KARR alarm shock sensor goes off frequently
Discussion in '1st Gen. Tacomas (1995-2004)' started by Andiamo, Aug 16, 2021.
  1. Aug 16, 2021 at 6:05 AM
    Andiamo
    Andiamo [OP] Well-Known Member
    My truck came with one of those KARR alarms and whenever I disconnect the battery it puts it back in shock sensor mode, so when I shut the door too hard the alarm goes off. I can’t figure out how to put it back into the mode where I can lock the car without the shock sensor arming. Valet mode I think?
  2. Aug 16, 2021 at 10:25 AM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
  3. Aug 16, 2021 at 10:26 AM
    Fuergrissa
    Devin
    San Jose
    2000 T4R Limited
    jbrandt likes this.
  4. Aug 16, 2021 at 10:29 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Good stuff, thanks. My truck has the KARR alarm on it too that I got bamboozled into buying when I bought the truck from the dealer. It's never given me trouble but I know it's only a matter of time, definitely saving this info for the future.
    BattleKat likes this.
  5. Aug 16, 2021 at 4:53 PM
    Andiamo
    I turned that shock sensor all the way down to one and have had it that way for years. It’s still goes off more often than not when I close the door. When I put it in valet mode, it allows me to just lock it without interference from the shock sensor. Would be cool to have it chirp when I lock it but I think that you can only do that when the shock sensor is on
  6. Aug 16, 2021 at 4:56 PM
    eon_blue
    Azusa, CA
    That's weird. Mine's turned all the way down too, the only thing that sets it off is if I drop something really heavy into the bed lol. I could jump up and down on my sliders and it won't set it off.
  7. Aug 16, 2021 at 4:57 PM
    eon_blue
    Azusa, CA
    Wait, so you're alarm is activated before you close the door? Shouldn't it activate after you close the door and hit the lock button? Just curious how shutting the door would trigger the alarm.
  8. Aug 16, 2021 at 9:27 PM
    Fuergrissa
    Devin
    San Jose
    2000 T4R Limited
    to trouble shoot I’d start by understanding why the alarm is going off, Intrusion Warning Signals page 4, this may help eliminate the shock sensor. Also maybe your alarm system is set to passive mode, you could try reprogramming to active mode.
    Changing Activation Between Active and Passive page 5 & 6
    Andiamo[QUOTED][OP] likes this.
  9. Aug 16, 2021 at 9:31 PM
    Andiamo
    it has function where it chirps if a door isn’t shut. I was going off this manual but I’m not sure if it’s for the correct model
    http://mikehmayer.com/stuff/xB/KARR 4040a.pdf
    eon_blue[QUOTED] likes this.
  10. Aug 18, 2021 at 7:17 PM
    Andiamo
    shutting the door at different pressures activates the shock sensor
    Fuergrissa likes this.
  11. Dec 23, 2022 at 2:40 PM
    BattleKat
    BattleKat Well-Known Member
    San Diego
    2021 TRD Offroad 4x4 - Army Green
    6112/5160s Icon RXT Leaf Pack (Option 2) Cali Raised 0-Degree Rock Sliders Cali Raised Bed Stiffeners Talon's Garage Cat Shield TRD Skid Plate ARE MX Interchangeable Yoda Dashboard Buddies
    I know this is an older post, but my Karr alarm on my 2021 Tacoma (bought in May 2021) is programmed with an app that connects to it via Bluetooth.
  12. Dec 23, 2022 at 4:02 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    While the technology for Bluetooth was technically around when 1st gen's rolled off the line, it wasn't implemented into widespread consumer electronics until WAY later.
