is there a trick to touching up Super White 040 ?
Discussion in 'Detailing' started by TacoTitan11, Apr 25, 2012.
  1. Apr 25, 2012 at 5:44 PM
    TacoTitan11
    TacoTitan11 [OP] Well-Known Member
    Mr. C
    North Carolina
    2012 Tacoma
    :deadhorse:
    wetsand?
    lankda?
    anyone with superwhite have good success?
  2. Apr 25, 2012 at 5:48 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Yeah, don't :mad:
    Subbed, I really hope someone has had some success with touching up a superwhite short of a professional painter!
  3. Apr 25, 2012 at 6:32 PM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    You're fortunate because it's a solid colour. Metallics/pearls are impossible to touch up, and look decent. That said, even with a solid colour, when you touch up it's going to look like a touch up does...
    I wouldn't suggest wet-sanding it, just because there isn't much clear on these trucks, and white can be a tricky colour to determine when you've sanded enough down... You can easily burn through, then you're pooched.
  4. Apr 25, 2012 at 6:37 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    You can do it. White is probably one of the easier colors to touch up.
    Fill the chip or scratch with several thin layers until it sits higher than the surrounding paint. Wet sand with the paper around your finger, just going lightly over the top of the high area - just the touch up paint. When you are flush, add a coat of clear. after it is dry, sand again, but stop before you are flush with the surrounding. It will take a while, but it is possible to do a good job.
    I did it on my wife's white car and you have to really look for it to find it. The same process on my metallic silver and it is still very visible, although protected from rust, so it's still good.
  5. Apr 25, 2012 at 6:58 PM
    4x4Tacoman05
    4x4Tacoman05 Member
    NC
    05 Double Cab LB 4x4 Sr5
    Westin bull bar, dual exhaust, 17" Ultra Wheel rims, 265/65/R17 Cooper AT3 tires, sunroof, ventshades, weathertech floormats, DVD player.
    I asked a guy who owns a shop and he said if you are just trying to touch up a small area then just cut a paper match in half lengthwise and use it to dab the paint onto the area and let gravity level it. Idk if this actually works though, I haven't tried it yet.
  6. Apr 26, 2012 at 5:20 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    good advice, thanks!!!
  7. May 14, 2012 at 12:17 PM
    Toytruckmike
    Toytruckmike Well-Known Member
    Michael
    Amarillo, Texas
    07 TRD Sport AC 6sp 4x4 Gone:18 TRD Sport 4x4 double cab. Cement
    Not much on the 07 yet. 18 is gone, but was a greata truck. TRD Pro grill, Gator FX3, Homelink mirror, Black out badges & exhaust tip, Remote start. Future TRD exhaust, skid plate.
