Jeep jk 5 on 4.5 wheel spacers HELP!
Discussion in '5 Lug' started by Minnis12, Jul 21, 2013.
  1. Jul 21, 2013 at 10:03 AM
    Minnis12
    Minnis12 [OP] Well-Known Member
    Blanchard, La
    '09 Tacoma BASE 2.7L i4
    de-flapped, Pro-Flow Super V muffler, Pilot offroad lights with 7 color changing LED's, fog lights
    Hey all, I recently purchased some jeep wheel spacer that wave the right bolt pattern but upon installation I ran I into a problem. The center bore size on the spacer is just a few millimeters larger than that of my rim. It fits in the hub no problem just not the inside of the rim. I've been searching all night and I can't find anything about it. I know i saw a build a while back where the guy did a write up on how he got his jeep rims to fit and I can't find it for the life of me. Does anyone know what I can do about this issue of had anyone else run into this issue and how did you fix it? I'm gonna call a machine shop this week but if there is a way around spending the extra money I'm all for it. Thanks in advance!
  2. Jul 21, 2013 at 10:19 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    According to this site, Jeep JK wheels are 5x5.0", while earlier Wranglers are 5x4.5". http://www.myboltpattern.com/bolt-pattern-guide/
    So if the wheel spacer doesn't change the bolt circle, then you can run only pre-JK wheels. Also, pre-JK wheel studs are 1/2"-20 thread, while Toyota is 12x1.5mm, so you will need non-Toyota lugnuts.
    You can get hubcentric rings to bridge the gap between your 67.1 mm hub and the Jeep spacer's 71.5 mm center bore. Based on the chart here, PN 71-6706 should work.
    http://www.gorilla-auto.com/hub-centric-rings-page-02
    Under $7 on Amazon: http://www.amazon.com/dp/B00280BJDW
  3. Jul 21, 2013 at 10:23 AM
    Minnis12
    Blanchard, La
    The pattern on them is 5 on 4.5. They are for an older model so your probly right on the old wrangler.
  4. Jul 21, 2013 at 10:25 AM
    Minnis12
    Blanchard, La
    The hub centric rings won't work because my rim is smaller bore is smaller than the spacers bore.
  5. Jul 21, 2013 at 10:34 AM
    KenLyns
    Belly of the Beast
    I thought you wanted to run Jeep wheels. If you wanted to run Tacoma wheels, you should've bought H&R spacers for Mazdas or Nissans with the correct center bore. ;)
    At this point the cheapest solution would be to take it to a machine shop and enlarge the bore in your wheels to 71.5 mm.
  6. Jul 21, 2013 at 10:42 AM
    Minnis12
    Blanchard, La
    The ring on the spacer has a Very wide lip so I'm gonna take them to the machine shop with my spare and see if they can shave it down. I'm going to measure it in a minute but it is just a few mm off.
  7. Jul 21, 2013 at 10:44 AM
    KenLyns
    Belly of the Beast
    If the lip is gone, then you lose the hubcentric locating feature. You can get wobbles at highway speeds and such.
  8. Jul 21, 2013 at 10:53 AM
    Minnis12
    Blanchard, La
    I measured from outside to outside of the ring on the spacer and it's 76.2 mm which is about 1/2" larger... Kinda bummed right now. I'm searching Craigslist for jeep rims though.
  9. Jul 21, 2013 at 11:07 AM
    KenLyns
    Belly of the Beast
    76.2 mm is not a Jeep center bore size... What spacers did you actually buy?
  10. Jul 21, 2013 at 11:38 AM
    Stupid hurts.
    Stupid hurts. Hoogie boogie!
    Steven
    So☆Cal
    '07 5-Lug Impluse Red Pearl Access Cab 2WD
    American Motorsports Front Long Travel Kit, Total Chaos Rear Dual Shock Hoop Kit, Engage 50T Leaf Pack, Engage Front & Rear Hangers, American Motorsports Shackles
  11. Jul 21, 2013 at 1:13 PM
    Minnis12
    Blanchard, La
    Alright the box says for a jeep but doesn't say which one but I'm just gonna return them and I got another deal that I'm gonna do m thanks for the help though man I really appreciate it.
