Jumpstarter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Jun 8, 2022.
  1. Jun 8, 2022 at 11:28 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
    This is the best brand.
    Are they worth keeping one in the truck?
    I heard a scary story once where it got hot and swelled up. I don't know it if caused a fire or not.
    Supposedly the type of battery inside is the type that can do that.
    That's the only drawback I can think of. But it does not seem widespread and I've certainly never seen or dealt with that issue in real life.
    Now, this would probably not be for me. But for friends or random people who need a jump. A jumpbox seems like a faster easier way of doing it. Especially if you just let the friend borrow it for a day until they fully solve the problem of a dead battery; by replacing it.
    Me personally, I run high quality dealer batteries for $100-200, the same price as a worse quality Autozone or WalMart one. It cranks hard every time, and lasts a while. When I start to feel it get weak years down the road, I'll simply replace it that week; no jumping needed.
    If yes, which one?
    I'd lean towards the GB70 for multiple jumps, and ability to start larger engines.
    Not a small one that might struggle to start a small engine once.
    Or maybe jumper cables AND jumpstarter.
    I don't know if it works on motorcycles. I know bikes run on 14v, not 12v, so if you jump a bike from a car with jumper cables, you'll fry the stator.
    It probably wouldn't work on bikes given it says 12v on the label.
    I'm not sure if temperature matters. Like one in an insulated garage for professional use, versus a vehicle that changes temperature. Though heat can be reduced by cracking windows with AVS/Weathertech visors, ceramic tint, sunshade, light paint, sound deadening, etc. and interior storage compartments may be a bit cooler than the cabin
  2. Jun 8, 2022 at 11:40 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    This is the model I bought also, the GB40 last year.
    Works well and added bonus is after each use simply plug in to your usb charger in the truck or at home and its topped off again.
    If camping will power other devices with a usb port. Good on a boat if you kill the batteries also to get the motor going offshore.
    You can buy as big as you want based on price and size. Much easier and lighter than a second full sized battery.
    inwood customs likes this.
  3. Jun 8, 2022 at 11:57 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    NOCO is good to go, they make some of the better jump packs. I carry jumper cables and a NOCO pack just to be safe. Haven’t used the cables (for others never myself) since I got the jump pack but old habits die hard.
    Also unsure about your motorcycle statement. I jumped my old street bike from my car many times with no issues. You just have to do it with the motor off. Many bikes have 12v electrical systems, it just depends on the bike.
  4. Jun 8, 2022 at 11:58 PM
    MGMDesertTaco
    Good brand, but I wouldn't leave it in the truck. At least not in the summer in AZ. :bananadead:
    DES2009 likes this.
  5. Jun 9, 2022 at 12:02 AM
    TacoTuesday1
    FL
    Does anyone know if NOCO ever has sales?
    I think Amazon had them discounted once randomly, as a part of their promoted products thing which probably changes every month
    I don't know what happened to my jumper cables. I have to see if they're in a box somewhere, or hiding underneath all my other recovery equipment in the truck storage compartments.
    But I think they somehow magically disappeared.
    Haven't looked into which is a reliable good brand of jumper cables to buy; hopefully cheap and $20ish.
    I'm hesitant to walk into Harbor Freight and grab the first pair I see on the shelf; they're probably cheap, thin, flimsy, etc.
    Thin wires and lots of electricity don't mix. Causes heat, melting, etc. (been there done that)
    Not to knock HFT. The few things I have from there (chosen carefully) work great.
    Maybe I'm wrong and they are 12V. Maybe the bike I'm remembering dying didn't fry the stator from a jump; but perhaps the stator died on it's own, needed a jump because of that (failure to charge) and needed it replaced after.
    I wonder if it's worth making a dedicated storage compartment for it. Like a foam box. Just like the Home Depot foam you use to insulate a house.
    Or something cheap that already exists to insulate instead of making it.
    Like a lunchbox.
    Jumpstarter in a lunchbox, inside seat storage. Even has a convenient carry handle because lunchbox.
    Carhartt has good insulating jackets. Hydroflask has good insulating water bottles. I bet they make a lunchbox. But pricier than something from the kids section at Target with a Paw Patrol logo on it.
    I imagine insulation (Hydroflask uses air) simply slows the rate of temperature coming in by a day or two.
    Cold water will stay cold for a day, but not a week.
    Sometimes AZ cools down at night, sometimes not so much.
    I'm not sure if the "24 hours of insulation" would help keep the jumpstarter cool. To survive hot daytime
  6. Jun 9, 2022 at 3:54 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    I would never, ever, buy a popular lithium battery based product on Amazon. Their counterfeit control is abysmal and highly rated lithium battery packs are one of the most common counterfeit products. Because Amazon mixes all their inventory it is impossible to avoid a counterfeit. Even if you carefully select the seller to be Amazon or even NOCO the reality is that Amazon will ship you whatever inventory they have closest to you with the same UPC. So you pick “Ships from Amazon” but what you may actually get is inventory from “Super Lucky Best Buy Battery” because that inventory lives in the distribution center closest to your house.
    Unfortunately big lithium batteries are not an item to go looking for a good deal on. Suck it up and purchase directly from the NOCO site or you run the risk of getting a counterfeit product that could be a ticking time bomb.
    As to the NOCO I have the GB40 and have used it a handful of times on various vehicles. Works great! I’ve even had to use it on a very dead battery and it had no problems (you do have to turn off its reverse polarity protection when jumping a very dead battery). I store my truck on the other side of the country in a hot desert and bring the GB40 in my carry on (you can not put lithium batteries in checked luggage) in case I arrive to a dead battery.
    JGO likes this.
  7. Jun 9, 2022 at 5:35 AM
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
  8. Jun 9, 2022 at 5:36 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    NOCO does run sales, just like most companies do. They were just on sale over memorial day.
    Mine live in the cars because they won't do anygood sitting at home in a climate controlled environment.
  9. Jun 9, 2022 at 7:19 AM
    Waasheem
    Waasheem
    2007 xrunner
    There's battery less jump starters that use a capacitor. I got one and the gb70, if I'm grabbing just 1 it's the noco. Sometimes I'll use both at the same time.
  10. Jun 9, 2022 at 7:25 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I've kept the GB40 in the truck for over a year, it lives behind the rear seat fully immersed in those Texas summer temperatures. Last time I used it was to jump a fellow camper at altitude, on a 20-ish degree morning. Did its job perfectly.
    b_r_o and JGO like this.
  11. Jun 9, 2022 at 7:29 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  12. Jun 9, 2022 at 7:39 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Musubi3 likes this.
  13. Jun 9, 2022 at 7:41 AM
    Regnar
    Regnar Well-Known Member
    Kodiak,AK
    2014 DCSB PreRunner SR5
    I have the GB 40 and went on a 2 week vacation this Christams. My family must have left the dome light on as nothing would work. So out in the middle of the parking lot I grab the pack, hook it up. Show battery has a fault ( means dead dead) so I switched to manual and in 20 degree weather the truck fired right up. I have jump friends and people at the gas station without problems. I will always have one in the truck. Even ran a 12 USB cord so it charges when the truck is on.
  14. Jun 9, 2022 at 7:51 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Also have the GB40 and it’s been great. Used several times on other peoples cars.
    Also, they make an attachment you can leave connected to your battery and plug the jump starter directly into it, if you find yourself jumping your truck/wife’s car/sons car often.
  15. Jun 9, 2022 at 8:05 AM
    plurpimpin
    PDX
    Just remembered. I got my GB40 on Amazon prime day for a substantial discount. IIRC prime day is in July so you can save some bucks if you wait a few more weeks.
    Sandman614 likes this.
  16. Jun 9, 2022 at 8:23 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    I got the same one. Bailed/helped many people including my riding lawn mower. Lol
    But great quality
  17. Jun 9, 2022 at 8:42 AM
    Sandman614
    Tim
    '06 SR5 Off Road
  18. Jun 9, 2022 at 8:45 AM
    davidstacoma
    David
    NC
  19. Jun 9, 2022 at 8:59 AM
    SlumberingBear
    SlumberingBear Well-Known Member
    21 TRD Off-Road 4x4 M/T
    Bilstein lift
  20. Jun 9, 2022 at 9:00 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    I now have 2 GB's, one I have had a few years, now in our old Subaroo our son drives, and the new bigger on in my vehicle. We had a friend that was having some issue and her battery died daily, so I lent it to her while she saved up a couple weeks for the repair bill. After he issue was fixed, she bought her own a few weeks later.
    We also use them camping to charge phones and charge the GB using a cheap solar panel.
