OSR like this.
  14. Jun 17, 2021 at 3:20 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Better padding, SKS lockable, foldable, etc. Depends on what you want.
  15. Jun 19, 2021 at 5:21 AM
    #35
    USCG_Chief
    USCG_Chief [OP] Member
    2019 Tacoma TRD
    Do you have the Tacoma OEM rack that you mount the JayLow to? Or you mount JayLow attachments to another rack? This is what I have: https://parts.toyota.com/p/Toyota_2019_Tacoma/Roof-Rack/70290669/PT27835170.html
    I mounted another (cheaper) kayak rack to my OEM rack and the OEM rack above is wobbly. The posts on the ends of the crossbars don't seem as solid as they need to be.
  16. Jun 19, 2021 at 5:43 AM
    #36
    USCG_Chief
    2019 Tacoma TRD
    Seems like JayHook or JayLow is the way to go with OEM rack. Thanks! However, do you find that the OEM is a bit wobbly? The posts on the ends of the crossbar don't seem like they secure well enough not to wobble back and forth. I guess you haven't had this issue or have been using the OEM rack for years and it's been fine?
  17. Jun 19, 2021 at 6:13 AM
    #37
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    I used it for years with no issue, though there was a small amount of play in that post your talking about, it always felt secure.
    I have since moved on to a prinsu rack to fit my needs.
  18. Jun 19, 2021 at 7:56 AM
    #38
    CrispyTacoLover
    Nope. I have Yakima Whispbar Through Bars (no longer made) with Yakima towers. They call them JetStream now.
