Jumper Cables
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shyanne’s Taco, Aug 20, 2020.
  1. Aug 20, 2020 at 11:52 AM
    Shyanne’s Taco
    Shyanne’s Taco [OP] Active Member
    Shyanne
    2017 Tacoma
    So.. Tacoma’s shouldn’t jump start (older) Cars ?!! Last time I’ll be nice enough. Someone told me it can burn out my computer. Is this true ?
    Yikes !
  2. Aug 20, 2020 at 11:55 AM
    Provist
    Provist Well-Known Member
    2020-TRD-OR-4X4-AT-DCSB-QS
  3. Aug 20, 2020 at 12:32 PM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    It’s possible, especially if someone doesn’t know what they’re doing. I’ll only jump start my own or a friends car. For everyone else I carry a jump box.
  4. Aug 20, 2020 at 12:48 PM
    JaysTRDsport
    JaysTRDsport Well-Known Member
    AJ
    2020 Tacoma Trd sport 4x4 6spd manual
    Toyo off road tires
    Any car or truck you Take the risk & can burn your computer if you jump it while it’s running all you have to do to be safe is shut the engine off make sure you connect the positive & Ground correct then start up your truck rev it to about 3k while jumping it & will be ok FYi
  5. Aug 20, 2020 at 2:09 PM
    Kev250R
    Kevin
    Orange, So.Cal.
    Good suggestions, I’ll add that I turn-off all my electronics and set the A/C Blower to Low or 1. I don’t generally find it necessary to rev my engine unless I’m trying to jump the Diesel engine in my work truck (F-550). I use really thick Jumper Cables as well.
    Big tall dave likes this.
  6. Aug 20, 2020 at 2:27 PM
    Shyanne’s Taco
    Shyanne
    2017 Tacoma
  7. Aug 20, 2020 at 2:30 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Not hard. Turn it off. Connect cables correctly. Start truck. Start dead vehicle. Turn your truck off. Disconnect cables. Move on.
    Guys, it's not a new thing. It could happen 25 years ago if you fucked it up.
  8. Aug 20, 2020 at 2:39 PM
    Shyanne’s Taco
    Shyanne
    2017 Tacoma
    Except, they say to Not Connect the cables directly to your battery but to a metal part on your truck- Connecting directly to battery can cause a short Or ruin your computer (if dead car is an older model) apparently this is directed to Newer model cars jumping old cars. Who knew
    hiPSI[QUOTED] likes this.
  9. Aug 20, 2020 at 2:42 PM
    ToyodaTruck
    ToyodaTruck Well-Known Member
    2019 TRD Sport
    I guess I been doing it wrong my whole life. I learn something new today.
  10. Aug 20, 2020 at 2:43 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Again, same thing could happen 25 years ago. Nothing to do with Tacoma and everything to do with Ohms Law.
  11. Aug 20, 2020 at 2:43 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Get yourself a jumper pack.
    tonered likes this.
  12. Aug 20, 2020 at 2:47 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    This, all day, everyday:
    Too easy, protected, and useful for a bunch of other stuff, like mood lighting:
    Jumpers just take up space and are otherwise useless anymore.
  13. Aug 20, 2020 at 2:48 PM
    Hobbs
    Yep…
    Mood lighting is my primary concern. Truck ain't gotta run to "set the mood." ;)
    G8R_Taco and tonered[QUOTED] like this.
  14. Aug 20, 2020 at 2:49 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    On the spot!
    That, and a good mating call: :burp:
    G8R_Taco and Hobbs[QUOTED] like this.
  15. Aug 20, 2020 at 2:50 PM
    Hobbs
    Yep…
    :burp::burp:
    G8R_Taco likes this.
  16. Aug 20, 2020 at 2:51 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :rofl::rofl::rofl:
    :duh:
    Hobbs[QUOTED] likes this.
  17. Aug 20, 2020 at 4:08 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I'm not an electronics expert but, "you have two alternators running against each other" doesn't sound like it makes sense.
    davidstacoma and Skydvrr like this.
  18. Aug 22, 2020 at 8:09 AM
    avi8or_co
    avi8or_co Well-Known Member
    2019 Cavalry Blue TRD Sport, 2023 Lexus IS500
    +1 on the jump box. Mine has a couple USB’s, a cig lighter socket, and a work light on it as well. Like the video said, it’ll yell at you if you don’t hook it up right and won’t turn on. I take it out and plug it in every month or so that way it’s good if I ever need it. I helped an employee at basspro with it while I was on my way out a while back, he had a Ram 2500 and it had him running in 2 min.
    helix66, CusterFan and mac84 like this.
  19. Aug 22, 2020 at 8:37 AM
    PilotguyPA28
    PilotguyPA28 Well-Known Member
    Trip
    2020 Metallic Gray Limited
  20. Aug 22, 2020 at 8:46 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    I work construction and we have to jump all kinds of equipment in the winter and we never shut the truck off .
    ian rogers and Frankenstuff like this.
