Just bought 2005 Tacoma with 200k, needs new suspension, advice needed...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by InspectorClouseau, Sep 18, 2017.
  1. Sep 18, 2017 at 2:28 PM
    InspectorClouseau
    InspectorClouseau [OP] Member
    2021 TACOMA CREW LONGBED TRD 4X4
    Hello -- First post. I recently purchased a 2005 Tacoma 4x4 Crew Cab longbed with about 200,000 miles. I took it on a mild 4x4 road a few times over the last month and noticed the suspension is shot. I also noticed it sagged a bit when I put in a few bags of concrete. I am looking for any advice on replacing factory shocks/struts/leaf springs. I don't really want to life the truck as it's my daily driver and I'm not really interested in getting shocks that can be adjusted or anything like that. What I would love to know is what is the perfect set up for replacing worn out factory suspension. I'd like to do it properly and get quality components. Do I need to replace the rear leaf springs also?
  2. Sep 18, 2017 at 2:30 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    See if somebody on the forum has a factory suspension that they removed to lift their vehicle. If not get a set of 5100's all around. The front springs should still be good. The rear leafs can be replaced with again an OEM take off.
    highriserkaiser and parsonsjr like this.
  3. Sep 18, 2017 at 2:36 PM
    TacoTacoma97
    TacoTacoma97 Eagle Scout
    Scott
    Waco TX
    I think it's a Tacoma, let me go check again...
    *Cracks knuckles* Where do I begin?
    Rear:
    Toytec progressive AAL (they're long and ride great)
    Bilstein 5100s
    Front:
    Bilstein 5100s
    OME coil overs
    Have fun!
    Tacoma_c_1.html
  4. Sep 18, 2017 at 2:41 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    You don't give any sort of budget....
    Simplest and probably cheapest would be to pick up a take off setup from someone who upgraded their suspension. You can find them with generally low miles and for pretty cheap. Otherwise you could look at bilsteins.
    As for sagging...the Toyota springs aren't exactly known for being the best. So yes they will sag with a few hundred pounds. The trucks payload is only 1400lbs including weight of passengers and really the limit (IMO) is the springs. Load it up to 1000 pounds in the bed and youll be hitting bumpstops. Upgrade the springs (I run OME dakars with the overload) and you can take the same load and be just fine. Ive had 10, 80lb bags of concrete with other stuff in and still not sagged to bad.
  5. Sep 18, 2017 at 2:42 PM
    parsonsjr
    parsonsjr "OFFICIAL" Moth Man |Free Folk have no King
    Sam
    Athens, Ga
    2014 DCSB TRD off road
    That's solid advice, since you have no desire to lift.
  6. Sep 18, 2017 at 5:03 PM
    SeanBonham
    SeanBonham Well-Known Member
    Sean
    Derby City
    2012 DCSB SR5 4x4 6mt with some thangs
    Get some takeoffs from a 3rd gen TRD off road. That's what I did, added an aal and a top plate spacer. Cheap and real skookum.
  7. Sep 18, 2017 at 5:13 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
  8. Sep 19, 2017 at 10:11 AM
    InspectorClouseau
    Thanks folks. This is perfect. If I go with Bilsteins, it seems like the 5100s are just for lifted trucks? They seem better than the 4600 but my truck isn't lifted.
    Are there any other parts I should upgrade while I'm getting this work done? Struts? Also, my budget is open. By that I mean I'd like to get the suspension updated using quality components so I don't have to worry about it for a long time. So I am open to spending whatever it takes to do this, within reason of course.
  9. Sep 19, 2017 at 10:14 AM
    RedRed
    RedRed TACO TUESDAY!!!
    Red
    Lake Norman NC
    15 taco with stuff & things
    1.75" Billy's plus 1/4 spacer on both sides. 1" block in rear. 265/70/17 nitto g2 SCS matte dark bronze 6s
    5100s are great for stock configuration as well since they are adjustable.
  10. Sep 19, 2017 at 10:23 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    At 200k miles, I would take a look at bushings, ball joints, and tie rods along with shocks and springs. I have to agree that finding someone with a 3rd gen truck with factory take offs is a good route for getting quality suspension on a budget price. I would suggest replacing your entire rear leaf pack with a 3rd gen factory take off rather than adding extra leafs to an already worn out leaf pack. Energy suspension makes a complete bushing replacement set for your truck which includes the upper and lower control arms, body mounts, and sway bar bushings. Another set of bushings to do while you're in there is the steering rack bushings. One way to avoid some labor on the upper control arm bushings and ball joints is to find someone with newer, like 3rd gen uppers that someone has replaced with an aftermarket. Oh and another thing to consider on your 05 is that the alignment cams may have seized especially if you're in an area that salts roads in winter. I'd check them for this before getting too far as you may need to replace your lower control arms completely. Where is it that you're located? If you need any help with this, feel free to send me a PM and I'll get ya going in the right direction.
    RedRed likes this.
  11. Sep 19, 2017 at 10:33 AM
    InspectorClouseau
    This is perfect. Thank you. I live in the Bay Area, Half Moon Bay to be specific. I found this on Craigslist. Would this work for shocks: https://sfbay.craigslist.org/sby/pts/d/2017-toyota-tacoma-trd-off/6311492919.html
    RedRed likes this.
  12. Sep 19, 2017 at 10:46 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    RedRed likes this.
  13. Oct 4, 2017 at 12:32 PM
    Ricky B
    Ricky B Well-Known Member
    Arkansas
    1998 XCAB
    Thanks for this thread I just put my vin# and found my 2007 qualifies for the rear leaf replacement. I just purchased this truck and don't like the rough country lift that is on it. Now that I know I can get a new leaf pack makes this even better. Thanks RIck
  14. Oct 4, 2017 at 3:52 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Yeap,dont waste your time with stock leafs.
