Just ordered 17x8.5 Method 308 Roost! Need info
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stagarm, Feb 25, 2019.
  1. Feb 25, 2019 at 5:43 PM
    Stagarm
    Stagarm [OP] Well-Known Member
    Trev
    Fj
    Me behind the wheel
    Like title states. I just pulled the trigger on 4 Bronze Method 308 Roost wheels for my 13’ dub cab 4x4.
    Wheel specs:
    17x8.5
    0mm offset
    4.75ish backspacing
    Questions!!!
    Do I need to order some hub bore (hub-centric)spacers? 108mm to 106mm
    Also what style lug nuts work best on the 308’s?
    New to this forum and very greatful of all the knowledge you all bring to it.
    ovrlndkull likes this.
  2. Feb 25, 2019 at 5:51 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    You won't notice that hub bore difference so no need for hub centering rings which I assume is what you are talking about.
    Here are some good lug nuts you'll need ET style for Toyota so there is enough thread engagements.
    https://www.summitracing.com/parts/..._YbicAiQpbvECcTIwQvnhTPbk9drNb3waAjwpEALw_wcB
  3. Feb 25, 2019 at 6:55 PM
    Stagarm
    Trev
    Fj
    Me behind the wheel
    ovrlndkull[QUOTED] likes this.
  4. Mar 2, 2019 at 10:25 AM
    Stagarm
    Trev
    Fj
    Me behind the wheel
  5. Mar 2, 2019 at 10:30 AM
    Stagarm
    Trev
    Fj
    Me behind the wheel
    The site I ordered the wheels from said hub bore size was 108mm. Ended up that the 17” X 8.5” lug pattern 6x5.5 come with 106.25mm. Perfect fit. Used the suggested Black ET spline lugs.
    Over all very satisfied with the results. Now suspension work!!
  6. Mar 2, 2019 at 10:39 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Damn I can't wait til I can order some methods
    Stagarm[OP] likes this.
  7. Mar 4, 2019 at 7:32 AM
    Fly Skids Up!
    Fly Skids Up! Well-Known Member
    Marc
    Fleming Island, Florida
    2014 regular cab, 4x4, 5 speed manual
    Fog lights, Weather tech floor liners, rear window tint, Gator pro tri fold cover and bed liner, Fuel Anza 16x8 wheels, Cooper Discoverer 265/70-16 AT3 4s, N-Fab nerf bar steps, The ultimate headlight upgrade, Pioneer speakers and amp, sound deadening, Bilstein shocks, Back-up camera, Class III trailer hitch,
  8. Mar 4, 2019 at 7:37 AM
    Mike714
    Mike714 Well-Known Member
    Cypress, CA
    2013 DCSB Prerunner Super White
    This looks amazing. Never thought I'd want gold wheels so badly until seeing this!
    Stagarm[QUOTED][OP] likes this.
  9. Mar 4, 2019 at 8:19 AM
    Stagarm
    Trev
    Fj
    Me behind the wheel
    I used 24 Black 12x1.5 Closed End ET Spline Tuner Lug Nuts.
  10. Mar 4, 2019 at 1:13 PM
    Stagarm
    Trev
    Fj
    Me behind the wheel
    Quick review and info for anyone looking to run this set up on a Tacoma.
    17x8.5 Roost wrapped in 265/70R17
    Suspension & Rubbing:
    Running on stock SR5 4x4 suspension with a little bit of rubbing on the front mud flap. I ended up removing flaps and sanding down the area. (See photo) Rubbing seems to be gone or so light I can’t hear it anymore.
    Balancing:
    I used 5oz of balancing beads per tire. No ugly sticker weights!!
    Hub centric? KINDA:
    My Toyota hub measured 106.10mm give or take. The Method 308 Roost hub bore measured 106.25mm give or take. Not enough room to run rings but still enough room to give you steering shake.
    Lug Nuts:
    I used 12x1.5 ET splined lug nuts (see photo)
    Criss-cross Tightening lugs:
    The tire shop didn’t take time to criss cross tighten them to truly center the wheels. My drive home on the highway I had some pretty good steering shake from 50ish to 70ish. At home I reinstalled each wheel with the proper criss-cross method. (See picture). Take your time hand snug the lugs then 1/4 turns at a time and give the wheel some good shakes as you tighten it up. Torque them at 85 ft.*lbf.
    Tested it on the highway and all steering shake/vibration is gone. Smooth sailing!!
  11. Mar 11, 2019 at 5:39 PM
    Stagarm
    Trev
    Fj
    Me behind the wheel
    Update: ended up pulling the beads and went to the traditional weights on a road force balancer.
    Beads were inconsistent.
  12. Mar 11, 2019 at 6:19 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    They are good catch
  13. Mar 11, 2019 at 6:25 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I was getting ready to reply that the .15 of Hub bore difference wasn't going to be enough to cause a shake especially with ET lug nuts since they will lug centric the wheels even better than standard acorn style. Beads are never perfect. I always tell guys they aren't worth running until you get up into the 37+ size tires and even then they are inconsistent. They don't always settle where they need to to balance the wheel and tire assembly well. Just those larger sizes usually end up asking for a lot of weight balancing them the traditional way.
  14. Mar 11, 2019 at 6:36 PM
    Ddaughen15
    Ddaughen15 Well-Known Member
    Dylan
    New York
    15’ Tacoma SR5
    Looks awesome! I’ve been wanting some methods since I got my tacoma
  15. Mar 11, 2019 at 7:15 PM
    Stagarm
    Trev
    Fj
    Me behind the wheel
    I agree .15mm is very minimal. Only can measure with feeler gauges. But I was very surprised how much steering shake was eliminated with retighting the et lugs.
    The methods are not a snug hub fit like the oem wheels. But they are damn sexy tho. satisfaction.
  16. Mar 11, 2019 at 7:17 PM
    Stagarm
    Trev
    Fj
    Me behind the wheel
    Added some center cap epoxy domed decals. 1CE8142E-20B3-4228-8B88-16B659326056.jpg
    mtnsoft_tac0 likes this.
  17. Mar 11, 2019 at 7:18 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    After driving for a bit any new wheel needs to be retorqued because the lugs seat themselves into the wheels. That vibration was probably more due to the lugs than hub bore issues.
  18. Mar 11, 2019 at 8:26 PM
    Stagarm
    Trev
    Fj
    Me behind the wheel
    Good info.
    Never had so much new wheels and tire balancing problems with my past 12 vehicles. But they are all balanced now and rolling smov.
  19. Mar 12, 2019 at 3:15 PM
    Smokes
    Smokes Well-Known Member
    I also have these rims but in black. Make sure that if the black center cap is ever removed you securely replace it. I have lost three of them due to them not being replaced correctly.
  20. Mar 12, 2019 at 4:56 PM
    Stagarm
    Trev
    Fj
    Me behind the wheel
    Completely agree! When I removed the snap in black plastic center caps to apply some decals, I noticed that they are barely holding on. And when reinstalling you have to really push down on all clip areas to make sure it’s fully seated.
