jack points
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mattmctree, Oct 16, 2018.
  1. Oct 16, 2018 at 3:56 PM
    mattmctree
    mattmctree [OP] Well-Known Member
    2009 black tacoma trd
    stupid question but where do i place my floor jack on the front on the truck to jack it up ? i can jack the rear up no problem on the differential but cant seem to find a decent spot on the front/
    danarello likes this.
  2. Oct 16, 2018 at 4:04 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Should be a sorta donut looking spot between the IFS arms. Put the jack in the middle, and both tires come off the ground. Or use the LCA arms to just get 1 off.
    mtmudrunner likes this.
  3. Oct 16, 2018 at 4:05 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Control arms are a good spot
  4. Oct 16, 2018 at 4:09 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Mid shaft :rolleyes:
    Kidding. Frame and control arms.
  5. Oct 16, 2018 at 4:11 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's this. This picture is without the stock skid on, but even with it on, it's still visible.
    JNFT1, CCinABQ, diverpat and 6 others like this.
  6. Oct 16, 2018 at 4:19 PM
    Gunshot-6A
    Conner
    Everett, WA
    That was the first thought that came to mind. Followed shortly by oil pan :devil:
  7. Oct 16, 2018 at 4:21 PM
    DrFunker
    DrFunker Well-Known Member
    :facepalm:
  8. Oct 16, 2018 at 4:26 PM
    mattmctree
    perfect thanks guys
  9. Oct 16, 2018 at 4:34 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    Because the stock jack barely gives enough lift for anything and I don't trust the rusty frame...I put an 8 inch 2x4 at an angle to match the frame right where the red is here and jack from that spot so I can then put a jack stand under it on the wood so it doesn't go right through the frame :)
    mcbain and Alexely999 like this.
  10. Oct 16, 2018 at 5:29 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
  11. Oct 17, 2018 at 6:17 AM
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    What? I thought that you could put the jack on any part of the frame that was solid.
  12. Oct 17, 2018 at 6:23 AM
    TreeFortRichard
    Brian
    you could, but these points are more balanced...the majority of the weight favors "falling" towards the grounded wheels so if lean on the jacked up quarter the truck doesn't fall..
    Norton and jross20[QUOTED] like this.
  13. Oct 17, 2018 at 6:23 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You can! Which is handy in certain situations, but when you wanna get both front tires up at once then you need to use the front jack point.
    jross20[QUOTED] likes this.
  14. Oct 17, 2018 at 6:25 AM
    jross20
    Georgia
    Ahhh I see what you're both talking about.
    Okay well no worries because I use like 5 or 6 jack stands because other wise I'm scared
    :anonymous:
    Toyoma17 and Trucko like this.
  15. Oct 17, 2018 at 6:42 AM
    TreeFortRichard
    Brian
    don't forget to use wheel chocks...saved my ass once when i had the front end off the ground and the truck lurched....
  16. Oct 17, 2018 at 7:02 AM
    jross20
    Georgia
    Oh don't worry I used 2 per wheel!
    danarello and Toyoma17 like this.
  17. May 20, 2020 at 7:43 PM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    my driveway (avatar) is just barely sloped to the street, but its pretty flat.
    Tonight I put chocks behind both rear wheels, and then lifted the front end from the center support. I lowered the front end back down on 2 Jackstands at the Factory spots on each side. All good. I gave the front end the hand shake and it seems all solid.
    I walk around the back and see that during the front end jacking up process the jack must have pulled the vehicle forward a few inches because those rear (triangle plastic wedge) chocks are not touching the tires! WTF!
    So I quickly chocked Both sides of the back tires and all is still good to go.... solid, but that gap from tire to chock at first was not what I was expecting to see!!
