Just bought a 2019 Tacoma, first thing, headlight bulb replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kjb12180, Mar 14, 2023.
  1. Mar 14, 2023 at 12:59 PM
    kjb12180
    kjb12180 [OP] Member
    Karl
    Upstate New York
    '19 TRD Sport Crew Cab
    Hey all,
    Not my first post here, but first time as a 3rd gen owner. I traded in my first gen along with a forester to acquire a TRD Sport double cab with a long bed. First thing, I already miss the brightness of my Foresters headlights with projector lenses.
    What is the best/safest and cheapest options for bulb repalcements? Does the 3rd gen require Can Bus style bulbs?
    I will be looking to swap out the reverse lights as well.
    Thank you all in advance!
  2. Mar 14, 2023 at 1:06 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
  3. Mar 14, 2023 at 1:09 PM
    tarbal255
    tarbal255 Well-Known Member
    Dave
    19 Taco SR
  4. Mar 14, 2023 at 1:11 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    H9's into lows. Search here or Google it. Just ordered mine.
  5. Mar 16, 2023 at 6:28 AM
    kjb12180
    Karl
    Upstate New York
    Thank you guys, this is great info. Crazy to think that LED may not be the way to go. What is the best option that you all have gone with? HID or Xenon?
  6. Mar 16, 2023 at 6:43 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Philips H9 halogen bulbs or buy a pair of OEM LED headlight assemblies to swap in.
    BillyE, TRDRed, t2c and 4 others like this.
  7. Mar 16, 2023 at 9:09 AM
    DeuceDeuceBravo
    DeuceDeuceBravo Well-Known Member
    New England
    LED is not the way to go because the housing is not designed for it. Go with the H9's recommended in the previously mentioned thread.
    TRDRed, FredRed315, t2c and 2 others like this.
  8. Mar 16, 2023 at 9:11 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    Get H9s but get these as well.
    https://www.amazon.com/iJDMTOY-Exte...=1678983053&sprefix=h9+adapter,aps,100&sr=8-8
    Modify this to take the H9 and go into the H11 off the tacoma. This way, if one burns out, you can stop anywhere and get a set of H9s and not have to worry about modification of them to get them to fit on short notice. This is how I did mine - get the pigtail to be the adapter, now I can swing by any store and get an H9 and drop it in.
  9. Mar 16, 2023 at 9:12 AM
    eurowner
    eurowner Duke Sky
    Scoty
  10. Mar 16, 2023 at 11:31 AM
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    I did not not know these were available. I did the H9 modification but now will buy this. Thanks for the information.
    GarlicFarts[QUOTED] likes this.
  11. Mar 16, 2023 at 11:41 AM
    Just1n
    Just1n Well-Known Member
    Did this a few weeks ago when I moved to an area with lots of deer, best investment so far.
  12. Mar 16, 2023 at 12:20 PM
    na8rboy
    WI
    You don't need those or modify H9 lamps. Just pop/pull the green adapter out of factory plug. It pulls right out. Then it plugs right into H9.
    musicisevil, t2c and blu92in99 like this.
  13. Mar 16, 2023 at 12:24 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    The H9 mod can be done by pulling out the plastic insert in the bulb socket too. Works well! Leds won’t work well in the halogen housings due to focus issues, but there is (or was?) a pair of OEM 2017 led lights in the So Cal San Diego garage sale for $200
  14. Jul 19, 2023 at 5:22 PM
    Pista1
    Pista1 Well-Known Member
    Pedro
    Ensenada, Baja, MX
    3rd Gen 18 4x4 TRD Sport
    TRD intake, TRD exhaust, Tuned, 6112's/5160's
    do you have a pic (visual guy) of how to do this?
  15. Jul 19, 2023 at 8:34 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    When you look in the end of the wiring harness plug for the H11/Low beam bulb, you will see the outer plug material is black, but there is a bright green insert. Grab it securely with a pair of fone needle nose pliers and pull it straight out. It's not glued, jist a press fit, iirc.
    Pista1[QUOTED], na8rboy and TRDRed like this.
