Is there a trick to securing these fender liner to bumper clips?
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by drewskie, Sep 5, 2023.
  1. Sep 5, 2023 at 5:59 PM
    drewskie
    drewskie [OP] Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    I can't believe I'm having so much trouble figuring this out. I'm putting the fender liners back on after fiddling with the front end for a few months, and I can't seem to get these damn push pins to go in. The clips I am talking about are the 2 piece clips that put the fender liner onto the front bumper sides. It's a little v-shaped clip with a push pin. It seems extremely self-explanatory, but after I put the fender liner on the clip it refuses to go on to the bumper. I've literally been messing with it for hours but the push pin will not go through the two pieces. I'm assuming I'm doing something wrong and it is an extremely simple process, so does anyone know what the trick is? I tried it both ways, on the bumper first, and on the liner first but no matter what the holes will not line up. I also realize it isn't very important and I can just leave it off, but that would bother my little brain too much.
  2. Sep 5, 2023 at 6:04 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  3. Sep 5, 2023 at 6:41 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Pics. Please
    drewskie[OP] likes this.
  4. Sep 5, 2023 at 6:46 PM
    drewskie
    Drew
    Burbank, CA.
    I know. I've been trying to post them but they won't load
  5. Sep 5, 2023 at 6:52 PM
    Oldie2007
    Oldie2007 Well-Known Member
    Kurt
    Lockhart, TX
  6. Sep 6, 2023 at 4:40 AM
    jpdeuce
    jpdeuce Well-Known Member
    James
    Houston
    2008 DCSB OR-6MT
    Lift, Bumpers, Sliders, Odds and Ends
    Sounds to me like he's talking about the black clips with the round center that pull out separate from the clip to remove the clip, not the ones on the flares.
    @drewskie For those black clips, they won't go in nicely with the "pin" pushed into the clip. You have to insert them with the pin pulled up, then once they are in you push the pin down. Also, some of the holes these go in may not be round and you might have to rotate the whole clip a bit to find the "key" for them to push in the hole and then press down the pin.
  7. Sep 6, 2023 at 10:17 AM
    drewskie
    Drew
    Burbank, CA.
    That's exactly what I'm talking about, and it looks like you've dealt with these before. I think I was able to get the driver's side in, but the passenger side is being a complete bitch. I've been trying to install it without the pin at all, and then inserting it later but I'll try the pin first and see if I can get it to line up and then push it in. There's no way it was made this difficult on purpose so maybe I'm just a dummy.
  8. Sep 6, 2023 at 10:23 AM
    jpdeuce
    James
    Houston
    2008 DCSB OR-6MT
    Installing without the pin is a good idea, rather than trying to keep the pin pulled out while you press the rest in.
