Is VIAIR the portable compressor to get?
Discussion in 'Recovery' started by alexh, Nov 13, 2017.
  1. Nov 13, 2017 at 1:01 PM
    alexh
    alexh [OP] Well-Known Member
    1998 TRD
    bski22 likes this.
  2. Nov 13, 2017 at 1:03 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I have the 88p and it's a great compressor, though it has blown a few fuses on me. I use it a lot though. Just keep spares in the truck. Its not the fastest compressor but gets all 4 of my 32" tires filled up in 10 min. The 400p would be better at that I'm sure. The 88p was only $70 or so IIRC.
    Edit: I was being generous, probably more like 15 minutes lol.
  3. Nov 17, 2017 at 10:24 AM
    geoyota760
    geoyota760 Allergic to pavement
    PHOENIX, AZ
    2019 TRD OR
    5.29 Nitros Bilstein ICON Kansei BFG
    I have owned the 400P for 5 years, used it extensively here in the SoCal deserts as well as Utah, Arizona, etc.
    Never had an issue with the pump or the storage bag. Never blown a fuse or cycled out due to heat.
    I did have to replace the valve/chuck/hose after three years, as the lock over feature eventually wore out and would not hold onto my valve stems any longer. This was a major PITA for a few trips as I had to hold the valve head onto each stem as I inflated.
    Fixed now, and I keep my 400P as a back up/trail loaner to my Powertank.
    3pooches, Bruce988jl and bski22 like this.
  4. Nov 18, 2017 at 9:51 AM
    TacoMoose
    TacoMoose Well-Known Member
    2017 Tacoma OR
    i have the 88p and i like it so far. had it for 2 years now, i keep it in the toolbox in the truck if i ever need it. used it several times at the beach to air up when the line was a mile long at the pump station. it does heat up after inflating 2 tires. its not the quickest compressor but it gets the job done. filled my 265/70/17s to 40psi in 3-4 min. if you follow the instructions of how long to use it and how long to let it cool down in between uses this compressor will last you for years since most of the thing is made up of metal or aluminum vs the cheap slime compressor where even the piston is made of plastic. so to wrap this up, if your going to use it several times a month, id get something bigger that will inflate it faster without taking breaks to cool it down. but if your like me that keeps it in the truck just incase u ever need it and only gonna use it several times a year then this will be perfect reliable compressor.
    Hamer95USA likes this.
  5. Nov 21, 2017 at 5:45 AM
    networkraptor
    networkraptor Well-Known Member
    2023 NBM ORP
    I have the 85p and it works great on my stock tires. If I had bigger tires then I would get one that attached to my battery instead of the interior power outlet. Theses are great little compressors.
  6. Nov 21, 2017 at 5:49 PM
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
    I have the 88p and have 265/75/16's. from 15 psi up to 30 psi, takes about 10 minutes for all 4 corners. the heat sink on top does get hot after the first tire or two. I use it when I'm in the woods but I'll default to the air pumps in the parking lots at the beach since they are much faster. Max run time is 25 minutes so, the time it takes to fill up is under 25 minutes. Plus there's usually a minute or two to switch between tires. 400 probably has a longer max duty cycle time since it's longer. 88p wouldn't be something I let a few other trucks fill up with since it has a 25minute max run time. anyway, I'm sure the 400 is going to be that much better, but the 88p is only $50 right now on Amazon.
    If I had bigger tires, I'd have to mount a higher capcity, maybe with a tank because it would take too long and I'd run out of patience.
    When I'm on soft dirt or gravel, I do like to place it on the wooden board I keep in the truck for the jack. the vibration can make it dig in a bit in soft sirt or throw around some small bits of pebble in gravel that might get pulled in to the intake. I'm sure the 400 vibrates just as much.
    mhshark likes this.
  7. Nov 25, 2017 at 12:12 PM
    Tdkrum5
    Tdkrum5 New TRD OR for me.
    Ted
    Oly, Wa/Sun City West AZ.
    2024 TRD OR
    New ride 2024 TRD OR. Old ride 2014 Icon Stage 5, 265/75/16 BFG AT KO2, Fuel wheels, KMFB sliders,BAMF trilogy skids, Baja Design Squadron Sport WC
    I have the 300 and have not had any problems.
  8. Dec 10, 2017 at 7:12 PM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    I'd get a Smittybilt compressor over a Viair any day. The Viars are good compressors, but I have a couple buddies with the Smitty's and they kick the Viairs butt. I have had a good experience with my ARB, but they are pretty spendy.
  9. Dec 10, 2017 at 7:19 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    I think Viair is the brand to get but I'm not sure about that compressor. I have dual Viair 444Cs onboard and they can fill a tire really fast and have never blown fuses or been anything but perfect runners. The only downside to them vs the ARB is the ARB is smaller, but because of their smaller package they need a fan and tend to overheat when that (computer fan) inevitably fails. I'd see if you can find a single compressor based of the 400 series or maybe a single 444C if you aren't looking for speed.
    Pic for fun...
  10. Dec 13, 2017 at 7:23 AM
    jzh11
    jzh11 Well-Known Member
    Orlando, FL
    17 SR5 DCSB
    I just bought the 88P on Amazon for $43 shipped. How/where do you guys store yours?
  11. Dec 13, 2017 at 7:25 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    That's a nice setup. Good to know that high performance and dependability are there with a setup like this.
  12. Dec 13, 2017 at 7:36 AM
    Frito
    Frito Well-Known Member
    People here mentioned more than once that these are not the fastest compressors.... What is ?
    I have a 400P-RV. For as often as I use it, I think it does a pretty good job but never really compared it to anything else.
  13. Dec 14, 2017 at 8:14 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Is it THE compressor to get? No, probably not, since which one is right your depends on a great many things. What you will use it for and budget are one course the big ones.
    It’s certainly not the MOST expensive, as there are some redonk expensive ones out there, but it aint no harbor freight one, either. It seems to be a great middle/high end brand that works for many people. I’ve been drooling over their ~$200 kit with all the fittings and an air tank, too for an on board air system.
    People ask about the fastest compressor, but honestly, if you want a fast fillup, IMO, get an air tank. You can probably find a really fast compressor, but I’m betting a decent one with a 5 or so gallon tank will fill up tires way faster than any compressor by itself.
    Frito likes this.
  14. Dec 18, 2017 at 10:03 AM
    BillBraski
    BillBraski Potato
    VA Tidewater Area
    2017 White TRD Off Road
    Tacoma Tailgate Lettering LED interior lights
  15. Dec 18, 2017 at 9:12 PM
    jbrandt
    Justin
    Yeah, that looks like a nice one, but for my money, I'd rather set up a 3ish gallon OBA system with a much cheaper (read: lower duty cycle) compressor. That should be plenty to fill 4 tires on the tank alone, so you don't need a 100% duty cycle. You can have the tank fill at your leisure while you're driving (or fill it at home). It's a LOT more work, but I'm a project kind of person, so it's worth it to me.
  16. Dec 27, 2017 at 4:12 PM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Amazon seems the best price....300P....$125
  17. Dec 28, 2017 at 1:16 PM
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
  18. Jan 9, 2018 at 7:50 AM
    ted44
    ted44 Member
    I have a 450P and it works quite well. I think VIAIR is a great value. If budget is less of a concern, then I like ExtremeAire. They are rugged workhorses. My needs have tended toward a portable design that can be moved from vehicle to vehicle, so take that into account. Once you go to a permanent, on-board air setup, especially with a tank, choices change. Do not discount a CO2 tank set-up for price and convenience. I have no local source for tank fill-up, so I have not made that choice, but it can be a good option.
  19. Jan 15, 2018 at 6:54 PM
    Bruce988jl
    Bruce988jl Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    I have the 400p and have used it extensively for the last two years for everything from my 33inch tires to my buddies 35's with no issues.
    3pooches likes this.
  20. Jan 23, 2018 at 10:01 AM
    Tacuache345
    Tacuache345 Well-Known Member
    Mario
    Los Angeles, CA.
    2016 DCSBOR/BBP
    None
    I have the 400p and works really good.
