Is there any reason why a 2012-2015 dash kit doesn’t fit a 2005-2011?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hans Moleman, Sep 19, 2019.
  1. Sep 19, 2019 at 4:00 AM
    Hans Moleman
    Hans Moleman [OP] Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    I’m looking at this oversized Metra dash kit http://www.metraonline.com/part/108-TO2B to install a Pioneer DMH-C5500NEX 8-inch head unit. But it says it’s only for 2012-2015 Tacomas.
    Aren’t the early and late model 2 gens dimensionally the same on the center stack except for some minor cosmetic differences like with the hazard/clock unit which I can just replace easily?
    Theoretically, wouldn’t a normal double DIN dash kit from a 2012-2015 fit a 2005-2011?
    ALI3N_123 likes this.
  2. Sep 19, 2019 at 5:38 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    In a recent thread, people indicated that a "refresh" took place in 2012. I recall the radio being part of that discussion.
  3. Sep 19, 2019 at 5:39 AM
    Taco-mama
    Taco-mama Well-Known Member
    2015 DCSB Prerunner
    Why not ask Metra?
    blu92in99 and Lester Lugnut like this.
  4. Sep 19, 2019 at 8:28 AM
    Muddinfun
    Muddinfun Well-Known Member
    They're different. If you look at the threads where people put the later stereo in the earlier truck, you'll see that they had to do some grinding on the plastic and it doesn't fit perfect.
    Hans Moleman[OP] likes this.
  5. Sep 19, 2019 at 11:44 AM
    Hans Moleman
    Bay Area, CA
    I see. I guess I will have to scrap the idea of going with the Pioneer C5500NEX.
  6. Sep 19, 2019 at 12:16 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I'm sure there's a kit that would fit your truck. Have you checked on Crutchfield?
  7. Sep 19, 2019 at 3:54 PM
    Hans Moleman
    Bay Area, CA
    Yes I did.
    There are many dash kits for the regular size double din head units with the typical 6.5 to 7" screens for 2005-2011 Tacomas.
    But the Pioneer C5500NEX is not a regular size heat unit. It has a 8" screen with doesn't fit the regular double din dash kits out there. Only Metra makes the dash kit to go with the C5500NEX but unfortunately they only list for 2012-2015 Tacomas.
  8. Sep 19, 2019 at 5:04 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Buy the kit. See if you want to do the required trimming before writing it off.
    A belt sander would work nicely in taking the plastic down.
  9. May 8, 2021 at 5:57 AM
    Fooburger
    Fooburger Well-Known Member
    Jim
    Southampton, PA
    2011 Tacoma sr5 access cab
    3” w/jba’s. LCE header w/intake spacer & hps cai tube
    Can't believe how hard it is to find people who have done this.
    Wanting the biggest flush mount screen, but scared to try an android unit.
    Guessing because its the worst time on earth to upgrade.
  10. Oct 20, 2021 at 12:48 AM
    Tac11
    Tac11 Well-Known Member
    Luis
    2011 white Tacoma sport TRD
    3" Front lift OME/5100 set at 0, 1/4 spacer on driver side CMC, BFG 285's, SCS ray 10’s -38 offset 1 inch rear block N-Fab steps Bumper Cali Raised LED light bar Cali Raised LED fog lights After market exhaust, and muffler tip Redline hood struts Tacoma Bed-liner mat Tailgate lock Tinted windows 20% HID headlights Short antenna Clazzio Seat covers Joying head unit
    Right!!!! Any luck with that dash kit?
  11. Feb 26, 2022 at 1:52 AM
    TacomaDblCab
    TacomaDblCab Well-Known Member
    Virginia
    2011 Tacoma Dbl Cab Off Road
    Window Tint, Kenwood DDX 470, Polk Audio DXi6500 (front), Polk Audio DXi650 (rear)
    Did you ever try this to see if it would work? It looks like the radio trim itself would fit. Maybe the radio bracket is different.
  12. Feb 26, 2022 at 8:37 AM
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    I have installed a factory Nav radio from a 2014 truck in my 05. It can be done with just a little trimming of plastic. its the plastic that is behind the unit so its not visible. I dont know for sure about the application your are attempting but I imagine you can do it with just some minor trimming. If you search around there are threads showing pics of how to install the 12-15 units in the older dash.
    This thread breaks down installing the new radio in the older dash and what it took. maybe it will help you with what you are trying to do.
    https://www.tacomaworld.com/threads...tion-retrofit-diy-w-info-part-numbers.318616/
    bokch0y likes this.
