Jacking truck with 4x4 engaged?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pontoon, Apr 1, 2018.
  1. Apr 1, 2018 at 5:47 PM
    pontoon
    pontoon [OP] Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    If I engage 4x4 high, and turn the truck off in gear (1st), then jack both rear wheels off the ground using the rear differential, will the truck be able to roll? I know if I jacked the front up in 2wd the transmission and parking brake would keep the rear wheels from rolling, but what I’m wondering is if 4x4 can prevent the front wheels from rolling.
    Edit: just so you know, I would of course chock the front wheels, but what I’m wondering is if the 4x4 can act as a secondary safety measure.
  2. Apr 1, 2018 at 5:50 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    It will roll back and forth a little bit (few inches). Best bet is to throw a block of wood or something against the tire also.
    pontoon[OP] likes this.
  3. Apr 1, 2018 at 5:52 PM
    Indy
    Indy Master of all I survey.
    It wont move much.
  4. Apr 1, 2018 at 6:00 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    If in a pinch lock ebrake auto and manual.
    You can change tires but do much else. You will not roll. Still though block your tires.
  5. Apr 2, 2018 at 12:18 PM
    TacosConQueso
    TacosConQueso Well-Known Member
    Brian
    1999 Sierra Beige Tacoma 4x4
    I do that all the time when Im lifting my truck, moves just a little but not much. Makes taking the front rims off a lot easier too if your working up there. As others have mentioned, this with the parking brake and wheel chocks is best
  6. Apr 2, 2018 at 3:23 PM
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Dear Pontoon,
    Remember once you engage four wheel drive, the front wheels do the same thing as the back wheels. If you jack up your rear end with your truck engaged in four wheel drive and your transmission in first gear with your foot off the clutch, the truck will remain stationary. The transmission will prevent the front wheels from going forward or reverse.
    Good Luck,
    Paul
  7. Apr 3, 2018 at 11:19 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Safety first - always chock the tires
    TacomaJunkie8691 and ChadsPride like this.
  8. Apr 3, 2018 at 2:41 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    1,000 times this. ^^^
    Always chock the wheels, even if you're only jacking up the front end, and using the E-brake.
    After you jack it up, be sure to give it the ol jiggle test before you start working on it, too.
