Jerry can mount options
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doughnut Spaghetti, Feb 13, 2018.
  1. Feb 13, 2018 at 10:11 AM
    Doughnut Spaghetti
    Doughnut Spaghetti [OP] Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Looking for a good way to mount a Jerry can in the bed of my Tacoma. How are you guys doing this?
    Something like this would be great:
  2. Feb 13, 2018 at 10:13 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
  3. Feb 13, 2018 at 10:14 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
  4. Feb 13, 2018 at 7:55 PM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I did something similar, but used the d-ring in the floor. I put two rings in the channel, one at the rear and the other ahead of where the can sits. I took an ordinary ratchet strap and added an extra hook. One hook goes in the rear strap. The strap then goes around the top of the can where the second hook catches the forward ring. The hook at the mechanism end goes into the d-ring on the floor. The can is held in across the front at the top and diagonally across the front. I generally put a ground cloth over the can to protect it from the side of the bed and the strap mechanism. Crank it down and it stays put.
  5. Feb 14, 2018 at 3:48 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    My only concern with the D-Ring setup is security. Was looking for something I could lock. Preferably metal straps, but I think the D-Ring may work for now.
  6. Feb 14, 2018 at 4:29 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  7. Feb 14, 2018 at 5:51 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    One thing I'd recommend (but haven't found the time to do it) is getting your gas can lined with Line-X. Of course, just the exterior away from the spout area. This does a couple of things for you. It keeps it from rubbing through it's own paint as it vibrates around in the truck bed. Additionally, the rubbery surface provides extra grip against the surface you're trying to secure it against. I found that the painted surface of the can against the composite bed moves around A LOT unless you really cinch the strap or bungee cord tight. This will solve that issue.
    Seems like an easy way to improve the overall quality of the can and make transport easier.
    CoDawwg likes this.
  8. Feb 14, 2018 at 7:02 AM
    OZ-T
    Peter North
    British Columbia
    Scepter MFC's are plactic and the way I strap mine it doesn't move at all
  9. Feb 14, 2018 at 7:06 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Do those come with a spout? If so, how do you like it?
  10. Feb 14, 2018 at 7:08 AM
    OZ-T
    Peter North
    British Columbia
    The spout is seperate from the can , they are great
  11. Feb 14, 2018 at 10:57 AM
    demo243
    demo243 Well-Known Member
    Devon
    Topsfield MA
    2015 DCLB TRD 4x4
    The spout is separate from the can, but works well... the only catch with the scepter MFCs is getting your hands on them in the states...
    There is a guy who sells used military surplus ones on the "other" buy and sell or you need to find a buddy in Canada to buy a couple and ship them down to you - the latter being the better option since they are pretty reasonable brand new and readily available in Canada. I scored a pair of Ebay a while back, but last time I checked to pick up a 3rd they were outrageously expensive. Im hoping my summer adventures take me up to Canada this year and Ill just buy another one while there.
  12. Apr 23, 2021 at 8:12 AM
    Sheepnick1
    Sheepnick1 TacoJerry.com
    Nick
    Lynchburg Virginia
    2019 Tacoma trd off road
    I didn't know this thread existed! I just made my own custom mount system that seems to work really well! Check this out guys.
    www.TacoJerry.com
  13. Jul 29, 2022 at 9:59 PM
    JB92109
    JB92109 Active Member
    Joe
    2007 Tacoma Sport 4 Door
    Rough Country Lift + 35" Mickey Thompson, Fab Fours Bumper, Superwinch 9.5k Talon, Dreamcatcher+Gunrack
    I have four jerry cans for water and two for fuel. I wanted a rack that would hold all of them in place, keep them secure while driving on trails, and prevent theft. This is what I came up with. Total material cost from Home Depot was about $350.
