Is this a Bent Spindle or Bent LCA?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AdamT23, May 10, 2022.
  1. May 10, 2022 at 9:57 AM
    AdamT23
    AdamT23 [OP] Well-Known Member
    Adam
    Fresno, CA
    2017 Silver Tacoma TRD Off Road 4X4 Double Cab
    Hey TW!!
    I’m really in need of some help with my truck. So recently, my truck was involved in a Hit n Run. Causing damaged to my fender, bumper and suspension. I’ve already bought a new fender and front bumper and the only thing left is the suspension component. Brief summary is that, passenger wheel is not aligned and parallel with my driver side. Driver side wheel is facing straightforward, while my passenger is facing towards the right. I don’t know if it’s a bent LCA or a spindle. Truck is leaning towards the passenger side now so it’s hard for me to tell what the issue is. I’ve jacked up the truck and checked the passenger side, everything looks fine besides the negative camber, but maybe I’m missing something here.
    If I can get advice on what it could be, it’ll be greatly appreciated.
    Also, didn’t tell insurance about it because I wanted to do it myself, just upgrading things from stock components
  2. May 10, 2022 at 9:58 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Pic under the truck would tell you/us right away.
    six5crèéd likes this.
  3. May 10, 2022 at 9:59 AM
    AdamT23
    Adam
    Fresno, CA
    I’ll go get some photos
  4. May 10, 2022 at 10:03 AM
    AdamT23
    Adam
    Fresno, CA
    Photos been uploaded
  5. May 10, 2022 at 10:07 AM
    geekhouse23
    Could just be out of alignment/bent spindle. You're going to need a new tire. The upper control arm is rubbing into the tire pretty good.
    AdamT23[OP] likes this.
  6. May 10, 2022 at 10:08 AM
    AdamT23
    Adam
    Fresno, CA
    Yup, luckily I wasn’t too far from home, was able to drive it home, but yeah, like some people said, could be knocked out of alignment or a bent spindle
  7. May 10, 2022 at 10:11 AM
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    I have dirt kings UCA’s,LCA’s and Fox 2.5’s going up for sale shortly if you are looking to mod while your at it…
  8. May 10, 2022 at 10:11 AM
    geekhouse23
    You might be able to check the cam bolts on the LCA to see if the bolts/tabs were moved.
    AdamT23[QUOTED][OP] likes this.
  9. May 10, 2022 at 10:12 AM
    AdamT23
    Adam
    Fresno, CA
    I’ve tried checking it already, both sides look identical, but I’ll give it another look
  10. May 10, 2022 at 10:13 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    That's indicative of a bent spindle. Other things bent wouldn't change the spatial relationship between the hub and the upper ball joint.
  11. May 10, 2022 at 10:13 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    take the tire off both sides compare and inspect. I cant tell you what looks wrong vs right with just a few pictures. It should be obvious when you see both sides
  12. May 10, 2022 at 10:14 AM
    AdamT23
    Adam
    Fresno, CA
    Greatly appreciated! I’ll probably do this upcoming weekend and check both sides
  13. May 10, 2022 at 10:14 AM
    AdamT23
    Adam
    Fresno, CA
    Thank you!
  14. May 10, 2022 at 10:15 AM
    geekhouse23
    Depending on how hard the hit was, yes. Hard to know what all was affected. It is out of alignment, so that led me to believe it's possible the LCA's were affected in some minor way at least. If you just got an alignment you would be changing your tail if the LCA was bent.
    Spindle is definitely bent.
  15. May 10, 2022 at 10:18 AM
    AdamT23
    Adam
    Fresno, CA
    Literally just got an alignment a month before LMFAO!
    geekhouse23[QUOTED] likes this.
  16. May 10, 2022 at 10:21 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^The cam bolts probably got knocked out of position in the crash, so that'll affect toe and camber. It happens often enough off-roading with larger tires, let alone crash forces.
  17. May 10, 2022 at 10:23 AM
    AdamT23
    Adam
    Fresno, CA
    Thanks guys! I’ll most likely order a new Passenger side Spindle along with some gussets this weekend once I get both sides and confirm them. Once it’s confirm I’ll place the order, and be on my way after.
  18. May 10, 2022 at 10:24 AM
    AY_ARONTRD
    Aaron
    Murrieta ,CA
    AdamT23[OP] and auskip07 like this.
  19. May 10, 2022 at 10:25 AM
    AdamT23
    Adam
    Fresno, CA
    Any link or info?
  20. May 10, 2022 at 10:32 AM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    May I ask why you are not taking it to a shop to get repairs if it was a hit and run?
