Is Transmission Temp Check Mode Necessary?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacotoosdays, May 15, 2024.
  1. May 15, 2024 at 8:34 AM
    tacotoosdays
    tacotoosdays [OP] Member
    2020 TRD Off Road
    Did a drain/fill on my 2020 OR a few weeks ago and, for some reason (user error probably) I had a lot of trouble getting the truck into temp check. I finally was able to do it and the whole process went well afterwards.
    I had planned to do another drain/fill again just to get more fresh fluid in the transmission this weekend. My question is: Is temp check mode necessary or can I just use my scan tool and wait until the transmission pan sensor reads 95-100 degrees and pop the check plug? Is temp check mode some mystical thing that's doing something else in the background or is it just simply telling me when the temp is ready?
  2. May 15, 2024 at 10:14 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Nope; all temp trans check mode does is give a visual indicator for those without a scantool. If you have Techstream or something that can read pan ATF temp, you are good to go.
  3. May 15, 2024 at 10:18 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    All you need is a source for a reliable and accurate temp reading. I use my scanguage when servicing the trans in my GX.
    SH10151 and tacotoosdays[OP] like this.
  4. May 15, 2024 at 10:18 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    How many quarts did you use on drain and fill? Sorry I am off topic just would like to know.
  5. May 15, 2024 at 10:23 AM
    tacotoosdays
    2020 TRD Off Road
    Thanks for the replies guys! I figured it just had to serve as an indicator but I ran across a couple of comments that made me think otherwise. That'll make it much easier to check.
    @23YOTA I drained 2.5 quarts. I've seen anywhere from 2.5 to 3.5 but I think it just depends how much ends up in the pan when you shut the engine off. I added half a quart more during fill and ended up draining about 1/2 quart so I was back a 2.5 quarts.
    shotgunbilly420 and t0p_d0g like this.
  6. May 15, 2024 at 10:26 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    Thank you!
  7. May 15, 2024 at 10:39 AM
    Pungo1
    Pungo1 Well-Known Member
    Mark
    I've always wondered why you have to measure at all if it's new and you're the one doing the first drain/fill. Drain a specific amount, put precisely that much back in. I'm guessing the only reason you'd measure the temp is to verify the factory actually had the level correct.
    boston23 likes this.
  8. May 15, 2024 at 10:41 AM
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Unferfilled trans fluid from the factory has been documented countless times.
    boston23 and Pungo1[QUOTED] like this.
  9. May 15, 2024 at 11:03 AM
    Captain Dirty Beard
    Captain Dirty Beard Well-Known Member
    Colorado
    2023 Ice Cap Tacoma TRD Off Road
    OTT tune
  10. May 15, 2024 at 11:42 AM
    tacotoosdays
    2020 TRD Off Road
    @Pungo1 It’s interesting because the service manual says you can fill to the fill hole and then drain the excess…so the fear of overfilling is technically non-existent…but I’m sure we all don’t want to spend hundred of dollars on excessive fluid so measuring and overfilling is just a way to avoid waste.
    @Captain Dirty Beard The gun I have was really inaccurate. It was off a good 10 degrees. I have a scan tool app but wanted to see how accurate my gun reading was.
  11. May 15, 2024 at 12:16 PM
    SilverTRD Sport
    SilverTRD Sport Well-Known Member
    Houston, TX
    2016 TRD Drowned now 2017 Inferno TRD Sport
    Is 95-100 degrees F correct?
  12. May 15, 2024 at 12:37 PM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    Or if you have a leak. It's not common, but you never know. With no dipstick it's the only chance to check the level.
  13. May 15, 2024 at 12:49 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    if you have a scan tool, you’re good to go. That’s all you need for the level check.
  14. May 15, 2024 at 1:10 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    95-113F to be precise.
  15. May 15, 2024 at 2:17 PM
    tastethepoison
    tastethepoison Well-Known Member
    Kansas City
    2016 Inferno Sport 4x4 DCSB
    Does temp really matter? I mean how much does liquid expand?
  16. May 15, 2024 at 3:26 PM
    tacotoosdays
    2020 TRD Off Road
    @SilverTRD Sport The service manual says between 95-113. My truck entered temp check mode when the oil pan transmission temp on my scanner app was about 98-100 degrees.
  17. May 15, 2024 at 3:28 PM
    tacotoosdays
    2020 TRD Off Road
    @tastethepoison Liquid expands quite a bit. Coolant levels can fall/rise in your reservoir if the ambient temps swing even 10-15 degrees. Of course this liquid is suspended in a column (coolant hoses, etc.) so the level you see is more sensitive. But temps matter. I have a Mazda I did a drain/fill and the temp needed to be 120 degrees to get a proper reading. All of this is in the service manuals for these cars.
  18. May 15, 2024 at 3:58 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    OP, does your tranny have the traditional black thin gauge pan at the bottom of the transmission? If yes, an IR gun will be within four degrees of the internal ATF pan sensor reading, based on my readings comparing my IR to my UltraGauge reading in my 2nd gen. If you don't have the thin gauge pan, the IR reading will not be accurate.
    jmneill and faawrenchbndr like this.
  19. May 15, 2024 at 4:12 PM
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    What about expansion of the parts of the transmission when heated? My thinking is the small pathways will be affected when heating up and change the fluid level. Maybe a tranny expert can comment.
  20. May 15, 2024 at 4:38 PM
    tacotoosdays
    2020 TRD Off Road
    @Chuy Yeah, it seems thin. It's definitely black. I have a cheap IR gun so I don't necessarily trust it but comparing its reading to the scan tool they were off almost 10 degrees. Glad to know I can just use the scan tool app and be done with the temp check mode. Frustrating experience for me.
    Chuy and faawrenchbndr like this.
