Is their a right and left front strut
Discussion in 'Suspension' started by 09toytac, Mar 19, 2013.
  1. Mar 19, 2013 at 2:34 PM
    09toytac
    09toytac [OP] Member
    jersey shore
    09 taco 4 door long bed
    I purchased used bilstein front struts with lo mileage to replace the originals. I was told that the left strut has more spring rate so you must reinstall with the proper side. The struts i got are almost brand new but before i change em out i need to figure out which is which. I looked at both struts and they have the same numbers.Any suggestions on how to tell them apart.
  2. Mar 19, 2013 at 2:41 PM
    Large
    Large Red
    Pics? Are they OEM replacement Bilstein shocks?
  3. Mar 19, 2013 at 11:45 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    t1m829 and bigmw like this.
  4. Mar 22, 2013 at 5:22 PM
    09toytac
    jersey shore
    oem struts from 2011
  5. Mar 22, 2013 at 5:32 PM
    09toytac
    jersey shore
    is this a top view showing lower end is at the bottem of the spring on the on strut, thanks 4 ur help
  6. Mar 22, 2013 at 5:35 PM
    09toytac
    jersey shore
    is this a above view of the strut showing the end at the bottom of the strut where the spring coil starts showing the bolt placement thanks
  7. Mar 22, 2013 at 5:51 PM
    splitbolt
    NW Arkansas
    Did you buy the complete assemblies or just shocks?
    I assumed complete assemblies because you mentioned spring rate. The shaded area in the diagram I posted is the coil. See how the lower end of the coil is the same on each side, but the top hats aren't? This should give you an idea which is which.
    If you're talking about just the shock; no, there is no difference.
    Toyota parts numbers are goofy; some have specific left/right part numbers, but are actually the same part.
    http://www.toyotapartszone.com/Page...Country=(8=USA)&sectionID=&componentsID=48-03
    bigmw likes this.
  8. Mar 22, 2013 at 6:00 PM
    splitbolt
    NW Arkansas
    Yep. I superimposed it from the FSM.
    t1m829, DR_CA68 and bigmw like this.
  9. Mar 23, 2013 at 5:20 PM
    09toytac
    jersey shore
    Thankz alot didnt want to reinstall wrong good site
  10. Jan 4, 2015 at 11:43 PM
    Silvatacoma
    Silvatacoma Well-Known Member
    Hawaii
    Going by the above diagram that would make the coil with two yellow dots the left? Any help would be greatly appreciated. Thanks
  11. Sep 5, 2019 at 7:23 AM
    alva12nell
    alva12nell Member
    VA
    15 Tacoma TRD OFFROAD
    the
    struts should go in one way... so long as the bolt slides in the strut assembly should only be aligned like that in one manner.
  12. Sep 5, 2019 at 7:24 AM
    alva12nell
    alva12nell Member
    VA
    Hey man, where did you get that diagram from?
  13. Sep 5, 2019 at 7:32 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    FSM (Factory Service Manual)
  14. Sep 6, 2019 at 5:06 AM
    alva12nell
    alva12nell Member
    VA
    another questions, is there a shock absorber or rubber washer on the inside of the hat between the shock and the hat?
  15. Sep 8, 2019 at 2:00 PM
    OverBurningLand
    OverBurningLand Member
    2001 Tacoma 4WD TRD
    Hey where did you get that diagram and are there more for older models such as mine?
  16. Sep 8, 2019 at 9:19 PM
    JHart_87
    JHart_87 Member
    2008 Tacoma Prerunner Sport
    If you put them on the wrong side, the sway bar will be extremely close to (and likely to hit) the shock.
    I couldn't see any difference in the length or spring rate differences...just a potential interference issue with the sway bar.
  17. Sep 9, 2019 at 3:43 PM
    OverBurningLand
    2001 Tacoma 4WD TRD
    I was hoping that wouldn’t be the answer. But beggers can’t be choosers....
    I guess if i’m going to keep my truck I might as well buy the manual. Know of any trustable sources?
  18. Jul 28, 2020 at 1:58 AM
    Colangeli
    Colangeli Well-Known Member
    Alex
    She's a god damn trooper. 95, 3.4, lifted, welded, 'merica muffler,
    Cup holders, oh she's got a sweet feather in her bumper
    There's pdf files out there if you look hard enough
