Jacked up my oil pan :(
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ScissorMeTimbers, Jun 9, 2013.
  1. Jun 9, 2013 at 9:25 AM
    ScissorMeTimbers
    ScissorMeTimbers [OP] Crème fraîche.
    Colorado Springs
    18 Cement V6 DC TRD Off-Road.
    So there I was, changing my oil just like I do every 5k miles and thinking everything was A-OK. I was wrong. I finished, cleaned up and went on with my life. A few hours later I notice a oil puddle under the truck and after closer inspection notice that it's leaking from my oil drain plug. I tightened the plug and notice that despite feeling tight it continues to turn...and turn...and turn. Thinking I was probably just breaking it more I stopped. Drained all of my new Mobil 1 5w-30 and removed the plug, it looks good...but it still won't tighten down. Bought a new drain plug just in case, and it does the same thing. So I can only assume my oil pan has bad threads, guess I'l be buying a new one on Monday when Toyota opens. Just my luck considering I'll be taking my truck on the 1100 mile drive to my new home in Ft. Walton Beach, FL in 12 days.
    Is my troubleshooting analysis pretty solid? I thought I'd post here to make sure I'm doing the right thing. Anyone ever change out your oil pan, looks like it should be pretty easy but being an aircraft maintainer for 6 years I've learned that the easiest task can sometimes become the hardest.
    Thanks!
  2. Jun 9, 2013 at 9:26 AM
    Large
    Large Red
    Maybe over-torque? Not sure..
  3. Jun 9, 2013 at 9:30 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
    Sounds like stripped threads. New pan is in order.
  4. Jun 9, 2013 at 9:32 AM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    if its not the drain plug itself its the pan thats stripped. Also curious as to how much its going to be for a new oil pan.
  5. Jun 9, 2013 at 9:52 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
  6. Jun 9, 2013 at 9:54 AM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  7. Jun 9, 2013 at 9:59 AM
    Seer
    Seer Well-Known Member
    Tom
    Bayfield, CO
    13 Double Cab 4x4 stock
    You could also go the Helicoil route.
  8. Jun 9, 2013 at 10:32 AM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
    You could tap the whole the next size bigger if possible?
  9. Jun 9, 2013 at 10:49 AM
    byrd
    byrd Unknown
    David
    Kansas
    '06 Access SR5 4x4 6 speed
    New pan stealer price
    ENGINE / ENGINE / ENGINE PARTS / Lower oil pan
    Lower oil pan 4.0 LITER, w/o X-Runner
    MSRP Core ? Online Price
    $64.71 $0.00 $64.71
    I would try the above methods 1st and use teflon tape.
  10. Jun 9, 2013 at 10:53 AM
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    Re-tap it. I used to work in a little lube bay when I was a kid, and we had to re-tap several. Mostly due to prior service being done at the Wally World, and the goons there reinstalling the plug with an impact.
  11. Jun 9, 2013 at 11:52 AM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    Yeah impact wrenches aren't for kids... Retap even though the price isn't bad you don't want to replace the oil pan unless necessary
  12. Jun 9, 2013 at 11:56 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    I did the same thing in my old Civic in high school. Get an oversized oil pan bolt like posted above and you should be fine. Mine lasted over 5 years and 60,000 miles without a drop of oil.
  13. Jun 9, 2013 at 12:04 PM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    Just reiterating try the oversize plug! Worked for me on a different car, but a cheap and easy fix. I also replaced a oil pan when the oversize plug wouldn't work.
  14. Jun 9, 2013 at 12:08 PM
    ScissorMeTimbers
    Colorado Springs
    Thanks everyone, appreciate the input and I will be headed to Autozone to pick that up. Is that the correct size I should be getting, gives me the "doesn't fit vehicle" but I feel like I can't trust that. I will update you guys after I give it a try!
  15. Jun 9, 2013 at 12:20 PM
    2013TuRD
    2013TuRD Well-Known Member
    Bruce
    SW BC
    TRD OFF ROAD
    ^This.
  16. Jun 9, 2013 at 2:35 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    The over sized oil plugs are in the "help" section. Happens everyday
  17. Jun 9, 2013 at 2:46 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    They make oversize plugs for things like that instead of having to buy an oil pan. I have used them and they work fine. Just do not over tighten. :D
  18. Jun 9, 2013 at 2:50 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Put in a tapered/oversize plug. And replace pan later
  19. Jun 9, 2013 at 2:55 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    Replace pan and install ya a Fumoto valve and never worry about stripping out your bolt hole again.
  20. Jun 9, 2013 at 3:25 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Given that I have the time and money I would replace the pan. I've never understood how one strips the threads on an oil pan. I have done an uncountable number of oil changes in my life and have never stripped one. I never use a torque wrench on them either. I just snug it up to a grunt and a fart and call it good. They do not need to be excessively tight; that is what the gasket is for.
