Just had rear brakes replaced, now parking brake doesn’t work
Discussion in '2nd Gen. Tacomas (2005-2015)' started by regtaco, Dec 7, 2018.
  1. Dec 7, 2018 at 3:44 PM
    regtaco
    regtaco [OP] Well-Known Member
    Lee
    Knoxville/Franklin TN
    07 Reg cab 4x4
    Toytec 3 inch lift kit with: OME 884 coils, OME Nitro shocks, custom driveshaft, diff drop
    Today I had the rear brake shoes, drums, rear brake lines (extended length from Wheelers off road), and related hardware replaced at my local mechanic. They did a good job from what I can tell except when I got home I put on the parking brake and the truck started rolling down the driveway.
    I backed up a million times while applying the parking brake and regular brakes trying to get the self adjustment to work and it definitely made it better but the parking brake still doesn’t hold the truck. Is this something I could fix myself easily so I don’t have to drive all the way back to get the shop to fix, or just let them fool with it?
  2. Dec 7, 2018 at 3:52 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It sounds like your mechanic potentially didn't perform the e brake adjustment, just tossed the drums on and called it good.
    Check the adjustment of them. The drums should exhibit some difficulty removing them when you try to pull them off. If they are not, and just slide out he did not perform the adjustment which is sort of a red flag.
    regtaco[OP] likes this.
  3. Dec 7, 2018 at 4:25 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Adjust the rears properly or take it back and have them do it as you paid them already to do it:
    b_r_o likes this.
  4. Dec 7, 2018 at 4:38 PM
    Thebubble
    Thebubble Well-Known Member
    Southern California
    2006 GX470
    2009 Pre-Runner, V6: Totaled 2014 Tacoma 4x4, 5 speed, 4 Cylinder: Totaled 2000 Tacoma 5 Lug: Sold 2006 Lexus GX470: Wheeling!!!!!!!!!!!!!!!!!!!!!!!
    Easy! As mentioned above - drum needs to be adjusted. Happened to my first time doing the rear drums....
  5. Dec 7, 2018 at 5:16 PM
    regtaco
    Lee
    07 Reg cab 4x4
    Thanks guys! Looks fairly easy so will probably do it myself tomorrow.
  6. Dec 7, 2018 at 5:21 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Pay attention to the little adjuster wheel. Make sure the teeth are pointed the right direction. They may have gotten switched accidentally and ended up on the wrong side
  7. Dec 7, 2018 at 8:35 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Yep, usually, when removing the shoes, the adjusters are 'closed' (screwed shut) to make it easier to remove the upper retention spring - I do it every time myself. When they put the adjusters back in, they forgot to open them up. I believe they open up by turning counter-clockwise. It can be done with a screwdriver that slides in through the backside. However, it's a PIA to do it that way. It is easier to remove the drum, turn out the adjuster 1 or two turns, then put on the drum for fitment. Keep adjusting out until there is a slight drag when installing the drums, then go back half a turn.
  8. Dec 7, 2018 at 8:42 PM
    TACOzJON
    TACOzJON Well-Known Member
    Jon
    Socal
    2005 Tacoma 4x4
    I would take it back. Not a big deal but you've already paid for this. Unless you really wanna get your hands dirty and DIY
  9. Dec 8, 2018 at 7:55 AM
    regtaco
    Lee
    07 Reg cab 4x4
    Well we had snow on the ground this morning in Nashville so took it back for them to deal with it. You guys were right - they said the last tech “forgot” to adjust the shoes back.
    Good to go now :thumbsup:
    TexasWhiteIce likes this.
  10. Dec 8, 2018 at 8:40 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Excellent!
