Is the trailer hitch an OK jacking point?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2020TacomaGuy, Jul 18, 2023.
  1. Jul 18, 2023 at 11:58 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    This is a question that deserves more time than I can spare at the moment, but suffice to say, a load in motion does not equal a load not in motion. And tongue weight has far more to do with safe drivability of the truck than it does the physical limitations of the hitch itself.
    madcratebuilder and cowfootball like this.
  2. Jul 18, 2023 at 11:58 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    That's what I do. I use the hitch to lift, and then put jack stands underneath the axle, frame, etc depending on what I'm working on.
  3. Jul 18, 2023 at 12:04 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Stroke that jack eh?:)
    RustyGreen and amyracecar like this.
  4. Jul 18, 2023 at 12:14 PM
    ScrippsRanch67
    ScrippsRanch67 Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Now that is a reasoned answer. Just because something can be done, doesn't mean it's a good idea.
    Out2gtcha likes this.
  5. Jul 18, 2023 at 12:30 PM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    Don't you have wait for the suspension to stop extending to get the tires off the ground when jacking by the hitch ??? Jack under the differential for me thanks...
    BillyE, ScrippsRanch67 and 3JOH22A like this.
  6. Jul 18, 2023 at 1:20 PM
    vnix
    vnix Well-Known Member
    2021 white Tacoma DCSB XP Predator
    blind spot mirrors, center tray, bedrug, more to come
    Whoa. This thread just turned a corner it didn't need to. Especially with that pic.
  7. Jul 18, 2023 at 1:24 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Provided you recognize the risk, I don’t see how jacking by the hitch receiver is unsafe. Hopefully, no one is under the truck during any jacking procedure and jack-stands or the equivalent are used after the truck is jacked up. I wouldn’t want to be under a truck teetering on a hi-lift jack attached anywhere to the truck.
    The biggest disadvantages I see are that the hitch receiver is high above the ground, it is nearly flush with the tail gate making a hi-lift inconvenient, and it isn’t under the suspension.
    ScrippsRanch67 likes this.
  8. Jul 18, 2023 at 1:34 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    ^THIS^ And by lifting from the hitch, you must be using a high lift or other similar jack? I would not use those to change the tire, they are really designed only to help get your vehicle out of a ditch, as a winch, and some other things like that.
    Putting a scissors or bottle jack under the axle is the best way to change a tire. Also, be sure to use the spare and then the flat wheel as an emergency block by putting it under the frame if you don’t have anything else like a jack stand.
    there are some tricks on how to tie up an axle to the frame so it doesn’t unspring as you lift the vehicle by the hitch or the body, but you do that at your own risk, and I’m not gonna explain how.
    Rock Lobster[QUOTED] likes this.
  9. Jul 18, 2023 at 1:35 PM
    OnHartung'sRoad
    :rofl:
    Note to self: Don’t piss off tow or recovery truck drivers!
  10. Jul 18, 2023 at 4:37 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    it's really the best way to change leaf spring shackles.
  11. Jul 18, 2023 at 4:54 PM
    Old goat1914
    Old goat1914 Well-Known Member
    Chicagoland, Indiana
    2016 TRD Sport DCLB 4x4
    Get a bigger jack so you don't have to crawl under the truck if you can.
  12. Jul 18, 2023 at 5:05 PM
    BmTaco91
    BmTaco91 Well-Known Member
    Alberta Canada
    2021 AC TRD OR 6MT
    It’s fine
    soundman98 likes this.
  13. Jul 18, 2023 at 5:16 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  14. Jul 18, 2023 at 5:39 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Hell no…..
  15. Jul 18, 2023 at 5:45 PM
    #35
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Still no real weight. A ton maybe? Those bolted connections could hold a lot more.
  16. Jul 18, 2023 at 9:55 PM
    #36
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    wait… Z71 package on a….. Ranger?? Hmmm. Edit… n/m I see it’s an Alfa.
    move the jack in a few more feet and lift the rear dif.
    soundman98[QUOTED] likes this.
  17. Jul 18, 2023 at 10:05 PM
    #37
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Funny enough, just tonight I helped a frontier change a flat. They were jacking from the hitch and couldn’t get it up high enough to even get the flat off.
    StandardTaco likes this.
  18. Jul 20, 2023 at 6:54 PM
    #38
    soundman98
    NW Indiana
    i was replacing a rotted out rear spring mount. needed the springs to droop, otherwise, cutting out the perch would've sent the eyelet through the bed!
