It got me too - Drive start control malfunction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NIckk, Jul 7, 2022.
  1. Jul 7, 2022 at 7:48 AM
    NIckk
    NIckk [OP] Active Member
    2018 Silver Tacoma TRD Sport
    nothing yet!
    On Tuesday morning my 2018 sport would crank but not start with the Drive/Start Control malfunction error. Fuses and relays appear fine and I had to resort to having it towed to a dealer. I will update the findings to benefit others.(fuel pump recall was performed a few years back)
    cruxofthebisquit likes this.
  2. Jul 9, 2022 at 1:05 PM
    NIckk
    nothing yet!
    the PopnLock is somehow shorting the communication to the ECM. Currently the harness is back to stock but now I have several O2 sensor codes, any ideas? The dealer was of little help, they just got unplugged the popnlock and it started and that's all they were able to do
  3. Jul 9, 2022 at 1:40 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Are any wires damaged?
  4. Jul 9, 2022 at 1:43 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I’m guessing I’m not the only one unfamiliar with the “Drive/Start Control malfunction error” and “PopnLock”.
    o313 and shakerhood like this.
  5. Jul 9, 2022 at 2:49 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Sorry about the troubles, OP. I’m curious, did the PopnLock actuator relay have a flyback diode attached to it to prevent voltage spikes?
  6. Jul 10, 2022 at 12:20 PM
    NIckk
    nothing yet!
    so no frayed wires, I re-connected the Pop-n-Lock and and it starts/runs fine however I still have O2 sensor codes.
    This happened the morning after a fairly significant electrical storm, I'm starting to wonder if it was struck
    OnHartung'sRoad likes this.
  7. Jul 10, 2022 at 4:08 PM
    OnHartung'sRoad
    Any damage on the truck? Lightening would leave a mark on itC8D44C28-00DC-4B88-A900-C0FE46F1B652.jpg
    Im wondering if the actuator on the PopnLock caused a voltage spike -
    That’s why I mentioned the diode protection.
    o313 likes this.
  8. Jul 10, 2022 at 4:17 PM
    NIckk
    nothing yet!
    No obvious lightning strike evidence. The popnlock has 2 ATO fuses inline that did not blow. I don't know if there's a diode in the servo mechanism
  9. Jul 10, 2022 at 4:38 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    What is the Drive/Start Control malfunction error? is that a common issue with 3rd gens?
  10. Jul 10, 2022 at 4:57 PM
    OnHartung'sRoad
    A flyback diode just needs to go across the positive and negative leads going to it- like this:
  11. Jul 10, 2022 at 5:05 PM
    OnHartung'sRoad
    Apparently some people are getting the error code from system issues- the 10amp STOP fuse blows, PopnLock kits, and shorts in the brake tail light wiring and bulbs. It’s not common, just looks like it as TW tends to be a magnet where a few people out of all the hundreds of thousands without an issue go to get help with something…
  12. Jul 10, 2022 at 5:19 PM
    TexasWhiteIce
    Texas
    Lol
  13. Jul 11, 2022 at 10:18 AM
    NIckk
    nothing yet!
    no blown fuses, the issue is a bit crypic. I'll take it to an independent shop to see what can be found
  14. Jul 14, 2022 at 9:26 AM
    NIckk
    nothing yet!
    no update yet, going to indy shop in 2 weeks
  15. Aug 5, 2022 at 9:35 AM
    NIckk
    nothing yet!
    update:
    The indy shop ran tests and determined it to be an ECU and said to take it to a dealer since it's still under warranty(51K miles currently). Indy shop didn't charge. Second dealer checked it, ran test with support and determined it was a bad ECU, ECU replaced and back on the road for no charge. Bredemann Toyota came through with great support and turnaround time. Leader Toyota can suck it
    Irons and Canadian Caber like this.
