JBA Offroad control arm question
Discussion in '1st Gen. Tacomas (1995-2004)' started by ToyotaHunter, Jun 27, 2020.
  1. Jun 27, 2020 at 1:49 PM
    ToyotaHunter
    ToyotaHunter [OP] Well-Known Member
    2003 Toyota Tacoma TRD
    Hello fellow tacoma nuts I have a quick question about the JBA OFFROAD control arms. So I need to change my upper control arm but instead of putting OEM one I was thinking buying and installing aftermarket upper control arms i was seeing the JBA OFFROAD one but my questions is does my truck really need to be lifted to use these upper control arams? My truck is a 2003 4x4 double cab no lift regular hight. If you guys think the would be good I would buy them if not any other ideas of aftermarket upper arms?
    TXpro4X4, Taco critter and opteron like this.
  2. Jun 27, 2020 at 7:54 PM
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    Stock height to 2" of lift, I'd stick with OE Style control arms.
    2.75"+, then you should run some aftermarket control arms.
    High Noon and Taco critter like this.
  3. Jun 28, 2020 at 9:43 AM
    ToyotaHunter
    Taco critter likes this.
  4. Jun 28, 2020 at 9:48 AM
    ruffridha9
    ruffridha9 Well-Known Member
    Jesse
    West Coast
    2012 Tacoma base
    stock ish
    They make factory Spec’d UCAs if you don’t have a lift.
  5. Jun 28, 2020 at 9:48 AM
    yaaj2005
    yaaj2005 Well-Known Member
    Fang
    Sacrament, CA
    2014 Toyota Tacoma TRD
    If you do not plan to lift, or already lifted, just go OEM...
  6. Jun 28, 2020 at 2:13 PM
    yaaj2005
    Fang
    Sacrament, CA
    You can not go wrong with
    JBA Offroad control arm ...
  7. Jun 28, 2020 at 6:31 PM
    mattvivsound
    Southern MD
    I went with JBA UCA's on my OME 882 coils, straight forward install.
    The original alignment was my best attempt after the Lift (I also replaced the lower balljoints and tie rods).
    TXpro4X4, Kolter45 and Taco critter like this.
  8. Jul 2, 2020 at 5:45 PM
    ToyotaHunter
    Awesome thanks for the advice I think im just gonna bite the bullet and lift my truck a bit it need a suspension overall anyways lol
    tonyclifton likes this.
  9. Jul 14, 2020 at 7:59 PM
    petecarlson
    petecarlson Well-Known Member
    2002 4X4 DC TRD
    Got a link to that?
  10. Jul 14, 2020 at 8:07 PM
    petecarlson
    2002 4X4 DC TRD
    What metrics are you using to come up with those numbers? It would be nice to see the geometry of different UCAs plotted out.
    Lets say you used these at stock* height. What would the issues be?
    *What is stock height anyway? Is a TRD SR5 a different height then a non TRD SR5 tacoma?
    I'm new to this and in no rush to decide on UCAs but want to make an informed decision that would let me lift a few inches down the road if I want to.
  11. Jul 14, 2020 at 8:20 PM
    ruffridha9
    Jesse
    West Coast
    2012 Tacoma base
    stock ish
  12. Jul 14, 2020 at 8:32 PM
    petecarlson
    2002 4X4 DC TRD
  13. Jul 14, 2020 at 8:40 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  14. Jul 14, 2020 at 8:41 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'd only recommend them if you're lifted due to the difference in caster that's meant for lifted vehicles.
    If you're at stock height, then there's no need for anyone to replace their UCAs unless they're rusted out bad.
  15. Jul 14, 2020 at 8:51 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Spend your money on beer and a nice steak. No reason to put aftermarket UCAs on unless you're lifted.
    Get a can of rustoleum if you want the look...
  16. Jul 15, 2020 at 6:39 AM
    petecarlson
    2002 4X4 DC TRD
    These https://jbaoffroad.com/toyota/tacoma/jba-upper-control-arms-ucas.html are cheaper then OEM and my upper control arms are pretty beat up. Frame and lowers got replaced but the uppers have almost 20 years of midwest winters on them. I could buy some nice steak and beers with the price difference and don't want to drop $750 on OEM if JBA will work AND give me flexibility to lift later. No one seems to have a straight answer to this question and my upper control arms aren't completely falling apart so for now I'm just going to do my LBJs, have it aligned, and figure out how much room I have to work with. Hopefully JBA or someone here can provide the geometry change vs stock and I can figure it out.
  17. Jul 15, 2020 at 8:24 AM
    jbrandt
    Justin
    $750? where are you getting ripped off to spend $750 on OEM uppers?
    https://parts.camelbacktoyota.com/v...4-gas/front-suspension--suspension-components
    $230 each. Same as the set of JBAs.
    And that's if you buy new. I wish I still had my take offs when I did my UCAs, I'd have sold you my rust free ones for $40 each. Hell, a six pack and we'd call it even.
  18. Jul 15, 2020 at 8:59 AM
    petecarlson
    2002 4X4 DC TRD
    I was looking at complete assemblies with ball joints - https://parts.mcgeorgetoyota.com/oe...hY29tYSZ5PTIwMDImdD1iYXNlJmU9My00bC12Ni1nYXM=
    Closer to 700. Not quite apples to apples since the complete assy has the other HW as well. The JBA comes with bushings and ball joints. so a better comp would be UCA + Ball joint which runs ~564 total at the site you linked. Still more then the JBA. I'd rather just buy a whole part with bushings then spending time pressing them out/in.
    I'd really rather understand the geometry of the JBA vs OEM and make a decision as to wether this part will work or not.
    If points U (upper pivot) and L (lower pivot) are the two points of your camber line, when you lift the truck, point L moves down in a straight line which obviously decreases the camber angle. I assume that the JBA must move point U backwards somewhat on the truck to counter this. The question is how far back? If I know that delta I can check my current alignment and measure how much camber adjustment I have to work with and then calculate what range of camber I can get with the JBAs. if it is more the 4 degrees then I'd say they won't work. Less then I'd likely go with them.
  19. Jul 15, 2020 at 9:07 AM
    petecarlson
    2002 4X4 DC TRD
  20. Jul 15, 2020 at 9:23 AM
    jbrandt
    Justin
    Fair enough. Not that you always need to replace the BJs, tho. Or just get the Moogs if you want to save some money.
    Sure, if your UCAs are jacked up the calculus is different. But unless they're rust buckets, that's pretty rare.
    I still say that even if you're lifted, you may still not even need them depending on how much lift you have.
    Most will recommend doing your lift, then getting it aligned and let the numbers decide if you need UCAs.
    petecarlson[QUOTED] likes this.
