Is there anything that can mimick a seized engine?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdrew97030, Apr 9, 2023.
  1. Apr 9, 2023 at 2:06 AM
    jdrew97030
    jdrew97030 [OP] New Member
    Justin
    2006 Silver Toyota Tacoma TRD Sport
    3” lift 33’s Diamond plate toolbox The truck is pretty stock, actually.
    So I recently replaced my timing chain and guides. The truck ran great for 3 weeks or so. Then one night driving in the snow, it shut off on me twice and restsrted both times. Then i pulled in and got gas and oil. It started up and drove for about 10 blocks, then just died. It coasted to a stop and thre CEL came on. It was a camshaft or crankshaft position sensor circuit error and woundnt turn over. When you turned the key all you heard was a click.
    After I got it towed home, I tried to turn the motor by hand with a breaker bar and it won't move. I had someone tow me down the road in D, 3, 2, and 1st and same result. Afyer that, I soaked all 6 cylinders, without spark plugs, in ATF for 2 weeks and tried marvel's mystery oil after that. I pulled the valve covers and oil pan and there's nothing visibly wrong. I replaced the bank 2 camshaft position sensor and fixed a few questionable nicks in the harness. The truck still won't turn over. Is there anything that would mimic the truck being seized (not being able to turn the motor by hand) without it actually being seized?
    *EDIT* Shit. I am sorry about the terrible spelling (goddammit, autocorrect) in that post. I had a couple too many shots of tequila, I guess.
  2. Apr 9, 2023 at 2:07 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    English please…
  3. Apr 9, 2023 at 2:46 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    if it wont turn over by hand... thats not good. was the chain and guides factory or aftermarket? it sounds like the chain may have skipped time and valves may have kissed pistons
    SR-71A likes this.
  4. Apr 9, 2023 at 6:15 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you can't turn the crank by hand its likely
    f--ked. Did it run out of oil somehow?
    Sorry..
    SR-71A and TnShooter like this.
  5. Apr 9, 2023 at 6:16 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    A sensor problem will not physically lock up an engine, if you can't turn it with a bar something is mechanically wrong.
    Your gona have to tear into it and see what happened.
  6. Apr 9, 2023 at 6:38 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Chain laying in a heap at the bottom of the case?
    Bpietro likes this.
  7. Apr 9, 2023 at 6:39 AM
    Bpietro
    Bpietro Well-Known Member
    2023 Trd sport 4x4
    I’d start by checking the timing again. Sounds like that’s your culprit. May of jumped time
  8. Apr 9, 2023 at 6:40 AM
    Bpietro
    2023 Trd sport 4x4
    That’s what I was thinking also.
  9. Apr 9, 2023 at 6:49 AM
    Bishop84
    Bishop84 Well-Known Member
    The worst part is, if its auto, getting the engine out is way more difficult due to the converter bolts.
    It's time for a full tear down. Valve covers and chain cover to start.
    TnShooter and Torspd like this.
  10. Apr 9, 2023 at 7:36 AM
    EME
    EME Well-Known Member
    Nick
    05 Tacoma sport
    have seen an alternator seize (not on a Toyota though)and lock up an engine, so a quick easy check is remove the belt
    goforbroke123, Leomania and Dm93 like this.
  11. Apr 9, 2023 at 7:50 AM
    Microtus
    Microtus Well-Known Member
    Robert
    Michigan U.P.
    2023 DCSB TRDOR Lunar Rock
    Lots of white smoke, laid rubber and subsequent flat spotting on tires? :eek:
    SR-71A likes this.
  12. Apr 9, 2023 at 9:42 AM
    Brandon###
    Brandon### Well-Known Member
    You let someone tow you in gear at 60 mph?!
    What was that supposed to accomplish? If you were trying to kill an engine, you probably succeeded.
  13. Apr 9, 2023 at 9:54 AM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
  14. Apr 9, 2023 at 9:59 AM
    Boneretreiver
    Boneretreiver Well-Known Member
    Tom
    Eastern WA.
    2010 AC TRD Sport 4x4
    Stop working on engines..
    Blockhead likes this.
  15. Apr 9, 2023 at 10:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    It is in neutral when you attempt this, correct?
    And with the plugs out to prevent compression resistance?
    If the engine can't spin, and you are in gear, this seems pretty unlikely.
    As well as dangerous to even try.
    Your soaking trick is helpful on engines that have corrosion from sitting for extensive time with no lubrication. Not helpful on a recently running engine that has just laid down.
    b_r_o and winkel like this.
  16. Apr 9, 2023 at 10:21 AM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    Try (slow and easy) manually turning the engine backwards rotation. If the valves are in the way it should still turn a little.
  17. Apr 9, 2023 at 11:50 AM
    lbhsbz
    lbhsbz Well-Known Member
    Not sure how you managed to get towed 60mph, or why, in gear when the engine won't turn....you should explain that...
    But, I ran into a timing chain issue when I rebuilt the engine in my 03 4runner where the aftermarket main chain tensioner casting was too thick, the bolt(s)? only had about 2 threads to engage the block. All else was the same so I machined the outboard surfaces to where they should be and used it, but contacted the supplier and they thought it might be a consolidation between the 3.5L (car) and 4.0L (truck) tensioners and claimed they'd look into it...dunno if they did. It was an ITM timing chain set. If running around with only a couple threads holding that tensioner on, good chance it came off. There's a little inspection panel in the timing cover (4 bolts) that you can pop off to get a look at the tensioner...it's pretty painless.
  18. Apr 9, 2023 at 12:12 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    WOW. Marked to see outcome.
  19. Apr 9, 2023 at 12:18 PM
    Brandon###
    Slow and easy? No, he should tow it backwards at 70 mph in gear. That’s the only way to free it up.
    lbhsbz likes this.
  20. Apr 9, 2023 at 4:27 PM
    iiggii
    iiggii Well-Known Member
    jeff
    2010 tacoma access
    lift n radio
    jumped timing.
