Is there a definitive answer on which shocks are closest to OEM?
Discussion in '1st Gen. Tacomas (1995-2004)' started by CoastieTX, May 11, 2021.
  1. May 11, 2021 at 10:56 AM
    CoastieTX
    CoastieTX [OP] Well-Known Member
    PNW
    Original owner 1998 Tacoma TRD; 3.4 V6 with 5 MT
    As my profile says, I have a 1998 TRD V6 extra cab. Suspension bits are all original, and it’s time for new shock absorbers.
    My TRD still has its factory Bilsteins. Can anyone tell me exactly which modern Bilsteins (also open to other suggestions) will preserve the truck’s ride quality and height?
    It’s my daily driver, off-roading is limited to forest and fire roads to trailheads.
    Thanks for any insight.
    LearningToFly likes this.
  2. May 11, 2021 at 11:09 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    CoastieTX[OP] likes this.
  3. May 11, 2021 at 11:20 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Those aren't the OEM shocks. They are stock replacements, but aren't the same as what is supplied from the factory. There's an older thread floating around where a guy compares them. The "OEM" ones are smaller diameter.
    4600's are still far and away the best shock to replace the OEM's with, however.
  4. May 11, 2021 at 11:25 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    If you want to preserve your truck's original ride and height, and if you plan on continuing on fire and forest roads, replace your shocks with Bilstein 4600s front and rear. Will set you back around $300.
  5. May 11, 2021 at 11:37 AM
    CoastieTX
    PNW
    Thanks for the replies. Out of curiosity, what would you say is a reasonable price to pay for installation labor on all four corners?
  6. May 11, 2021 at 6:39 PM
    jbrandt
    Justin
    It'd probably cost a few hundred bucks.
    Rear is super easy, a total no-brainer to DIY. The fronts are a little more complicated, but still DIY.
    It's not that hard. You can rent all the tools for free from most auto parts stores. Plenty of write-ups about it, too. Should only take a couple hours.
    CoastieTX[QUOTED][OP] likes this.
  7. May 11, 2021 at 6:54 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Hey I see you have a 1998 TRD. It's a bit of a rabbit hole, but consider doing a full suspension refresh if you plan on keeping the truck. It makes a big difference! Replacing the worn-out old springs made a huge improvement on my '99. New ball joints, new control arm bushings, new springs and shocks. It can be done while keeping it looking factory.
    The reason I mention it is I tried doing new ball joints, bushings and bilstein 4600 shocks and it did tighten things up a lot, but the upgraded springs and shocks took it to a whole new level by eliminating body roll and keeping the wheels planted while accelerating.
    There are a lot of resources here on the forum, if you want to learn about what others have tried. I'm very happy with my Toytec Boss kit.
  8. May 11, 2021 at 8:43 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Depending on how many miles are on your truck and considering the age of everything on the truck. Post #8 gives you some really sound advice.
  9. May 11, 2021 at 9:04 PM
    Kiloyard
    Phoenix, AZ
  10. May 12, 2021 at 6:43 AM
    CoastieTX
    PNW
  11. May 12, 2021 at 7:13 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oof
    Long due for replacement.
    General Springs offers an OEM replacement, as well as u-bolts and bushings to go with.
    MalinoisDad likes this.
  12. May 12, 2021 at 6:31 PM
    Kiloyard
    Phoenix, AZ
    Well thanks for posting those pics, @CoastieTX those are looking pretty worn out to me (but still driveable).
    Suspension gets expensive, so only you can decide if it's worth it. To give you an idea how much I spent, it was about $2000 on new springs and shocks on all four wheels, and I had spent about an equal amount on having a shop install new ball joints and control arms (bushings) on the front end, which you'll want to do if you're still on the originals.
    I can promise you it was the best money I've spent on my truck because it improved the ride so much.
  13. May 12, 2021 at 7:17 PM
    League4
    League4 Active Member
    For what it's worth, when I was replacing my front struts with an OME lift, using spring compressors and all that was so awful that if I ever do it again I'll bring the assembly to a shop (with a wall mounted compressor or something) to assemble and I'll just put the entire assembly back in.
  14. May 12, 2021 at 7:54 PM
    CoastieTX
    PNW
    So, I got an estimate or two today and got the distinct impression that they’d rather not touch the springs and just install shock absorbers. Basically, they said if none of the rear leaf springs were actually cracked and broken, and the truck wasn’t sagging, to just leave them alone.
    As far as replacement shocks go, they also said that if I used Bilstein 4600s, they couldn’t really guarantee my truck would ride like it did originally. For $480, I could order OEM shock absorbers from the local Toyota dealership and have the garage install them. I’m assuming they’re the exact same Bistein model the truck came with. The Toyota dealerships parts department told me they were Bilsteins.
    So at this point, I’m left wondering if I should take the advice I was given and just replace the shock absorbers with OEM units.
  15. May 12, 2021 at 8:31 PM
    Kiloyard
    Phoenix, AZ
    It's up to you. I've run Bilstein OEM and 4600's on my truck before I upgraded the suspension and they're the same. I'm baffled by the guy telling you to keep the 23 year old springs until they break. Did he just not want to do the job?
    I'd keep researching and reading on tacomaworld, unless you have to make a decision quick.
  16. May 12, 2021 at 10:24 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    for what it's worth. I just installed 4-4600 shocks on my 03 DC last year. My truck is completely stock, and I've had no issues with these new shocks. thicker body than the factory tokico shocks. Definitely improved the ride. But only you can decide. My rear springs are getting flat, haven't gone completely "W" just yet. But that's another project down the road.
    The 4600's will get you as close to factory without creating any lift.
  17. May 13, 2021 at 6:58 AM
    CoastieTX
    PNW
    Call me crazy, but I’m actually contemplating just using the local Toyota dealership to do this job. Especially if they can use an OEM spring set on all four corners, in addition to an OEM shock absorber set.
    I get the impression all the local garages are just extremely busy right now, and can afford to be choosy on which jobs they take on. To me, from my research and just the way the truck rides, it really does seem like it needs new leaf springs in the back, too.
  18. May 13, 2021 at 12:26 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    how many miles are on your truck. I can show you a video to install the front shocks and coil springs that really make it simple. Look at my avitar. I truly am a crippled up old man, and I did mine following a video that was simple as hell. I even re used my front coil springs. The rear shocks are really pretty simple to do. just take a little muscle and elbow grease. You can save a ton of money by not having the stealership do this job. Anyone here will be willing to walk you through any questions you might encounter.
    Abeyancer and CoastieTX[OP] like this.
  19. May 13, 2021 at 1:16 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You've been given the advice you need plenty of times over in this very thread.
    Buy the Bilstein 4600's
    Buy a new leaf pack, General Springs offers an OEM-replacement
    Buy new u bolts to go with
    Buy new bushings for your shackles
    Buy front coil springs to go with your front Bilstein 4600's
    Install yourself, it's super easy. If not, post up on the regional section and I guarantee someone will offer help.
    If you were in CA, I'd say let's knock the whole job out in a few hours.
  20. May 13, 2021 at 2:00 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    For what it’s worth, those rear springs might be sure for replacement, but don’t expect positive arch. My brand new SDs look pretty close to that
