JL Fiberglass/MDF sub woofer box
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by JPDud2, May 19, 2013.
  1. May 19, 2013 at 4:55 PM
    JPDud2
    JPDud2 [OP] Active Member
    Little Rock, AR
    2011 Debagged TRD Sport 4x4
    Stereo: 2 JL 8W3v3 subs 2 JL 6.5 C5 coax 2 JL 6.5 C5 components JL HD 900.5 amp Pioneer AVH 2400 Exterior: Access bed cover TRD skid plate Painted valance Painted fog sleeves 6000k HID headlamps 6000K HID fogs Avid rock sliders 3" SST lift Terra Grappler 285/70r/17
    Custom made for 2011 tacoma...but will fit most gen 2. Front is fiberglass and concaved to fit behid the seat and to produce the correct firing angle. The back is 3/4 inch MDF. This box was built for quality!!! It will house most 8 inch subs but this one was specifically designed for JL 8W3's. I had a JL stealthbox with 10W1's...but this box sounded much cleaner and louder.
    Hate to get rid of it, but bought a different truck.
    This sale is for th ebox only. SUBS NOT INCLUDED. $225 for local pick up. Custom fiberglass boxes usually go for $450 or so, but I need to get started on my project and need the money. You can pay for shipping if you want....but that is going to be expensive.
    Pray4Mojo likes this.
  2. May 19, 2013 at 5:43 PM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    How much you think it weighs? Could you get a shipping quote to 85715?
  3. May 20, 2013 at 7:39 AM
    SRT Nate
    SRT Nate Well-Known Member
    Nathan
    Titusville, FL
    10 PreRunner DCSB TRD Sport
    6K Hid Headlights, 3K Hid Foglights, Black Housing Headlights and Smoked Fog Lights, Access Rollup Tonneau Cover, Debadged, K&N Intake, OEM Roof Rack
    Wow that's a beautiful setup!! I wouldn't mind checking out the shipping cost as well. I'll check it out once you post the estimated weight of the box.
    Thanks,
    Nate
  4. May 20, 2013 at 1:50 PM
    JPDud2
    Little Rock, AR
    I'll post the estimated weight when I get home tonight. I will consider selling the subs too...as my new truck will have 10W3's...but these subs are about 8 months old. I rarely have them at high levels---but most folks are shy about buying used subs. I just know the 8W3's sound amazing and you won't be dissappointed.
  5. May 20, 2013 at 6:08 PM
    JPDud2
    Little Rock, AR
    sorry guys---gona have to delay the exact weight measurement (scale broken). i'll have to take it to work tomorrow to be exact but if you plan for 30 lbs it's gonna be real close to that. th eproblem with shipping is weight but bulk....it's an odd shaped piece.
  6. May 20, 2013 at 7:05 PM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    beautiful setup...GLWS
  7. May 23, 2013 at 4:54 PM
    TRD Toy85
    TRD Toy85 Well-Known Member
    CT
    loaded 2013 TRD sport
    Looks like a nice box, good luck with the sale wish you were local .
  8. May 24, 2013 at 2:01 PM
    lakerfan
    lakerfan Well-Known Member
    Doug
    Castaic,CA
    09 DBL CAB PRERUNNER SPORT,Mag Grey.
    Sway away 2.5 coilovers, Maxtrac spindles, Dakar rear leafs, 18x9 Moto metals.
    How much for the box and subs.
  9. May 26, 2013 at 5:19 PM
    williegreen33
    williegreen33 Active Member
  10. May 27, 2013 at 7:24 PM
    JPDud2
    Little Rock, AR
    PM'd
