Is this HG’s or lower intake plenum?
Discussion in '1st Gen. Tacomas (1995-2004)' started by spencerdiesel, Dec 29, 2021.
  1. Dec 29, 2021 at 12:24 PM
    spencerdiesel
    spencerdiesel [OP] Well-Known Member
    Spencer
    '97 ext cab flat bed 3.4 5 speed
    Still in the midst of my lower plenum/ valve clearance job. I would like y’all’s opinions on this showing the valve covers (definitely leaking), engine valley/ heads.
    I have wiped/ mopped up several ounces of what I assume to be coolant out of the valley before taking this video. The whole reason for the tear down was a coolant leak believed to be from the lower plenum.
    1st bit of video is just showing the leaking VC’s.
  2. Dec 29, 2021 at 1:13 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    From the pics I'd say oil is from valve cover gaskets, coolant is from intake valley gaskets. Could stop there and see. Going full head gasket change is at least going to double the time and cost.
  3. Dec 29, 2021 at 3:50 PM
    spencerdiesel
    Spencer
    Thanks those are my thoughts as well. What do you think about the glistening spots at the head gasket?
  4. Dec 29, 2021 at 4:08 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Not sure. How many miles on the engine? Any exhaust smell or smoke? Loss of oil?
  5. Dec 29, 2021 at 4:38 PM
    spencerdiesel
    Spencer
    She’s no spring chicken, 278k. Credit where it’s due though, only “uses” a quart of oil every 4,000 miles WITH bothe VC’s leaking.
    96BlueTacos likes this.
  6. Dec 29, 2021 at 6:22 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    OK, I'd change the head gasket then. Make sure you get new head bolts. Don't forget the washers, keep the valve caps in the same order, and follow the loosen and torque specs to a tee.
  7. Dec 29, 2021 at 7:08 PM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    She’s only a late spring chicken.
    For what it’s worth, I was losing at least that much oil when I bought ol’ blue with ~260xxx miles. I always thought that it was a combination of burning and valve cover leaks (which I still have not felt like dealing with).
    But the real culprit was the rear main seal, which I discovered was where the vast majority of my oil loss was. After I fixed that, the valve covers turn out to actually leak a very small amount compared to what I thought and I use a quart in more like 6-8,000 miles with 378,000 miles.
    I just needed to add a quart at 378,000 so I will watch more closely for how long it takes to go through a quart.
    But ya, you could be leaking out your rear main seal, which you have to drop the transmission to replace. If you have a manual truck, when you do your clutch, do your rear main seal.
    edit:added quote
  8. Dec 31, 2021 at 7:06 PM
    spencerdiesel
    Spencer
    Thanks for the info you guys! Fantastic engines, the dipstick in my my ‘02 with 220k reads the same as it did 5k miles ago with no oil added!
  9. Jan 1, 2022 at 12:56 AM
    Glamisman
    Glamisman Well-Known Member
    If it was me I would take the thermostat bypass tube off and replace the gasket just because you are in there. I would also replace the knock sensor harness for the same reason. While not “maintenance” items the bypass tube gasket is one of those “I am having to add coolant but I cant find the leak” things.
  10. Jan 1, 2022 at 6:30 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    valve cover job is on my spring 2022 list of things to do. anyone have a part number for this gasket.
  11. Jan 1, 2022 at 7:21 PM
    spencerdiesel
    Spencer
    Good idea Glamisman, I’m doing the knock pigtail and both sensors. One of the sensors crumbled when I was carefully trying to disconnect. I’ll be doing the bypass as well!
    If the heads end up being warped, what’s usually recommended? Can they be decked and run a custom thickness gasket?
  12. Jan 2, 2022 at 8:12 AM
    Glamisman
    if you are talking warpage where the lower intake sits that usually isn’t a problem. What usually is a problem is corrosion pits around the water crossover passages on both the heads and lower intake. Depending on how deep they are and if they extend to where they aren’t supposed to there are different approaches to the fix.
  13. Jan 4, 2022 at 6:49 PM
    spencerdiesel
    Spencer
    I filled the coolant passages in the heads and let it sit for a day. It’s definitely time for a head gasket job.
    I was wanting to purchase a machinist straight edge to check the heads a block, but the more I read I believe I’ll have the machine shop check the heads.
    I assume the head bolts aren’t to be re used? I haven’t found yet if they’re torque to yield or not.
    Got the timing belt and plate off today, hopefully tomorrow I can pull exhaust and maybe the heads.
