Just installed the Spyder Projector/LED kit on my 2011
Discussion in 'Lighting' started by josh256, Oct 2, 2011.
  1. Oct 2, 2011 at 2:28 PM
    josh256
    josh256 [OP] Apprentice Modder
    Josh
    Tacoma TRD Sport
    TRD exhaust TRD short throw shifter T-Rex Grille Rhino Wheels PL5300 latch Muth Mirrors Pioneer HU, amps and subs Image Dynamics in the doors Dynamat (everywhere) Dynaliner (selectively) 3M DiNoc wrap de-badge/rebadge (black)
    I was plesantly surprised with the build quality given I picked these up on Amazon for $189 (w/ free shipping). The kit also included brighter regular & high beam Halo bulbs. Now that I have projectors I plan to upgrade to a Xenon 6000K H4 kit soon.
    *EDIT* The Spyder kit uses H1 in the projectors, not H4 like the OEM headlamps. This also explains why they ship w/ Halo bulbs included.
    Updated - HID 5000K Lows, HID 4300K Fogs:
  2. Oct 3, 2011 at 4:11 AM
    09_tacoma
    09_tacoma Forever at a crossroads
    Mylene
    North Pole
    09 Taco V6 4x4 DLCB TRD Sport
    Headlights, Exhaust, grill, Kings all around resi suspension. Camburg UCA's, Clarion double din
    We've got the same headlights :). What wire combo did you do on yours? (what setting is each bulb on)
  3. Oct 3, 2011 at 6:47 AM
    josh256
    Josh
    Tacoma TRD Sport
    I wired the LEDs into the parking/signal leads so they're on in both lighting positions "parking lights" and "headlights" (and off when I turn lights off.. which I rarely do).
    Stock projector aim is perfect I believe.. In traffic when I'm stopped behind cars the beam tops out about 1" below the top/edge of most car/sedan's trunks so I'm not blasting any oncoming drivers nor hitting any rear view mirrors.
  4. Oct 3, 2011 at 6:50 AM
    Hook & Ladder
    Hook & Ladder Well-Known Member
    Maine
    16' TRD Tacoma
    The project @c4_fabrication-Sliders, HC bumper w/ swing out @kb_voodoo_fabrications-Bed rack @tepuitents-RTT @cali_raised_led-Fogs, ditch lights, bed stiffeners @prinsudesign-Roof rack @kingshocks-2.5 with adjuster @totalchaosfabrication-UCA @rcioffroad-diff skid plate Follow at @wicked_overland #nacrew
    Hey I have the same lights dose your hi beam stay on with your low ?? They are great lights I have 10k in mine and I love them
  5. Oct 3, 2011 at 7:06 AM
    09_tacoma
    Mylene
    North Pole
    I find they're aimed at the right spot as well. However, low beams (I've got the upgraded HID kit also) sucks when doing night driving on a highway/interstate in bad weather. They also take a while to fully brighten up and I've almost took the ditch or went straight for a rock cut in a curb a couple times because of it. :cool:
  6. Oct 3, 2011 at 12:41 PM
    09_tacoma
    Mylene
    North Pole
    Once they are in full brightness it's fine, as you know HID's take a few seconds to fully light up. When split seconds are involved I don't care if you're Travis Pastrana or Ken Block you'll be on the same level as me. Mine are 6000K
  7. Oct 3, 2011 at 1:32 PM
    Hook & Ladder
    Maine
    16' TRD Tacoma
    When I added my fog light i wired them so they stay on all the time. Witch helpd when driving you dont see the warm up time for the high beams as much, plus I went with the 55w bulbs.
  8. Oct 12, 2011 at 7:31 PM
    rberumen2
    rberumen2 Well-Known Member
    Ralph
    California
    2017 White Tacoma TRD Sport 4x4 DCSB
    Where did you guys get your hids. I just got these and want hids like I had in my oem's. Since these are different bulbs, how'd you guys install them.
  9. Oct 15, 2011 at 8:31 PM
    rberumen2
    Ralph
    California
    Are the hids h4 or h1? I just got these headlights from carid and need help on this. The bulbs that come with them are h1. But are the hid bulbs supposed to be h4?
  10. Nov 15, 2011 at 9:17 AM
    josh256
    Josh
    Tacoma TRD Sport
    No, you have to use H1 after converting from the OEM to Spyder headlight/enclosure
  11. Feb 6, 2012 at 7:16 PM
    islandracer8o8
    islandracer8o8 Member
    Doug
    Honolulu
    Could you help me please? I just bought these headlights and have no idea what to do with the 3 pin connector running to the low beams. I want to change them out to HID's but am unsure what bulb size to use and if I can just swap them out with the awkwardly "screwed" in bulb now. Thanks
  12. Feb 8, 2012 at 2:06 PM
    josh256
    Josh
    Tacoma TRD Sport
    Ya sure. You will need to use an H1 HID kit which is *not* screwed in. EG. the bulb in the Spyder low-beam socket is an H1 and is held in place by a retaining clip.
    The low-beam bulb in the OEM assembly was an H4 I believe.. anyhow that's not relevant.
    From the harness you are describing the blue wire is the lows, red is the highs and the blacks are the grounds.
    Respectively you will cut the blue/black (lows) which ran to the Spyder's existing H1 bulb and rewire those directly into the ballast:
    On the new H1 bulb I recommend you cut its red/black wires so that you can feed them through the rubber cover then shorten and reconnect (I used heat shrink afterwards):
  13. Feb 8, 2012 at 2:16 PM
    josh256
    Josh
    Tacoma TRD Sport
    If your bulbs take a while to heat up replace your ballasts.. my Slim ballasts on the fogs are like that, went with full size ballasts for the lows and they're instantly bright..
  14. Feb 25, 2012 at 12:02 PM
    sofiasdad11
    sofiasdad11 Reads more than posts
    Near the Windy City, but in the country
    2011 BLACK 4X4 DCLB TRD SPORT
    Flux capacitor (2nd gen version), toytec ultimate liftkit, amp research powersteps, custom katzkin heated leather incl. console cover, retraxpro retractable bed cover, earnhardt jr. cannons@18x9(summer),ballistic jesters@18x9 (winter),285/60/18 nitto grapplers, bodymatched bushwackers, the original Homertaco full satoshi " raptor" grill, viper 5704 remote/smart-start/alarm w/viper cellulor app, ravelco anti-theft device, ipcw tails, redline hoodstruts, oem roof rack, led maps/dome, backup light mod, swingcase storage box, jl audio stealthbox and amps,focal drivers,alpine carplay unit, pop&lock premium handle, seatbelt chime disabled, tailgate hoseclamp mod, rich evans caliper covers, weathertech digitalfit mats, flyzeye V2W,oem bedmat, salex console organizer,speeddawg shiftknob
    hey josh, just wondering how these lights are doing nearly 5 months later. think i found 'em at Amazon (with your review?) also found some at another site with "premium japanese" HID's already installed:cool: still prefer this look in a headlight over the oem's. thanks.................and pm sent
  15. Dec 9, 2012 at 7:33 PM
    tbostrom
    tbostrom Member
    San Diego, CA
    00 Tacoma Prerunner
    I'm going to agree with Josh256 here. Just got done installing Spyder projectors on my 2000 Tacoma with full size ballasts and it takes less than a second or two for them to come to full bright.
  16. May 13, 2015 at 6:11 PM
    spazz
    spazz Member
    gary
    2010 Tacoma 1199
    I was wondering what brand HID KIT TO BUY FOR MY 2010 TACOMA THAT HAS THE SPIDER HALLO PROJECTORS ON IT
  17. May 13, 2015 at 6:12 PM
    spazz
    spazz Member
    gary
    2010 Tacoma 1199
  18. May 13, 2015 at 6:12 PM
    spazz
    spazz Member
    gary
    2010 Tacoma 1199
    And how to wire them up so my high beam still works
  19. May 15, 2015 at 11:50 AM
    snowbrdd
    snowbrdd Well-Known Member
  20. Jul 11, 2015 at 7:45 PM
    BlueWaffleTaco
    BlueWaffleTaco Well-Known Member
    Brendan
    Stl (wentzville) MO
    2007 Blue Double Cab sr5 trd sport
    SOS CONCEPT ROCK SLIDERS, CALI RAISED LED w/ STEALTH MOUNTS, THULE ROOF RACK, 3" ROUGH COUNTRY BODY LIFT w/ 5100 BILLYS, VISION WHEELS W/ 285 70 R17s, AFTERMARKET HEAD UNIT, SOON TO BE OWNER OF NEW FRAME
    Has anyone put led strips in their 2007 Tacoma lights? Think it looks bad ass but not the smartest electrician on the short bus
