Kanati Trail Hog A/T
Discussion in 'Wheels & Tires' started by Razorecko, Feb 25, 2021.
  1. Feb 25, 2021 at 4:29 PM
    Razorecko
    Razorecko [OP] Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    So I needed new tires for my '09 with 190k and have always been on the lookout for something that had the deep snow traction of the duratrac's. I already went through a couple sets of the duratrac's and watched them from going $ 160 a tire to nearly double that over the last several years. I ended up buying the Trail Hog's for a couple reasons. One being that the whole set cost me $ 700 total in 285/70/17's and the other is that in that size duratrac doesn't make E load tires. Even though E load tires are heavier and not as responsive I feel they do alot better in deep snow and absorb crappy roads better. I'll update it when I get a chance to go thru some deeper snow. For now though they ride good, no noise, balanced fine and have a great tread.
    - camber is not off - road isn't flatIMG_20210225_171327.jpg IMG_20210225_171338.jpg IMG_20210225_171828.jpg
    TacoTRD78 likes this.
  2. Apr 7, 2021 at 7:31 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    Was thinking about getting some also. Great reviews 10 ply tire and it weighs about 6lbs more than a duratrac in 285/75r16.
  3. Aug 5, 2022 at 6:19 AM
    flat_tire
    flat_tire Well-Known Member
    Independence, KY 41051
    2016 Tacoma TRD Off-road ACLB blue, 2018 Tacoma TRD Sport DCSB white, 2020 supercharged Tacoma Limited DCSB magnetic grey metallic, 1993 AMGE HMMWV, 1993 Ford Mustang GT 5.0 supercharged
    2020 Tacoma: Icon stage 9, Magnuson supercharger, URD full exhaust, solar 2018 Tacoma; OME 2in suspension 2016 Tacoma: Falcon front and rear rate adjustable suspension, rear airbag lift
    The wear is good so far, definitely still quiet on the roads. It's better than duractracs on wet/rained on pavement. I'd say they are at about 20% less efficient in deep snow and on ice than duractracs. The sidewall blocks curve more than the straighter edge duratrac blocks on the sidewalls so I think that has a lot to do with it. I should be able to give a more realistic update this winter when the tires are more into their halfway life.
