JBL subwoofer location and upgrading all speakers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoTim85, Dec 3, 2020.
  1. Dec 3, 2020 at 8:43 PM
    TacoTim85
    TacoTim85 [OP] Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    I know this topic has been discussed many times but...
    Anyone have a picture of the stock JBL subwoofer location? I cannot find this online anywhere. Considering getting a truck that has the premium audio (I know it sucks), but I did not look behind the rear seats.
    Does the sub occupy the space that would otherwise be part of the storage bin?
    Or is it behind the plastic storage bins (unseen) and you have the same storage bin capacity as non-JBL trucks?
    My other question, can someone point me in the direction of a link to some good information about exactly what the challenges are when upgrading all the speakers in the JBL system? I've read there are some challenges with wiring, but I don't know the specifics. Let's just say if I wanted to upgrade my speakers and keep the same head unit/subwoofer... this isn't as easy as plugging in new speakers and done. So what needs to be changed? Point me in the right direction please.
  2. Dec 3, 2020 at 8:50 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    This is a 2nd gen, but its pretty much the same. It takes up a good amount of the rear space.
    As for upgrading the JBL system
    The headunit sends a digital signal to the factory amp (non-JBL doesnt have this). The fader and crossover points are all handled inside the amp, so its not so easy to replace the factory amp with a aftermarket one.
    The speakers them selves each run on their own run of wires to the amp. So the dash tweeters have wires that go to the amp, the door speakers have wires that go to the amp. On the non-JBL systems, the wires come from the headunit to the dash tweeters, then to the door woofers. Both ways can cause some issues when upgrading. On the JBL system, the amp provides the crossover points for the speakers, so just swapping the dash speakers with new tweeters will result in blown tweeters as the crossover point is too low for a tweeter.
    The JBL system also uses 2 ohm speakers, they are a little harder to find, but they are around.
    If your plan is to upgrade and keep the factory headunit, then get the non-JBL system. If you plan to upgrade and replace the headunit, it doesnt matter as much, but you will end up with lots of extra wires in the back where the factory amp normally goes.
    Now if you plan to do as you said and just replace the speakers, keeping everything else. Then you will need to find a 2 or 3 ohm 6x9 woofer for the front doors, then the dash speakers you will want to find a 2 or 3 ohm 3.5 inch coaxial speaker (you will have to cut the dash to fit them) Or if you can find a 2.5 inch full range, but thats getting much harder to find. Rear is a 6.5 inch 2 or 3 ohm coaxial speaker.
    Pedro2598, max_o and TheAredub like this.
  3. Dec 3, 2020 at 8:54 PM
    TacoTim85
    Wow this is exactly what I needed to figure out. It would have taken me quite a while to dig up this info so thank you! That thing takes up all the useful storage space. I have so much shit back there in my non jbl truck. I would not wanna give up the storage
  4. Dec 3, 2020 at 9:02 PM
    TacoTim85
    This is my non JBL truck. Wouldn't wanna lose this space really. [​IMG]
    SpeySquatch likes this.
  5. Dec 3, 2020 at 9:28 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    I have the JBL but in retrospect I'd be just as happy with new speakers and one of those little kicker key amps. When I bought my truck I didn't even know those were a thing, haven't bought car stereo stuff in probably 10+ years.
    Pedro2598 and TacoTim85[OP] like this.
  6. Dec 7, 2020 at 5:48 PM
    atlasot
    atlasot Member
    KO
    Tacoma
    Anyone have the JBL now? I had a 2016 limited, which sounded decent, but I just bought a 2021 and I swear it sounds different. Not as clear and way less subwoofer... I did not have much over half on the sub on my 2016 and it sounded good, the 2021 just sounds different.. Same source of music
  7. Dec 7, 2020 at 5:52 PM
    max_o
    max_o Well-Known Member
    Colorado
    2018 Silver Sky DCSB OR
    I have a 2018 with JBL and it is garage. All of it is going into the Fuck-It Bucket. Working up a plan to replace all of it now. Check the Audio thread for the Pioneer 6600NEX if you decide to replace the headunit. Looks almost stock.
  8. Dec 7, 2020 at 5:54 PM
    tommygs3
    tommygs3 Well-Known Member
    tommy
    18 tacoma limited
    Fox 2.0 - KDmax tune - 5.29 revolution
    i got jbl on my 18 limited.. upgraded to the kicker tweeters on the dash and it sounded better..
  9. Dec 7, 2020 at 6:10 PM
    Hooper89
    I don’t see why newer would be different its all the same shit.
  10. Dec 7, 2020 at 6:38 PM
    ljerr2
    ljerr2 Well-Known Member
    Iowa
    2020 Tacoma TRD Pro
    If you're not after audiophile sound, you can upgrade the sub along with a separate sub amp and get pretty decent bass for what it is. I've done this in my 2015 and I like it. Way more punch in the low end, but there's a definite limit.
    I was going to do the exact same thing in my 2020, but that project is now on hold until I see what OEM Audio Plus comes out with next week. They are supposed to have a completely upgraded system that fully integrates with the factory JBL setup.
  11. Dec 8, 2020 at 3:56 PM
    atlasot
    atlasot Member
    KO
    Tacoma
    Thanks!
  12. Dec 8, 2020 at 7:08 PM
    daltondrose
    daltondrose Well-Known Member
    Dalton
    Forest Grove, OR
    2019 Tacoma TRD Pro Voodoo Blue, 2008 FJ MT Sand Storm / White
    • Victory 4x4 front Strike Bumper • Warn Winch Zeon 10 Synthetic • White Knuckle Offroad Rock Rails • Prinsu Full Rack System front and rear • ARB On Board Twin Air Compressor • Nitro 5:29 gears w ARB Air Lockers • 315 70/17 BFG KM3 • 17” Wheels KMC XD with Matching Spare • Decked Storage System • SnugTop Canopy with Windoors • Expedition One Rear Bumper with Dual Swing Outs • Baja Designs Rock Lights • Switch Pros SP 9100 • Victory 4x4 LED Light Bar • Front Baja Designs Driving Lights • Rear Baja Designs Flood Lights • Body Mount Chop (installed by Accessory Outfitters in Aloha, OR) • OME Rear LEAF Springs (soon Deaver Stage III w/ Archive Hammer Hanger) • Ride Rite Airbag System with Daystar airbag free floating cradle • Tailgate panel, Black Mountain Hatch • Tacoma Bed Stiffeners, Chaos Fab • Spindle Gusset, Chaos Fab • ICON 2.5 (58735c FR / 57805P RR) Suspension
    OEM AUDIO! Those dudes make awesome kits!
  13. Dec 9, 2020 at 6:43 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    I installed a OEM Audio Plus system in mine 3 years ago, amp, plus speakers and sub, all plug & play, its pretty sweet system, and sounds great. Have the Premium Entune HU
  14. Apr 9, 2021 at 9:25 AM
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    Old thread, but does anyone have pictures of a JBL 3rd gen double cab sub and door speaker locations possibly with covers off?
    Possibly have specs of the rear sub? i don't wanna remove it just to know what i have just to put it back together while i research the upgrade
  15. Apr 9, 2021 at 7:11 PM
    mwrood
    mwrood Well-Known Member
    2021 Voodoo Blue TRD Premium Sport
    I don’t have pictures, but I can try to explain. The door speakers are in the typical location. If you look at the door panel, they’re behind the part with the speaker grill (bunch of holes in the door panel).
    The sub and amp are behind the plastic panel behind the rear passenger seat. You can take those panels off pretty easy. There’s a few videos on YouTube about removing them. I think it’s like 4 screws along the middle (in a horizontal row). Then you just yank it out. There’s clips holding it in place. I think the drivers side has to come out before the passenger side, but you can tel by looking at what piece overlaps the other.
    Let me know if I didn’t answer your question, or if you have more.
  16. Apr 9, 2021 at 7:23 PM
    old_and_in_the_way
    old_and_in_the_way Well-Known Member
    Somewhere hot, flat and brown.
    Why not just try it first and see if it "sucks" before you rip out perfectly fine stuff and spend a bunch of bucks on something that may not be a problem after all? Is it the best OEM audio system? No, of course not. Is it better than the standard one? Yes! Does it suck? Not really...especially in this class of vehicle.
    DrFan likes this.
  17. Dec 3, 2023 at 9:34 PM
    Yambutt
    Yambutt New Member
    2017 tacoma limited
    None yet
  18. Dec 3, 2023 at 9:37 PM
    Yambutt
    Yambutt New Member
    2017 tacoma limited
    None yet
    I have 4 ohm audiofrog gs25 speakers front and rear and 4ohm dynaudio 6.5 mid woofers in the front doors and its louder and sounds way better than the 2ohm JBL. What everyone isn't considering is its not just about the ohm of a speaker but also the efficiency of them.
    As for the head unit sending a digital signal to the amps where is the d/a converer? You would actually need 2 of them since the Aux input is analog going directly to the head unit which then a A/D converter is also needed to convert the analog to digital at the head unit...lol
    Its probably a analog preamp output going to the analog amplifier to drive the analog JBL speakers lol
  19. Dec 3, 2023 at 10:59 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
